This thread is privately moderated by MassiveOverkill, who may elect to delete unwanted replies.
Old Mar 07, 2013, 08:09 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Fixing those loose battery connections in your transmitter
It's obvious that not all batteries are created equal, but sometimes their dimensions, most importantly length can cause problems as the battery won't make proper contact because it's too short. I've noticed the problem more prevalent on rechargeable batteries.
Stretching the springs doesn't always work because the battery stop on the transmitter prevents the postive (+) terminal from reaching the flat plate. To fix this you need to pry the plate out a bit.
Here's a stock battery plate:
Simply insert a screwdriver or better yet I'm using some pointy scissors:
Do the twist:
And the final result:
If your quad is falling out of the sky do to momentary battery connection problems, this is the first thing you should check.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Mar 12, 2013, 06:25 AM
gamjamm is offline
Find More Posts by gamjamm
gamjamm's Avatar
United States, MD, Havre De Grace
Joined Dec 2009
Great advice. Almost all the RTF TX's suffer from "inferior contact syndrome". Short of a rechargeable battery mod, this is the best bet. Also some thin cheap foam can be attached to the inside back battery cover to kill the slop of some causing the double A's from having intermittent contact.
gamjamm is offline Find More Posts by gamjamm
Question EOS1420i ''output battery connect error'' and ''bad balance connection'' errors mistercrash Batteries and Chargers 10 Mar 24, 2015 02:07 PM
Discussion USING THOSE AA RECHARGEABLE Batteries in a radio for RC Rhondas Batteries and Chargers 24 Jan 16, 2013 01:23 PM
Discussion How - to connect your transmitter to PC stefan9111 Radios 4 Jan 08, 2012 03:36 PM
Alert Video Transmitter Connecter Failures by Vibration and Heat :( Here is how to Fix JettPilot FPV Talk 37 Dec 19, 2009 09:56 AM
Whats your experience connecting a Full-charge to Half-charge Battery in Parallel? lazy-b DIY Electronics 6 Nov 17, 2005 12:29 AM
