If you two are laughing at me, laugh away. I will just consider the source. For many, many years, when fuel was not so readily available, I bought my nitro by the 5 gallon container from a shop that supplied dragsters and such, and castor oil from a commercial supplier; mixed up, and sold fuel to the surrounding fliers to pay for my own addiction, so I did have to do more than just a little research into the subject.
I one were to make a CASUAL examination of two stroke vs four stroke, one would realize that in a two stroke the mixture is introduced into the crankcase, and then disbursed into the engine. In a four stroke, the mixture is introduced into the head (through the valves), and the only lower engine oiling is by whatever bypass there is in the engine. Les |
doesnt matter anymore on any reasonable fuel.
in the early 90's (may have been late 80's IDR) "4-stroke" fuels came out. instead of 20%'ish castor like normal fuel, they used synthetic blends to drop the oil content in the 15-17.5% range. if youll look on any bottle of normal old glow fuel made in the last 10-15 years in the USA. youll notice most normal 2-stroke fuel is running synthetic blends around 17% oil. oil content is pretty close either way. dont let them get lean and youll be fine. |
I have a blending question. I have a gallon of Byron Gen2 Race 2000 20% nitro, 12% lubrication. I know the lube is a 50/50 blend synthetic/castor. I want to bump the oil content up to 25% using sig castor. This gives me a nitro content of about 17%. My question is this: Will this blend work good for ok cub, cox .049 engines? Will the synthetic have an adverse effect? Is the nitro content sufficient?
Torino, Italy
Joined Oct 2010
Letchworth, Great Britain (UK)
Joined Jul 2004
The only warning I heard about 4-stroke fuel was that they can't tolerate too much castor oil, because it can gum-up the valves.
The fuel I used in both my 2-stroke and 4-stroke OS engines (before I went electric) contained 9% synthetic oil and 6% castor oil, and 10% nitro. Never had any wear or running problems. |
| Thread Tools | |
| Sold Miracle Double Switch with Fuel Dot for gasoline or glow fuel New in package | Green Fuel Boy | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jan 10, 2013 02:35 PM |
| Discussion New Syma S107 for nephew not working properly help please | Theo911 | Beginner Training Area (Heli-Electric) | 29 | Jan 10, 2013 09:38 AM |
| Discussion Proper fuel and glow plugs for engine. | Strykerta | Engines | 3 | May 02, 2011 11:59 AM |
| Discussion Proper Disposal of Glow Fuel | theluckyone17 | Beginner Training Area (Fuel) | 9 | Jul 28, 2008 10:04 PM |
| Proper length for fuel line | babenson | Fuel Plane Talk | 9 | Oct 26, 2005 11:22 AM |
