How about a picture of the wing? The only way that the Dandy sport will roll uncontrollably after launch is a really warped wing or the cg so far off that when stalled it enters a wicked snap roll.. Sounds like a rigging issue.
Whatever its worth (not much if you ask my wife ) I think that the Dandy/ Dandy sport combination (i.e. polyhedral/ and dihedral wing) is an incredibly well thought out, well designed, and well implemeted basic trainer. Yes I do have one. My 7 year old is learning on it as we speak.Scott |
Joined Aug 2002
I feel inclined to speak up for the Dandy Sport, too. It was my first traditional balsa plane (after a Wing-E). Warps in a wing can be hard to spot. Mine looked perfect after covering but wound up needing lots of trim to stay level. Once trimmed, it behaved perfectly.
I'm building a Tantrum now. Another great kit. Skawrpion -- I suspect your problem is with building and/or covering, rather than with your choice of kit. |
Are you STILL bashing this plane? You've been jumping in almost every Dandy thread tellng your tales of woe. In your first thread you stated you were the cause of all of the problems. Now here you are blaming the kit again. You say you had to buy another fuse. In the first thread Doug tried to GIVE you a new fuse to make you happy. With all the perfect fitting, laser cut, interlocking parts I don't see how someone could build one crooked yet you managed to and you want to blame it on the kit? Dude, if you can't build a Mountain Models kit then you'll never be able to build any balsa kit. YOU and you alone are responsible for your lack of success and you need to appologize to Doug AGAIN. At the bottom of this post is a quote from your original post with your first appology. Obviously you didn't mean it.
I, too, am sorry you've had a bad experience with the Dandy/DS.
I am on my third fuse. I still have the original Dandy wing, and the Sport wing, which I've used as my aileron trainer. I have a less-than-envious talent for turning my Dandy into a lawn dart. My current fuse has three layers of balsa around the nose, to make up for the pieces I've ripped off. But it is still a great plane to fly, IMHO, and my first aileron plane. If I take two planes to fly, the Dandy Sport is always one of them. I do not blame the designer/kitter for my errors in building, or in piloting. If you are more comfortable with foam, go for it. When I started this hobby (last March), I went through three foamies (Mini Piper from H-L), crashed all three on the first flight for each. After doing more research here, I ordered a Duskstik from MM. Builit it. I could barely get it off the ground. Wrote Doug an email and asked him what I should check. I ended up sending him jpeg's of the finished plane -- wings, tailfeathers, etc. He diagnosed the problems, and told me how to fix them. I tried the plane again and had my first successful flight. Not every flight was successful. I ended up building a second Duskstik to continue my learning process (self-taught, no club or expert to help out). Than a Dandy. Than the Sport Wing. Than a Switchback Sport. I would have given up on the hobby had it not been for Doug's willingness to help and his encouragement, which he gave freely and sincerely. I am not a kid (51 y.o.). I can tell you that his approach to the hobby in general and his customers in particluar is a rare and wonderful thing. You are certainly entitled to your opinion, as you have stated. But, there is an old saying: "It's a poor workman who blames his tools." |
I don't want to pile on I think its common enough knowledge that the Dandy Sport is a great plane!! I think the best advice you have gotten is to have an experienced flyer trim the plane for you and look over it! Neither fuselage was crooked, I told you in another thread how to make sure your tail was straight
I do have a Dandy Sport and it is one great flying airplane even with an inexpensive brushed motor. Because of the potential building problems and lightweight structure I wouldn’t recommend it for a beginner that doesn’t have someone to give direct help with the building and with the initial flights. |
Also the stabs being out of square more than enough to see with the naked eye still wouldn't cause his flight problems. I'll bet that the wing has one hell of a warp in it as sukhoi26mx pointed out. I'm just sick of seeing this guy jumping into all the Dandy threads saying this is such a bad kit. If he was asking for help it would be a different story. Instead he's just blaming his lack of building skills on a great plane. I have 2 Dandy's with all three wings, 3 SwitchBack's with both wings, a MiniFlash with both wings, a Cessna 180, a FlashBack and had a Tantrum. All of which built with no trouble I could blame on anyone but myself. I'll also be the last to call myself anything more than an average builder. If I'm asked to suggest a first plane it's always the Dandy. If they want an ARF then it's the Slow Stick. If they want something that can crash then I tell them I can't help them. I build with flying in mind. Not crashing. Joe |
Turbojoe,
I must say, I'm with you. I do think it was in somewhat bad taste to be critical of one plane while advertising another with pictures. I would say without much hesitation that from the description of the events it was a wing, trim problem. The fuselage looks pretty good to me. As a matter of fact if he will PM me, and if he will mail the fuse to me I'll give him $20.00 to help his loss. Peace, LcJ |
Latest blog entry: Own your own - What it means
| Thread Tools | |
| Build Log When You're Out Of F8... The Crusader Build Thread | GGRN | Pusher Prop Jet Models | 390 | Nov 23, 2009 06:51 AM |
| It's Spring, I know you're out there running,.. | Umi_Ryuzuki | Scale Boats | 8 | May 02, 2004 06:04 PM |
| Dandy Sport....this is the one you want, no,need! | turbojoe | Parkflyers | 25 | Mar 27, 2003 05:00 PM |
| UPS One strike too many... you're out!!!!! | boomerace | Life, The Universe, and Politics | 20 | Feb 25, 2003 02:59 PM |
