Old Mar 06, 2013, 09:52 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
any benefit it to using the factory suppressor on a 4 stroke
during a bench test on my os 4 stroke the suppressor set screw came loose and blew the suppressor off, i noticed that the engine seems to run much smoother without it on or maybe it was just a increase in the exhaust noise, i didnt have the rpm gauge handy. does the suppressor help or hinder the engine? it seemed to respond more in rpm to adjusting the carb then when it was on. thats is also a small .30
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Mar 06, 2013, 10:01 PM
datsunguy is online now
Find More Posts by datsunguy
Joined Jun 2011
What is a suppressor?
datsunguy is online now Find More Posts by datsunguy
Old Mar 06, 2013, 10:11 PM
jeff262 is offline
farmington, mn
Joined Sep 2003
the chamber at the end of the exhaust pipe
Old Mar 06, 2013, 10:14 PM
706jim is offline
Find More Posts by 706jim
The suppressor (aka muffler) will reduce both noise and power somewhat.
The engine will run fine without it in place, however, it is also a source of pressure for your fuel tank.
706jim is offline Find More Posts by 706jim
Old Mar 06, 2013, 10:53 PM
Joined Jun 2011
Muffler is what I've always heard it called.
Old Mar 06, 2013, 11:23 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
A dictator in some banana country ?
Reginald is offline Find More Posts by Reginald
Old Mar 07, 2013, 05:57 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Most four stroke engines run fine without a muffler on the end of the exhaust tube. But most flying clubs require a muffler for one to fly at their flying fields along with some sort of a maximum noise level based on measuring DB's. So you might have to have a muffler irrespective if the engine makes enough noise or not. Then most fellows have to provide "muffler pressure" to the vent line of the fuel tank in order to get the engine to run good too.
earlwb is offline Find More Posts by earlwb
Old Mar 07, 2013, 06:54 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Jeff, if the engine really ran smoother after the silencer fell of it was likely due to running too rich and the loss of muffler pressure let it lean out and run smoother.
I TOBOR is offline Find More Posts by I TOBOR
Old Mar 07, 2013, 03:52 PM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
Pretty good theory there, but it sounds like you adjusted the needle afterward, is that right?
I've flown a .40 four stroke with no muffler and it made less noise than most engines with mufflers. With no muffler pressure it would not run out a tank until I rigged up the tank as a uniflow and then it was good to the last drop.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Wanted ASP 1.80 4 stroke use/new mikes68charger Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 06, 2013 02:48 PM
Wanted Looking for Enya 4 stroke engines, used or new, paying with paypal, good price belgiancoupe Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 26, 2013 02:48 AM
Discussion Any Fuel pumps for twin 4-stroke engines? jeff262 Fuel Plane Talk 6 Jan 14, 2013 11:11 AM
Discussion Any benefit in using CL or SPW on control Tx? nixy FPV Talk 15 May 11, 2012 05:31 PM
Discussion How bad could a used Saito (or any 4 stroke for that matter) be? maxpower Engines 11 Dec 11, 2007 12:42 AM
