Western KY
Joined Sep 2003
I'm very interested in hearing of your results. With silkspan becoming very scarce, finding another source of a suitable covering is important. Tracing paper tends to be more stiff and I wonder how easily it can be used over compound curves.
My guess is that it will be fairly tough, but once holed, I'm inclined to think that it may have a greater tendency to tear, moreso than silkspan, since it does not have the long fiber component of silkspan. Keep us up to date on your experiment. |
Ancaster, Ontario, Canada
Joined Oct 2005
Looks good Craig. You might find that you can also "iron" on the paper once the Weldbond glue has dried. There's no need to rush and get it stuck down when the glue is wet. Or after drying, and you find a wrinkle, or want to "move" the paper slightly, just heat the area up with your iron and "iron" it out flat.
You might also want to consider the Doculam. It is probably cheaper, lighter, and has the "glue" on one side. John |
United States, AL, Tillmans Corner
Joined Oct 2012
Finally got a can of nitrate dope (and some thinner), and tried it out on the first cover test done a few days ago.
First comment: OUCH! $21 for a quart of dope, $13 for a pint of thinner. Second comments: Applied beautifully, dried quickly, the paper did not pucker like it did with the water. It stayed taut and formed a nice skin. I am now going to begin papering the Envoy with this material, and using some color tissue as the trim. Pictures (in the build thread) as I proceed... |
Joined Oct 2012
Update -- Tracing paper has a wax-like coating that seems to completely prevent nitrate dope from penetrating through the weave. I just tried to work the dope through some wet paper, and could not get the wood wet at all. The substance acts like a blocker to the dope.
Back to the drawing board... ![]() I'll be ordering some genuine tissue in a few days... |
Western KY
Joined Sep 2003
Joined Oct 2012
I haven't tried that yet. I'll see what happens when I get a chance. What I did notice is that nothing from the dope appeared to penetrate, even after rubbing repeatedly with the brush. The wood remained dry to the bone under where I had been rubbing. I figured at least some of the thinner component should have passed through, but it didn't.
| Thread Tools | |
| Discussion Covering material recomendations | Heliman420 | 1/2A Planes | 34 | May 10, 2013 08:29 AM |
| For Sale 7 rolls of aircraft covering material Flitekote & MonoKote | Paulsitive | Aircraft - Electric - Miscellaneous (FS/W) | 9 | Apr 04, 2013 06:04 PM |
| Idea Ripstop Nylon as Covering Material | Jon K | Electric Plane Talk | 10 | Jul 17, 2008 11:52 AM |
| Idea Covering with Tracing Paper | kevin matthews | Free Flight | 4 | Apr 20, 2007 09:34 PM |
| Has Anyone Built Using Paper Covered Depron? | WillowPtarmigan | Foamies (Kits) | 19 | Aug 22, 2003 01:06 PM |
