Old Mar 06, 2013, 09:25 PM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
Help!
Elevon linkage throws with electrical mixer
Bear with me please, I'm new to wings! I'm trying to figure out how less elevator travel and more aileron travel is done with an add on electical mixer. My radio doesn't have mixing or programming. I'm used to two separate sets of control horns and servos. Now that they are combined into one linkage each, sharing functions, I'm confused.
I can do this easily with the old sliding servo mechanical mixer but the electrical version has me baffled. Maybe because I've never seen one work? You tube has many vids, all using programmable radios, which is no help for me.
KenSt is offline Find More Posts by KenSt
Old Mar 07, 2013, 05:58 AM
Claude G. Vest is online now
Find More Posts by Claude G. Vest
Claude G. Vest's Avatar
Indiana
Joined Jan 2003
Before programmable radios, we would open the transmitter and install resistors on both outside terminals of the elevator stick's pot.
Remove the wire, solder one end of the resistor to the terminal, solder the wire to the other end of the resistor.
Some people installed small multiturn trim pots in a similar manner so they could adjust the amount of throw, instead of trial and error with resistor values.
Tight Turns,
Claude
Claude G. Vest is online now Find More Posts by Claude G. Vest
Old Mar 07, 2013, 08:40 AM
KenSt is offline
Scratch builder
USA, PA, Telford
Joined Apr 2004
When I searched "elevon mixer" I saw posts about this. Some questioned whether it would work while others had already been there and done it. I'd rather make a mechanical mixer than mess with my transmitter if that's my only choices. From what I understand, the electrical mixer add on for this purpose is a fixed 1:1 ratio. That's what promted my question, how do you vary the throws. Apparently you don't/can't??????
Old Mar 08, 2013, 12:08 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Try asking in the DIY Electronics forum.
Stuart A is offline Find More Posts by Stuart A
Help! Flaperon Mixer for Elevon? Jumpshot Flight Accessories 3 Jun 09, 2013 10:28 PM
Question Using a Flaperon Mixer for an Elevon? Jumpshot Electric Plane Talk 3 Feb 18, 2013 01:26 AM
Help! Elevon mixer - problem with switched channels and beep error! Moelich73 Aerial Photography 10 Dec 03, 2008 05:35 AM
Help! Elevon mixer - problem with switched channels and beep error! Moelich73 FPV Talk 0 Nov 28, 2008 06:57 AM
Tx with "Elevon" mode or V-Tail Mixer? eta Parkflyers 1 May 13, 2003 01:43 PM
