United States, CA, Stockton
Joined Jan 2006
Check here http://www.toolcenter.com/070_5_Band_saw_Blades.html
If you Google 70,5" bandsaw blades you might find a outfit close to you. I also think Craftsman carry's14 " bandsaws |
You can order anything you want and any length you want here
http://www.bandsawbladesdirect.com/ LEN www.RcAerotowing.com |
USA, MI, Rochester Hills
Joined Jul 2010
For re-sawing: http://www.highlandwoodworking.com/w...s705to137.aspx
Joined Feb 2010
Here is the eBay welder:
http://www.ebay.com/itm/Sure-Splice-...item3a7c9129b3 I do like to repair things and can solder, so I will try the silver solder method, but what is a "blowlamp". SpadCat |
USA, GA, Carrollton
Bradford West Yorkshire, UK
Joined Apr 2010
Sorry SpadCat , Even the term Silver Solder creates waves of misunderstanding on your side of the pond so I didn't realise that "Blowlamp" was an uncommon term too.
OK., this link should explain :- http://www.homemodelenginemachinist....w-blades-9288/ As you can see, you only need a small Gas torch to "Silver Braze" the joint. On any of the woodworking and Model Injineering sites the same question is regularly asked and you can save lots of stress on a Sunday when all the stores are closed with a relatively cheap "Repair" kit. You DON'T need a gas torch connected to an external cylinder with a flexible rubber pipe. As BM has stated, a scarfe joint is much stronger than a butt weld. Regards Ian This :- http://www.rcgroups.com/forums/showthread.php?t=977831 was at the bottom of this page. |
Joined Feb 2010
No problem Circlip, and thanks for the answer and link. Just like what has happened to some of you, my latest project has been halted due to a broken blade, and if I had the right material and knowledge, it would have been only a short delay.
Thanks to all! SpadCat |
| Thread Tools | |
| Discussion Band saw Blade | RCTodd | The Builders Workshop | 27 | Aug 23, 2012 02:47 PM |
| Question Band saw vs. scroll saw | NedBurdick | The Builders Workshop | 45 | Jan 12, 2011 01:16 PM |
| Question Looking for band saw blades to cut metal, any recommendations? | ken_nj | Dock Talk | 9 | Jun 28, 2010 05:28 PM |
| Discussion Silver soldering band saw blades | planeman | The Builders Workshop | 14 | Aug 16, 2009 06:38 AM |
| Scroll saw vs band saw? | chlee | The Builders Workshop | 32 | Jul 07, 2004 04:38 PM |
