Old Mar 06, 2013, 04:47 PM
wsmorton is offline
Find More Posts by wsmorton
United States, AZ, Prescott
Joined Aug 2006
Help!
Need Help Identifying Wingtips
Hi!
I got these wingtips from a friend and neither of us can determine which plane it could have come from. In the pics, I only show the left tip, but I also have the right tip.
Wingtip Length: 37.25 inches
Wingtip Root Chord: 9.25 inches
Joiner Rod Diameter: 0.46 inches (11.8 mm)
The joiner rod appears to be carbon and is glued into the wingtip and extends out of the wingtip by 2.25 inches. Both the leading edge and trailing edge is carbon/kevlar fabric and fiberglass between them. The servo pocket is also reinforced with a patch of carbon/kevlar fabric. The aileron is top hinged and has a carbon fiber wiper. The airfoil appears similar to the MH-32 and the wingtip weighs around 8.9 ounces.
It's obviously from an older 3 - 3.5 meter F3B/J plane, but I just can't pin it down. I might even consider buying the whole plane if someone has it as a hangar queen or has the rest of the parts.
Any help with identifying the plane that these wingtips belong to would be greatly appreciated!
Scotty
wsmorton is offline Find More Posts by wsmorton
Old Mar 06, 2013, 05:05 PM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Looks like tips from a Graphite (Vladimir's Models). MH-32 foil as you surmised
GoFaster is offline Find More Posts by GoFaster
Old Mar 06, 2013, 05:43 PM
wsmorton is offline
Joined Aug 2006
It does look like it's from the original Graphite series, but from the fully molded version:
http://www.fvk.de/Englisch/Graphite%20GFK-CFK.html
The other wingtips (built-up, D-Box) shows a round joiner rod so this might just be it. From the pic on the web site, the color scheme looks the same. The Graphite 2 has a square joiner rod so I think the wingtips might be from the first version of the Graphite.
Thanks!!!
Scotty
Old Mar 10, 2013, 05:27 PM
Larrikin is offline
Find More Posts by Larrikin
Everything's A Compromise
Larrikin's Avatar
Joined Jan 2005
You may want to consider the possibility of them belonging to a Europhia1.
The broad root chord, short span and tip shape give it away.
David
If the pic doesn't appear in the media browser, click on it anyway to enlarge it or right click and "open in new tab".
Larrikin is offline Find More Posts by Larrikin
Old Mar 10, 2013, 07:28 PM
wsmorton is offline
Joined Aug 2006
The measurements are very close to the Europhia 1. I'll have to do a search to find if the joiner rod on the Europhia 1 is round or square. I can also print out the airfoil per the pic (HD48) and compare that to the wingtip.
A search on RC Groups came up with some good reviews, but not many pics of version 1.
Scotty
Old Mar 11, 2013, 02:58 AM
Gungho is offline
Find More Posts by Gungho
Gungho's Avatar
Singapore
Joined Aug 2006
Thats surely a Vladimir plane.....from these few observations
1. The servo openings
2. The Kevlar strands wrapping around the spar
3. The Neon colors...classic Vladimir
4. The wing shape
I have built 2 mini graphites and also have friends with Graphites...pretty sure its a graphite. My first Mini G had the same exact magenta underside color
Gungho is offline Find More Posts by Gungho
Old Mar 11, 2013, 07:27 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
The Graphite has the round joiner and the metal locator pin near the TE, along with the oblong hole for servo wiring - just like in your pics.
Old Mar 11, 2013, 08:56 AM
wsmorton is offline
Joined Aug 2006
I tend to agree that the wingtips are from the first version of the Graphite. The information I've found on the net seems to confirm this, plus the confirmation of the construction type from GoFaster and Gungho. It appears that the composite Graphite 1 wingtips were rare since all I could find actual product pictures of were of the gas-bag type.
The Europhia sure looks nice and I'd love to find some good pics of the wingtips for comparison, but I'm not finding that many composite planes with large, round joiner rods. But I haven't finished searching around the net and I might still find something else with similar construction.
Anyone got a Graphite 1 composite, center panel on the cheap? :>)
Scotty
Old Mar 11, 2013, 05:25 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
I would tend to agree that this is NOT a Europhia. I have been friends with MartinW for a while and have built and handled most of his airplanes, (Carracho, Estrella, Europhia 2, Radical). The use of Kevlar/Carbon fabric is not consistent with his building techniques. I would tend to look toward eastern european countries as they use more Kevlar/Aramid. So the guess that Vladimir built it is probably a good one.
Avaldes is offline Find More Posts by Avaldes
Old Mar 11, 2013, 07:22 PM
Soarmark is offline
Find More Posts by Soarmark
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Looks just like the tips from my expired Graphite 1, no doubt in my mind. Paint, servo cover recesses and round joiner rod are big hints also. That carbon wiper looked way cool on the ailerons and flaps!
Soarmark is offline Find More Posts by Soarmark
Old Mar 12, 2013, 08:45 AM
wsmorton is offline
Joined Aug 2006
Since I don't have the rest of the plane to go with the wingtips, I might just have to make a 2 meter slope plane out of them. Although, I would have liked the hinge to have been on the bottom, instead of the top.
Scotty
Question Need Help Identifying an Engine Pierre_de’ Loop Engines 5 Feb 12, 2013 03:26 PM
Help! Need Help Identifying This Dauntless KenSue Fuel Warbirds 9 Feb 06, 2013 05:07 AM
Help! Need help identifying scale helicopter flyingskyhigh Scale Helicopters 14 Jan 29, 2013 05:49 PM
Discussion New to boats need help to identify please. sgmxr6 Racing Boats - Internal Combustion 5 Jan 15, 2013 08:39 AM
Discussion I need help to identify.... avidek Classic Pattern Flying 1 Jan 11, 2013 02:49 PM
