Old Mar 06, 2013, 04:26 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
anyone know how to remove camshaft ball?
i am replacing the os camshaft with a reverse camshaft i need to get the ball out of the old one anyone know how to get them out without damaging them? here is a pic of the old with the ball next to the new one
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Mar 06, 2013, 05:02 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
I think they are permanent. Once they are in, they are in forever.
datsunguy is offline Find More Posts by datsunguy
Old Mar 06, 2013, 05:14 PM
screilly is online now
Find More Posts by screilly
United States, FL, Orlando
Joined Feb 2008
Maybe put everything in the freezer, ... then heat the camhaft outter shank with concentrated heat: such as a propane torch? maybe should verfy the use of such torch ... heat may need to be feathered in from behind the openinig or carefully controlled otherwise?
screilly is online now Find More Posts by screilly
Old Mar 06, 2013, 05:16 PM
Joined Feb 2008
I wonder if there is a procedure that is recommended by the manufacturer?
Old Mar 06, 2013, 05:50 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
They are a loose fit. Heat it up to loosen the castor glue and tap it so the ball can fall out or try a strong magnet.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 06, 2013, 06:28 PM
jeff262 is offline
farmington, mn
Joined Sep 2003
if i heated it they would have fallen out, i used a fuel tube and sucked them out there is nothing holding them in, actually sucks putting in the new cam since they just want to fall out of each side. thanks for they help though
jeff
Old Mar 06, 2013, 08:07 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
A dab of grease will hold them in for assembly.
Greg
Old Mar 07, 2013, 12:24 AM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
bearing balls only come in a few standard sizes (usually inch measurements) so if somehow it really is stuck it shouldn't be a problem finding new ones.
ZAGNUT is offline Find More Posts by ZAGNUT
Discussion Anyone know how to fix 808 #16 that died while updating firmware? OBwan Aerial Photography 1 Feb 16, 2013 11:12 AM
Discussion Anyone know how to remove this HK Mini-Swift prop? Kipling Electric Plane Talk 7 Jan 31, 2013 12:36 PM
Discussion Anyone know how to fit these?? ripmax Multirotor Electronics 3 Jan 25, 2013 03:49 PM
Discussion Anyone know how to take apart the S111G? Spirittoo Micro Helis 2 Jan 10, 2013 11:41 AM
Paint removal anyone know how? finallyaheli On-road Cars 8 Dec 06, 2004 05:56 AM
