Old Mar 06, 2013, 12:51 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Interesting not the outer 1/3!
Because it's an APCE (16x10)?
jrb is offline Find More Posts by jrb
Old Mar 06, 2013, 01:08 PM
Nereth is offline
Find More Posts by Nereth
Joined Jun 2012
I'm confused What's going on? Seems like an interesting experiment but I'm not sure what I'm looking at
Nereth is offline Find More Posts by Nereth
Old Mar 06, 2013, 01:21 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Three guesses on what prop I use on my Spit ?
Correct, an APCe 16" x 10", and I love how it FLIES. Flies being the important word.
Now when you get your test bench flying, you may realise that there is a difference between static tests and flying.
Spitfire 5 (5 min 11 sec)
eflightray is online now Find More Posts by eflightray
Old Mar 06, 2013, 01:36 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I like how my Mustang files with 4; Toledo w/2 is OK too:
Jim's electric RC P51 @ 95mph (2 min 18 sec)
H9 Toledo Special Full Throttle Pass (0 min 11 sec)
Jim's RC Electric Toledo near 100MPH (2 min 6 sec)
Old Mar 06, 2013, 02:22 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
The outer 1/3rd of his prop produced no airspeed?
Failed experiment?
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Mar 06, 2013, 04:59 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Don't think so Bruce -- repeatable:
Old Mar 06, 2013, 05:06 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
If I reading this right. The outer third has no air movement to it...or little.
It would make sense that it is this way to hold the rest of the blade in position by just adding a flat plane that resists twisting.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Mar 06, 2013, 05:23 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The outer 1/3rd of the blade is normally responsible for producing most of the thrust.
It appears you've bolted a motor to a stand and have used a pitot tube to measure the propwash velocity. I don't truthfully know the relationship, if any, between propwash and net thrust, but I suspect this test's results aren't incredibly useful.
I think that measuring the thrust produced by any given section of the blade with some accuracy would require physically removing the portions you don't want to measure and taking thrust readings with something like Phil's test stand, using the same RPMs across all tests.
Piece is offline Find More Posts by Piece
Old Mar 06, 2013, 05:56 PM
Nashville TN.
Joined Mar 2006
Oh well. Sounded good to me.
Old Mar 06, 2013, 06:20 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Apce?
Old Mar 06, 2013, 06:41 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Yes, the prop appears to be of the APC E variety. Is that all you're trying to determine? No need for the fancy graphs and tests... The prop's type is written right there on the blade
Instead of posting these cryptic graphs with a couple words and zero background information, why not give us at least a few sentences describing a bit about what it is you're doing, how you're doing it, what you're using, and what you intend to show or prove. The test results aren't exactly self-explanatory.
Old Mar 06, 2013, 07:01 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Interesting theory - I've noticed on many of my props the outer~1/3 has very little if any pitch.
hoppy is offline Find More Posts by hoppy
Old Mar 06, 2013, 10:18 PM
Nereth is offline
Joined Jun 2012
If it's well designed though, it should still be ejecting air at the same speed - but way more of it since it is covering a larger area.
It's probably just that the pitot is having trouble picking up whatever the airflow is like. Pitots generally like to be in undisturbed air as far as I know (not that I even have one).
As C4H10 said, the best method might be to take a prop, measure thrust, then incrementally cut off an inch or so of it and remeasure each time at the same RPM (don't let it spin up more!) to get the result.
Old Mar 07, 2013, 03:01 AM
FLOEY is offline
Find More Posts by FLOEY
Norway
Joined Dec 2007
Measure the thrust with a digital scale (the true force) holding back
Your test gear.
Then cut of 1/3 of Your prop and do the experiment again.
I'm prettur sure You will get a difference ...
FLOEY is offline Find More Posts by FLOEY
Old Mar 07, 2013, 03:33 AM
Brush Hog is offline
Find More Posts by Brush Hog
United States, NC, Smithfield
Joined Jul 2012
Doesn't thrust come from the prop pulling air through it rather than pushing it out?
Brush Hog is offline Find More Posts by Brush Hog
Sold AVEOX 27/39/1.5 with a 3.3:1 gearbox. VERY LIGHTLY USED in Excellent condition mechengineer03 Aircraft - Electric - Power Systems (FS/W) 1 Jan 25, 2013 08:07 PM
Discussion Kids are not interested in RC planes suwito The Builders Workshop 23 Jan 23, 2013 11:16 PM
P-51 inner and outer gear doors for topflite 1/5 scale kit heavichevi Aircraft - General - Miscellaneous (FS/W) 2 Jan 13, 2013 10:33 PM
Found New or Near New 1/8 E Buggy (not interested in nitro's) Buzz_Man Cars - Cars and Parts (FS/W) 1 Dec 31, 2011 10:36 AM
Video wringing out the McClain Wing Cores Starfire Beta 1 - day 2 flight 1 -Outer Banks, NC pval3 Electric Plane Talk 1 May 30, 2009 07:45 AM
