United States, FL, Largo
Joined Feb 2006
Quite honestly takeoffs and landings, or touch and gos is really 75% of what I fly for. I just do touch and gos as often as I can just for the fun of it. A flight simulator is the next best option for learning to land, but IMHO asking for advice on a message board is not going to translate into better techniques, only practice will. |
My brain is filled with so much information !!! we do tend to wander,don't we?
No matter where the wheels are,no matter what type of plane--get the wheels 3 to 5 inches off the ground,and don't allow them to get any closer.Just keep slowly holding the nose up,and as speed bleeds off the plane will settle to the surface. Full size="real ? plane?....What is my model-imaginary ? .Models are real.... No matter who says what,The 'accepted'description is "Full Scale", "Full Size", and "Model" airplane.....It's hard to unlearn things..... |
Latest blog entry: The 'Ancient Modeler"
It does not prevent people from interpreting these terms. I simply explained how I interpret them. Anyone can interpret these terms their own way. We live in a world of confusion anyway. A Predater is a full size airplane without a human on board but it is manned by humans on the ground. If a hobbyist builds one then it becomes a model. Some fellows seem to consider that model airplanes are not real airplanes. For me I consider that model airplanes are real airplanes usually of scaled down dimensions or of relatively low weight and flown remotely via a radio link. Some automatic reaction is essential to be devlopped to become a successful pilot and that is where and why practice is important. Unfortunately it is not practical to have instructors that have been trained to be instructors and to follow a predetermined teaching curriculum like exists in full size teaching for a pilot's certificate (license). Zor |
The LA Racer is not a great beginner plane. It's basically a club pylon racer, like the Sky Raider pylon racing plane (from the same company). I suspect if you're bouncing this one, it's actually because you're landing too slow. Most of the time beginners try to land too fast, but the most common mistake I've seen with these planes is landing too slow, and the plane plops rather than landing and rolling. Try carrying a bit more speed on your landing and see if that helps. Set it down soft and let it roll. I see the pylon racer guys do this all the time - they come in for a traditional landing and slow way down, then the plane stalls just above the runway - for many planes that is the right way, but for these racers, the fast vertical drop causes it to bounce and usually flip over forward. Let it settle onto the runway slightly nose up, but while it's still flying - then hold the elevator to keep the tail down as it rolls. Hard to explain, easy to do when you figure it out. |
You know the same concept applies to full scale flying...when I was working on my Privates, I did a LOT of touch and goes (had to, instructor said so
) then after getting my license, my landing started getting 'less than perfect'....so every so often I would log 6-8 touch and goes every other month and things started getting MUCH better!
Latest blog entry: Is it possible to lose weight?
Joined Feb 2006
In latest AMA e-mail. http://www.modelaviation.com/LandingApproach
Joined Jun 2012
I'll go ahead and try that today .Aswell as some touch and goes to figure it out physically , like what kerwin suggested . Thanks guys . |
If your radio has servo speed control you can slow the elevator servo just a wee bit and that will help a novice thumb smooth out the landings. Of course somebody will dispel this idea but, it worked so good for me on a touchy plane that I'm considering it for other models also.
| Thread Tools | |
| Discussion Land Based FPV System (what's best)? | tsull | Video Piloting (FPV/RPV) | 12 | Feb 26, 2013 03:52 AM |
| Discussion RC Land Catamaran, RC Land Sailing | aebilodeau | Sailboats | 4 | Feb 23, 2013 03:41 AM |
| Mini-HowTo Launch and land - not | jaizon | Electric Sailplanes | 7 | Jan 12, 2013 12:35 PM |
| Discussion A land rich with DS hills... | Aerogance | Dynamic Soaring | 2 | Jan 08, 2013 10:49 AM |
| Discussion air and land based RC wargames! with converted rc quad bikes and quadrotors. | f111 | Car Talk | 0 | Jan 05, 2013 03:24 AM |
