This thread is privately moderated by MrHavoc, who may elect to delete unwanted replies.
Old Mar 06, 2013, 10:36 AM
MrHavoc is offline
Find More Posts by MrHavoc
Trader Rating: 0
MrHavoc's Avatar
United States, TX, Spring
Joined Mar 2013
Trader Rating: 0
For Sale
Hot Item 1700mm P-51 Mustang
All items sold together not seperately.
Kit Includes:
*New* P-51 Mustang RTF Airplane with working lights, flaps and retractable landing gear
*New* Tranmistter
*New* Reciever
*New* Lipo Battery
*New* Lipo Battery Charger
Big Beautiful Doll 1700mm P-51D Mustang
This superb looking P-51D is from the top of the line quality Durafly range and has enough scale detail and features to keep any warbird enthusiast happy. The 1700mm range offers the RC pilot a practical size model that can be easily transported and uses the ever popular 2200mAh 3s Lipoly pack, yet at the same time, the model is large enough to have presence and is able to tackle most airfields, not to mention a little wind, making it very practical.
As well as looking fantastic, this Mustang is plug and fly, meaning very little assembly work is needed. The powerful out runner motor, ESC, navigation lights, servo-less electric retracts & servos are all pre-installed leaving you to glue on the tail feathers and some scale detailing, bolt on the plug in wings and go flying!
The airframe features a removable 2 piece wing that is simplistic in attachment and connection, the new FMS 'multi-pin plugs' mean that the complex wiring is now just a single connection per wing and not the usual plate full of spaghetti normally seen in lesser airframes.
The cockpit is adorned with the full complement of dials and levers and the hand painted pilot finishes the effect. Upfront, the scale shape spinner and reinforced nylon four blade propeller really does give a purposeful look. As you would expect, the huge brushless out- runner motor is mated with a top quality ESC enabling stunning flight performance.Metal gear servos handle all the control surfaces and are fast with great centering performance. This plane will not disappoint, there is plenty of power for those really scale warbird aerobatics and the airframe is vice less with no hint of a tip stall. The pre-installed flap servos have a nice, slow operation to help prevent ballooning and the flaps themselves allow the approach speed to get down to a crawl without a hint of wing rock. There is no doubt, this is one fantastic looking war bird and it flies as easily as a low wing trainer!
Material: Durable EPO
- Wing Span: 1,700mm ( 55.2in )
- Length: 1,5000mm ( 49.0in )
- Flying Weight: Around 3500g
- Servo: 25g Servo x 9 17g Servo x 1
- Landing Gear : Big & slow Electric Servo less Retract Landing Gear
- Motor: 5060-KV300 Powerful Out runner Brushless Motor
- ESC: 85A with 5A SBEC & 6A UBEC Brushless ESC
- Propeller: 17X10 4 Blade Propeller With Spinner
- CG Position: 120mm (From Leading Edge)
-Twist & Turn Electric retracts with oleo Legs & Electric Tailwheel
-All Hardware
-Wing Drop Tanks
-Instructions Manual
-*New out of the box never assembled or flown*
Spektrum DX6I 6-Channel Full Range Asking Price
The 6-channel DX6i uses the same full-range DSM2™ technology found in the Spektrum DX7 and includes an impressive list of programming features for both airplanes and helicopters that are simple to access and use. It comes with the new AR6200 DSM2 6-channel receiver that is robust enough to use in large models yet compact enough to fit in many parkflyers. The DX6i is also compatible with all existing Spektrum aircraft receivers. Whatever kind of flying you do, the DX6i can be adapted to most any model in your existing collection that requires 6-channels or less.
Key Features
• Full range 2.4GHz DSM2 6-channel radio
• 10-model memory
• ModelMatch
• ServoSync
• Roller/selector user interface
• Attractive and ergonomic design
• Proven DSM2 technology
• Rudder dual-rate
• Large LCD display
• Integrated timer
• Contrast Adjustment
• Dual-speed trim scroll
• Model name and type
• Throttle cut
• Trainer Mode
• Model Copy
• Travel adjustment
• Sub-trim
• Servo monitor
• Dual rate and exponential
• Compatible with any existing DSM & DSM2 receivers
• Airplane Programming Features: Flaps, P-mixes, Dual aileron, V-tail, Delta, Differential
• Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal, and CCPM 120)
• Adjustable stick length
• Direct trim access display
Gens Ace 4000mah 5S1P 18.5v 25c Lippo Battery Pack
• Capacity: 4000MAH
• Voltage: 18.5V
• Size: 136.56 * 42.96 * 43.02mm (L * W * H)
• Weight: 536g
• Discharge rate: 25C Continuous , 50C Burst
• Plug:
• 4.0 Banana
• Application : Acepow Gens ace 4000mah 18.5V (5S1P) 25C high discharge rate, able to be charged by 5C! Suitable for Seagull Decathlon ARF 120.
Spektrum AR6210 6-Channel DSMX Reciever
The AR6210 DSMX® 6-channel receiver is a great solution for all model aircraft requiring full range up to six channels. This DuaLink® receiver simultaneously gathers information from two receivers that is processed by patent pending Spektrum™ software that combines it to form the most vivid picture of an RF signal. This dual-path redundancy, plus the fact each of the two receivers is located in a slightly different location, exposes each to a different RF environment and creates a bulletproof RF link in all conditions.
• 6 channels
• Internal and remote receiver
• Patented DuaLink® technology
• ModelMatch™ technology prevents flying a model using the wrong model memory (feature does not work with module systems)
• ServoSync™ technology (feature does not work with module systems)
• SmartSafe™ failsafe system
• US patent 7,391,320
• Flight Log Compatible
• Works with TM1000 & TM1100 Telemetry units
Imax B6AC+ LiPo/Li-Ion/LiFe/NiMH/Nicad/PB Balance Charger
• Charger with built-in AC adapter - use at home and at the field.
• Dual Power multi-use charger for 1-6 Li-Ion/LiPo/LiFe cells, 1-15 NiCd/NiMH cells, and Pb 2-20V. Includes adapters for "Deans" style plugs, JST, Rx pack, glow plug lighter, and alligator clips. Balance plugs on end of unit are JST-XH type and are compatible with many Asian battery packs.
• Internal independent lithium battery balancer: Employs an individual-cell-voltage balancer to maintain your pack in balance while charging.
• Balance individual cells during discharge: During the discharge process, B6-Pro can monitor and balance each cell of the pack individually. An error message will sound and the process will end automatically if the voltage of any single cell is abnormal.
• Fast and Storage mode charging: "Fast" charge will fully charge a lipoly battery in the shortest time. "Store" setting will charge the battery at approximately a 50% charge for long term storage. This prolongs the useful life of the battery pack.
Total complete package worth over $1,000 asking No Less Than $650.00
MrHavoc is offline Find More Posts by MrHavoc
Old Mar 06, 2013, 01:43 PM
deerfreak is offline
Find More Posts by deerfreak
Trader Rating: 100
Joined Jul 2008
Trader Rating: 100
YOu got any actual pics of items? Say with your screen name beside them.
deerfreak is offline Find More Posts by deerfreak
Old Mar 06, 2013, 02:00 PM
MrHavoc is offline
Trader Rating: 0
MrHavoc's Avatar
Joined Mar 2013
Trader Rating: 0
The pictures I uploaded are from the net since everything is still boxed up and brand new.
Old Mar 06, 2013, 02:08 PM
MrHavoc is offline
Trader Rating: 0
MrHavoc's Avatar
Joined Mar 2013
Trader Rating: 0
For those fearful I will take photos of all boxes and plane box open which the plane has never been flown or assembled with my screen name and post them tonight when I get home from work.
New Product FMS North American P-51 D Mustang 1700mm (67 inches!!!) Beltpilot Electric Warbirds 11090 Jul 20, 2016 12:17 PM
For Sale FMS 1700mm P-51 Mustang NIB curtusua Aircraft - Electric - Airplanes (FS/W) 3 Nov 23, 2015 12:53 PM
Sold FMS 1700mm Red Tail P-51 mustang parts glegee Aircraft - General - Miscellaneous (FS/W) 12 Feb 18, 2013 05:23 PM
Found Looking for Dynam P-51 mustang whirl10 Aircraft - Electric - Airplanes (FS/W) 0 Jan 09, 2013 04:22 PM
