Old Mar 06, 2013, 07:36 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Build Log
Aerographics Comper Swift conversion (Video added 27.10.15)
I haven't built a balsa plane for a long time, but i couldn't resist to the Comper swift kit from Aerographics.
It has a 26" wing span.
The kit is made with 1/32 balsa (very fragile), 3/32 balsa and plywood (very hard!).
I bought the kit last year to Sam's Models in the UK. I also bought a pilot, a dummy engine, some glue and solite fims for covering.
I've started to cut and sand the fuselage parts.
It should be a long build, as i haven't much skills at making 'stick and tissue' planes.
The plane should be light, but needs some reinforcement here and there to stand bad landings.
I wish i could build a backyard flyer, so i must care about weight.
It will be ailerons, rudder, elevator and throttle.
I'll use an AR6400 brick + 2 micro linear sevos for the ailerons, if it is a 1S setup. For a 2S setup, i may use a AS3X or an AR6300 + 4 micro servos...
As you can see on the pics, i have bought 2 kinds of glue: Super Phatic and Duco cement.
Any advice for that?
Here are a few pictures of the real plane.
indoor_fr is offline Find More Posts by indoor_fr
Old Mar 06, 2013, 08:16 AM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
For wood its better resin like the super, let me know how it goes!
chulian1819 is offline Find More Posts by chulian1819
Old Mar 06, 2013, 10:58 AM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Use the Super Phatic. It does not get brittle when cured.
Free Flight designs can usually have some of the fuselage structure lightened or removed as it won't have to support a wound rubber motor when converted to RC.
A 2s brushless setup would probably eliminate any possible power concerns. The model would have to be very light (for its size) for a 1s setup.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 06, 2013, 11:53 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks. I've started the fuselage with Super Phatic. It seems ok.
The plane is quite big, but the balsa is very light. I think that the final weigh (plane alone) could be around 35g including wheels and covering.
A 1S setup gear weighs:
Battery 5g
AR6400 4g
2 x 1.7g servos
PZ gear box + bravo SX motor+ 5030 prop: 8-8.5g (Thrust is 50g)
or AP05 + 5030+ 1.5g ESC= 8.5-9g (Thrust is 70g).
misc: 1g
Total = 22g or so.
AUW could be equal to 35+22 = 57g.
So, if i can reach an AUW under 60g, a 1S setup could be used. It is maybe unrealistic..
Old Mar 06, 2013, 03:59 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Mike's flying scale model
I'm a big fan of this website dedicated to FF scale models.
There is a build of a Veron Comper swift. I'll try to follow the tips for my project.
http://www.ffscale.co.uk/comp3.htm
Old Mar 07, 2013, 03:51 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The beginning
I have made the 2 sides of the fuselage.
To get a symetrical result, i have made the first fuselage half , covered it with transparent paper, and then made the second fuselage half over it.
Weight is 4.7g for both halves.
Old Mar 07, 2013, 05:32 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Hi,
Thanks for the input.
I've found aliphatic resin glue:
http://www.shop4glue.com/aliphatic-r...esive-20-c.asp
Is it what you're refering to?
What is the difference with the glue i'm using?
Thanks.
Old Mar 08, 2013, 03:13 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
A little more progress. I've had problems with the wood which is very soft (1/32). I broke 2 pieces. I don't understand this choice. The 3/32 balsa would have been a better idea...
I'm on holidays, so i should be able to finish the fuselage by the end of the week.
Stay tuned.
Old Mar 08, 2013, 11:15 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Hi Folks!
I've progreesed on the fuselage. Building with balsa is addictive!
Old Mar 10, 2013, 10:10 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Well, making the nose was longer than i expected. I have sanded a big block of soft balsa for the lower part. Here is the result.
I will finish the fuselage, except the upper rounded part, by mid week, i think.
Old Mar 10, 2013, 11:45 AM
Tim Wolff's Avatar
Joined Sep 2002
Do you have a plan for mounting the motor (or gearbox)? The nose is looking very "enclosed". Is it removable? It may be worth considering. No matter how you do it, do the best you can to make the power system easily serviceable. Changing the prop or motor should not be an ordeal.
EDIT: The whole bottom block of the nose looks like it would make an excellent hatch if carefully cut free and retained with magnets. Install and service the power system (and probably the battery) from the bottom.
I'd also have a go at removing the part numbers from the exterior surfaces. They will show right through any light colored tissue. Perhaps a Q-Tip (cotton swab on a stick) and bleach? Try it before sanding because it (or any liquid AFAIK) will raise the grain of the wood.
Old Mar 10, 2013, 12:21 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The nose is not removable, because the motor is outside the fuselage. It will be hidden in the dummy engine.
You can see the motor mounting on the picture of the plan.
Good idea. I don't know where the battery will be located. I might be surprised, because the bottom block is quite heavy, and the motor is much forward than usually. So maybe i 'll have to install the hatch backward.
I'll do that.
Thanks Tim for your interest and your advices. They are welcome.
Old Mar 12, 2013, 06:39 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Here is the vertical vertical tail.
I'll make the horizontal one tomorrow.
Old Mar 14, 2013, 06:34 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Dummy engine
Here is the horizontal stab. It weighs 1,9g. I really don't like the super phatic glue. I've used some cyano.
I would ask if someone could tell me how to work with the dummy engine (from Sam's models). See picture on post #1.
Do i have to cut the plastic between the cylinders?
As it is hollow, i've thought about filling it with expansive foam to get a full shape. What do you think?
If someone has used this dummy engine, please tell me how you have done.
Thanks.
Old Mar 15, 2013, 06:48 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
I've started the wing. The ribs are so thin, like cigarette paper! They break easily.
Also, here are a lot of nice Comper Swift pictures:
http://www.google.com/search?q=compe...64%3B824%3B549
Question Century Swift NX vs Century Swift Carbon psguardian Large Electric Helis 8 Feb 04, 2013 04:58 PM
Discussion Aerographics Auster conversion advice kartman24 Scale Kit/Scratch Built 2 Jan 19, 2013 09:29 AM
Discussion Aerographics kits, any one converted one to RC? kartman24 Scale Kit/Scratch Built 3 Jan 17, 2013 09:36 AM
Sold Swift NX, Swift 16 frames $90 shipped sv_1 Aircraft - Electric - Helis (FS/W) 1 Jan 12, 2013 12:41 PM
Contest Fun Build 3: Comper Swift (plan) Milhafre Scale Kit/Scratch Built 39 Apr 12, 2010 08:11 PM
