Old Mar 06, 2013, 03:13 AM
Magne is offline
Find More Posts by Magne
Moss, Norway
Joined Jul 2003
22xx-24 direct drive in IMAC model?
Hello Steve.
I am considering motor options for a 35% IMAC model operating on 12s.
(2600mm/102" wingspan, 13 kg/28 lbs)
Although I have used set-ups with both the P42 and the P62 gearboxes in the past, I would prefer a direct drive system.
Are the 2220-24 2.5Y or 2225-24 2Y viable options in a direct drive system?
Is the 8mm output shaft strong enough to take the load from a 24-26" propeller operating at 6500 rpm?
Thanks and regards,
Magne
Magne is offline Find More Posts by Magne
Old Mar 07, 2013, 10:57 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
The 22XX motor is really for higher RPM than you are looking at--one of these would make more sense: http://www.neumotors.com/Site/3200_36_series.html
sneu is offline Find More Posts by sneu
Old Mar 07, 2013, 12:57 PM
Magne is offline
Moss, Norway
Joined Jul 2003
Thanks for the reply, Steve.
Maybe I am misinterpreting the data on your website, but I find this a bit confusing.
For my application I would be looking at something like 7 kW power, for IMAC.(Advanced class)
The 3210/2Y (kv=165) would be in the ballpark when it comes to rpm, and is rated at 4 kW peak.
(Assuming 165x44x0.86=6200 rpm loaded.)
On the other hand, the 2220-24/2.5Y (Kv=172) has a similar Kv, but is rated at 6 kW peak.
Further I would expect the 2225-24/2Y (Kv=180) to be in the ballpark 8 kW peak.
(data missing from table)
For applications requiring 4kW peak power (as quoted for the 3210), why would not the 1924/2.5Y (Kv=165), rated power 6 kW peak be a better option?
Really not trying to be difficult here, but seriously interested in finding viable options that would work reliably without a gearbox!
Regarding the 3210:
Is the motor front mounted only? (no rear supports required?)
I have previously operated the 1527/P42 combination to levels significantly exceeding the stated Surge power. After sorting out some initial cooling/baffling problems, this seemed to work fine.
Do you think this would be possible with the 3210 also? (i.e overloading)
4 kW Surge is a bit low for this particular project.
Thanks a lot,
Magne
Old Mar 07, 2013, 04:45 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Regarding the 3210:
Thanks a lot,
Magne
Hello,
The ratings for the power levels are based at operating the motors at or near their maximum RPM rating. The 22XX @ 6200 RPM is only operating at just over 1/5th its maximum RPM--which means the available power with have to be reduced to 1/5th also.
The 32XX at 6200 is running at almost 2/3 of the maximum RPM so the derating is less.
We will also be making a longer version 3215 which would easily handle the power you need.
The published ratings are on the safe side--you can push things harder than suggested.
Steve
Old Mar 08, 2013, 02:38 AM
Magne is offline
Moss, Norway
Joined Jul 2003
OK, that is interesting.
I suppose that this means that the motors for all practical purposes don't have a power level limitation, but rather a current (Amp.) limitation. (I mean, is anybody operating these model airplane motors at up to 125 or 166 Volts? Certainly not legal here in Europe.)
In my opinion it would make the specification tables easier to read if the Max. Amp. level was quoted in the table. (Suggestion.)
Back to the 32XX motor.
The 3215 is interesting. Do you have any details such as various Kv's, and motor weight and length?
(And max. Amp!)
Thanks for your support,
Magne
Discussion Motor for 22-24 lbs 3D/IMAC model Magne NeuMotors 2 Jun 30, 2009 09:38 AM
Discussion Ammo 24-33-4040 or Ammo 24-33-3500 direct drive? cjbucher Power Systems 15 Apr 29, 2007 01:30 PM
24% Funkey Extra 300, Direct drive 20x13 henke Sport Planes 16 Jul 19, 2002 10:26 AM
24/12 Strontium Ferrite Motor - Equivalent to Direct Drive Cobalt Motors Jamie- Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2001 12:27 AM
