Old Mar 06, 2013, 12:45 AM
Dale93 is offline
Find More Posts by Dale93
Tommy
Joined Mar 2013
NQD rc jet boat build
hey guys I decided to get in to this famous craze at the moment with the nqd jet boat now I just got some questions to be answered please answer as many as you can as all the help and or advice I cane get will be much appreciated.
1. whats the biggest water cooled brushless motor I can put in this
2. what is the best esc and turning servo I can put in it
3. the actual jet system is there a better setup for it ie copper propeller or metal grate to put on the bottom or ? :/
thank you for answering these questions also websites rc hobby shops or whatever names you got throw them at me I want to get this thing into the beach s I can do some jumps
Dale93 is offline Find More Posts by Dale93
Old Mar 06, 2013, 12:00 PM
pompebled is online now
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Dale,
Welcome to the wet side!
Regarding your questions:
- 1) read the thread: http://www.rcgroups.com/forums/showthread.php?t=1404719
- 2) see 1)
- 3) see 1), any obstruction in the inlet slightly reduces the efficiency, for these small jets there are no brass impellors available.
Regards, Jan.
pompebled is online now Find More Posts by pompebled
Old Mar 06, 2013, 01:26 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
While I second Jan's suggestion that you read the thread, I will admit that there is sometimes a fair bit of random stuff to sort through in there to find the useful bits. That said, it is an entertaining read!
The basics in my opinion:
Ideal motor = 24mm or 28mm water cooled inrunner, 2800-3200kV on 3S 2200mah LiPo.
ESC: Turnigy Seaking 35A
Servo: Any 9g servo or larger, bonus points if it's waterproof.
Jet upgrades are not necessary, aside from maybe changing the stock plastic grate to some small metal rods. The plastic one works fine though until you break it.
Anyway, come on over to the main thread, we'll help you through the process.
Firehawk989 is offline Find More Posts by Firehawk989
Old Mar 07, 2013, 10:17 AM
sundogz is offline
Find More Posts by sundogz
Platinum Card Member
sundogz's Avatar
United States, AR
Joined Sep 2007
Also check out the Tear Into forum on the RCU site http://www.rcuniverse.com/forum/m_7991409/tm.htm as the one here on RC Groups has turned into basically a chat room, and takes a lot of reading to find pertinent info.. A good powerful motor would be this 28mm water cooled brushless from HK http://www.hobbyking.com/hobbyking/s...rSearch=3900kv. You'll need a 3.17 to 2.3mm coupler. Any 60A water cooled esc will work as well as any full size servo, no need to spend a lot of money. You'll like the boat, it's a blast to run in rapids. I use expanded metal, like what some desktop organizers are made from (Wally World) as a grate to keep out the baddies, as the original grate (or stainless wire copies) still lets in small pebbles that will destroy the plastic impeller (get spares from ebay). Hope that helps!
sundogz is offline Find More Posts by sundogz
Old Mar 07, 2013, 03:43 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I have a build thread from when I built mine as well, it's a couple years old though.
wparsons is offline Find More Posts by wparsons
Old Mar 09, 2013, 01:51 PM
paultbg is online now
Find More Posts by paultbg
paultbg's Avatar
Joined Jul 2012
Can someone link
Can someone link the good replacement propeller for this boat on ebay ?
I know someone you might be able to make them out of metal.
Regards
paultbg is online now Find More Posts by paultbg
Old Mar 10, 2013, 01:17 PM
Tollytime is offline
Find More Posts by Tollytime
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
Hey Dale. Here's the ultimate!!
KMB Drive, with a Xk4042 2000kv Turnigy.
I have these drives available with the adapter plate.
This guy has all his motor numbers mixed up.
KMB Jet drive NQD jet sprint hull BL4024 2400kv River climbing (1 min 47 sec)
Tollytime is offline Find More Posts by Tollytime
Old Mar 10, 2013, 07:48 PM
sundogz is offline
sundogz's Avatar
United States, AR
Joined Sep 2007
Regards
Here's an impeller seller on ebay http://www.ebay.com/itm/NQD-757-6024...item3a7f1797f2
Old Jun 29, 2014, 10:08 PM
Jmill33 is offline
Find More Posts by Jmill33
Joined Mar 2014
Hey Toll
Where can I get one of those drives and how much?
Jmill33 is offline Find More Posts by Jmill33
Old Jun 30, 2014, 12:26 PM
Sneek, Netherlands.
Joined May 2004
Do you mean this:
http://www.ebay.com/itm/NQD-757-6024...item43ca3161c2
Regards, Jan.
Old Jul 04, 2014, 12:41 PM
BenVK is offline
Find More Posts by BenVK
BenVK's Avatar
United Kingdom, England, Enfield
Joined Jan 2012
I had a spare 3500kv outrunner laying around so put that in my NQD jet boat. On 3S, it reaches max speed at about 60% throttle and won't go any faster so I just use 2S packs now.
It's a fun boat but not as fast as I hoped for.
BenVK is offline Find More Posts by BenVK
Old Jul 07, 2014, 12:43 PM
Vancouver, BC
Joined Aug 2009
Yea 3500kV is a bit high for 3S. Also, a jet boat will never be as fast as a prop boat due to how they work. Way more resistance to flow in a closed system compared to having a surface drive prop out back spending its time half in and half out of the water.
These are most at home in rapids in small creeks where you can play with the features of the stream and not worry about damaging the boat or the prop on rocks.
Old Jul 09, 2014, 02:25 PM
BenVK is offline
BenVK's Avatar
Joined Jan 2012
I can't run my fast prop driven boats right now due to the amount of weed in the water so this little jet boat is good way to still enjoy the hobby. It's not clogged up once yet.
Old Jul 09, 2014, 04:11 PM
Vancouver, BC
Joined Aug 2009
Yea that's a plus too for sure!
But do yourself a favour and find a creek!
NQD Tear Into RC Jet Boating Seymour River (11 min 20 sec)
Old Sep 27, 2015, 11:34 PM
Lew Zee is offline
Find More Posts by Lew Zee
Lew Zee
United States, FL, St Petersburg
Joined Dec 2013
NQD jet drive(s) in a scale boat
Has anyone used the NQD (757?) in a scale model boat? I know someone that is building a Dumas American Enterprise and original design called for jet drives. The AE is 52 inches long. I don't know what the finished weight should be. Lew
Lew Zee is offline Find More Posts by Lew Zee
NQD Brushless jet boat for ??? (feeler) Crowdcontroler Non R/C Items (FS/W) 1 Feb 26, 2013 01:55 AM
Sold NQD Jet boat - everything you need to build your own! JGuilty13 Boats (FS/W) 4 Feb 06, 2013 07:42 AM
Video [VIDEO] SGCrawlers Boat Team: Stiletto Mystic NQD Jet Boat Offshore Warrior Sea Drift boolean21 Dock Talk 0 Nov 15, 2012 03:57 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 07:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 07:48 PM
