Old Mar 05, 2013, 10:22 PM
Rocketman320 is offline
Find More Posts by Rocketman320
Joined Oct 2005
Covering with ca glue and silk
Is it possible or has anyone covered a sold wood or balsa structure using CA Glue and silk? I have seen CA and fiberglass used together as a covering method. I really need need a fabric that is lighter than 1/2 oz cloth yet strong like silk.
Thanks!
Rocketman320 is offline Find More Posts by Rocketman320
Old Mar 05, 2013, 10:33 PM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, VIC, Sale
Joined Apr 2011
The Cyano will immediately harden on the silk, leaving an ugly, raised mess. The tried and true method is attaching the silk using model dope. You'd need to seal it in any case, and dope works well for taughtening and sealing it too. And it smells good
Have a look here http://airfieldmodels.com/informatio...wing/index.htm
wizard of odd is offline Find More Posts by wizard of odd
Old Mar 06, 2013, 07:30 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
It will be heavy.
Al M is offline Find More Posts by Al M
Old Mar 06, 2013, 11:09 AM
packardpursuit is online now
Find More Posts by packardpursuit
Joined Jan 2009
The FF guys flying discus launch gliders (up to one meter span), almost always use solid balsa wings, with local applications of fg cloth at launch wing tip, and use duco cement to stick the cloth to the balsa. There was a recent build over on Hip Pockets where a fellow built a very small rubber scale Me-109F using CA and tissue on very thin balsa shells, for wing tail and fuselage. VERY interesting and surprizingly light.
A single layer of Fg cloth or silk imparts almost no strength to a sheeted surface EXCEPT in tensile strength. For all intents and purposes doped silk, tissue, and or silkspan does a similar job. However, I gotta think CA and tissue (which is comprized of multiple fibers overlapping), once bound to balsa MUST impart more stiffness. FG is most efficient when used in multiple layers, which then starts to emulate the CA/tissue/ balsa shell.
Just my .02.
packardpursuit is online now Find More Posts by packardpursuit
Old Mar 06, 2013, 11:17 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I'm assuming here from the fiberglass cloth reference that you're covering a sheeted fuselage or fully sheeted wing.
The weight will still be there as CA glue is quite heavy. It's also difficult to spread the CA out evenly as it kicks off before it can spread out very far. And it's hell to sand.
The 1/2 oz cloth isn't that much heavier than silk. And it's most certainly stronger and won't degrade from UV light exposure when outside like silk does. Silk loses much of it's strength when this happens. A buddy that uses a lot of silk for his big spark engine old timers gets about 5 years worth of life before the silk is so brittle that it needs to be stripped off and the model re-covered. And we only fly these things about a dozen days a year.
If you're looking for a lighter sort of base for a finish then consider dope on the wood then cover with tissue paper using thinner to soak into the paper and soften the dope on the wood. The tissue won't degrade but if you clear finish it the UV will fade the colour over time. But as a base for a painted finish it's pretty good.
If you're painting the finish on the tissue is a better option since it will require a lot less primer/filler to smoothen it out compared to most of the fabrics. And the sandable primer is VERY heavy. Colour paints are also heavy so a light finger on the spray gun trigger will go a long way to holding down the weight. Brushing on colour paint is right out of the question. By the time the film is thick enough to ensure even colour you've got easily three times as much paint on the surface as a minimal spray coat would be.
BMatthews is offline Find More Posts by BMatthews
Old Mar 06, 2013, 01:49 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
My way-outside the "box"
I fiber-glass the sheeting on my models with .75 oz cloth and thin C/A. I cut more cloth than necessary,and drape it over one half of the area,'weighting' it to lie flat.
Then I open the"box", and pour C/A into a clean spray bottle...(Windex,etc.),and standing up wind, let 'er fly.It goes a loooong way,and doesn't 'go off' all that fast.A cloth in a sandwich bag in the opposite hand pushes it flat on application.Cloth follows contours,and plastic doesn't stick.
On my 1/4 scale models, it's lighter than paint,as it seals the surface,limiting penetration.
Rubber gloves are recommended,and obviously it's done outside.
Total cost is equal to most other finishes.
epoxyearl is online now Find More Posts by epoxyearl
Old Mar 06, 2013, 09:43 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Very interesting technique there Epoxyearl....might have to try it!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Mar 07, 2013, 05:06 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Earl, an interesting technique for sure.
Do you need to keep the pump going pretty consistently to avoid the CA kicking off in the mister pump or does it stay thin and watery for quite a while?
Old Mar 07, 2013, 05:33 PM
epoxyearl's Avatar
Joined Oct 2011
The life of the pump depends on a couple of unknowns..One, I think, has to do with moisture,as the first time I tried it, there was no problem.
I had no plan to "reuse" that bottle,it was just a one-shot deal.
But another time,the nozzle clogged up immediately,with a different bottle.
All I expected was to 'pump and dump' the bottle when done,but it lasted through 2ozs.
Stay UPWIND ! That stuff is dangerous ! I would imagine the mist would glue hair, eyelids, etc.Much care is required...
Old Mar 08, 2013, 10:45 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Or making up a temporary paint booth using a fan and plastic or tarps would be a wise idea as well.
Old Mar 08, 2013, 09:46 PM
Gooroo is online now
Find More Posts by Gooroo
Joined Sep 2010
I have always used thinned white glue to attache both silkspan and silk and then doped over it. Works great!
Gooroo is online now Find More Posts by Gooroo
Old Mar 08, 2013, 11:41 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Definitely wear a breathing outfit if spraying CA. I can only imagine it would eventually kill you in the same manner as Imron paint does for those who learned the hard way.
ARUP is offline Find More Posts by ARUP
Old Mar 09, 2013, 05:58 AM
epoxyearl's Avatar
Joined Oct 2011
Safety is of the utmost importance..I can't imagine taking a deep breath of the spray mist,and having it kick off inside your lungs.
On second thought, I'm almost sorry I shared this.
In retrospect,I have been carefully using C/A since the introduction of C/A glues,beginning with "Hot Stuff".....(the 70's ?)...as with Imron, the results are worth 'suiting up' for.
Old Mar 09, 2013, 09:38 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"I can only imagine it would eventually kill you in the same manner as Imron paint does for those who learned the hard way."
I don't know how long that takes, but my three sons and I did a number of full size cars, and many, many patern planes, using catalyzed Delstar, which, I am given to understand, is the same as Imron, and we are still alive and kicking, and me at 82.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 09, 2013, 10:14 AM
epoxyearl's Avatar
Joined Oct 2011
Les
Les, I did custom paint on show cars, using catalyzed paint and no safety gear for many years,until such time as I realized I am mortal.At 72, I am not on any prescription drugs,for any disease. I think we have a 'protective coating' inside that shields us from harm. lol
Smoking "can" kill you, but not everybody who smokes, dies of cancer.
Discussion Instructions for cover vintage model aircraft of silk Helikoff Vintage & Old-Timer Designs 9 Mar 04, 2013 09:17 AM
Alert frozen CA glue fastfwd Electric Plane Talk 13 Jan 04, 2013 04:23 PM
Discussion Covering tail fathers with Ca glue singlin Hand Launch 11 May 16, 2009 10:07 PM
Covering with silk uscra112 Scale Kit/Scratch Built 26 May 18, 2004 09:55 AM
Question CA glue on covering? danstrider Fuel Plane Talk 4 Sep 23, 2002 12:02 AM
