Old Mar 05, 2013, 08:03 PM
C-ME-FLY is offline
Find More Posts by C-ME-FLY
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
cen aquajet mod
OK guys Yal might laugh like hiyennas. I got a cen aquajet 27" hull with a velineon traxxas 3500 kV with a hk-b125a ESC with a grimracer 4052 3 blade brass prop. Any suggestion on getting this hull to 50mph. Im running 2 nanotech 3s 2200 45-90 c discharge in parallel. Shoot away guys
C-ME-FLY is offline Find More Posts by C-ME-FLY
Old Mar 05, 2013, 08:13 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You'll have a very hard time getting that hull to 50mph, but to do it you're going to need a new motor, batteries and prop. You'll need a strong 3674 motor around 2000-2200kv, 4s5000mah packs (or two 2s5000mah in series) and play with props to see what works best.
Even with all that you might have trouble keeping the hull on the water at those speeds. Might be better all around to keep this one running well as is and then pick up something that's happier at those speeds.
wparsons is offline Find More Posts by wparsons
Old Mar 05, 2013, 08:20 PM
C-ME-FLY is offline
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
OK cool... I've got her running in the 40's now and she is pretty stable. Thanks for the info. 2 4s paralled is too much weight. But I like the idea of seriesing 2 2s 5000. I ran her in some good chop today an she handles really well without turnfin. But awesome I wanna go fast with what I got. Thanks for the info
Old Apr 16, 2013, 10:12 PM
geofrancis is offline
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
how did you get on with your cen aqua jet ? I am in the middle of upgrading mine and I have installed :
KB45-10XL 1200kv Brushless Inrunner 2880W
http://www.hobbyking.com/hobbyking/s..._Inrunner.html
100A 6S ESC
2x 5000 3s Nanotech batteries running at 6s
first run it hit its own wake at full speed and flipped it rolled so fast one of the batteries flew out but luckily the connector kept it attached...unfortunately that had the effect of pulling the boat over and sinking it with just the bow bobbing up and down on the surface.
anyway... after that I decided to upgrade everything as there was a lot of play in the rudder and the prop shaft was bent slightly so it was vibrating. I have ordered a stainless steel 5mm shaft, stainless steel coupling, stainless steel rudder, set of turn fins and a pair of trim tabs. I will be putting servos on the trim tabs then mixing them with a V-tail mixer into a pair of gyros to stabilise it.
this is an old video of the time i had an old 1.2cc nitro car engine in it with its gyro stabilised trim tabs
http://www.youtube.com/watch?feature...&v=XATLij2Xp2s
if this is stable i am thinking about upgrading to a 12S esc with 4x 3s batteries. it should crack 50 or explode trying
geofrancis is offline Find More Posts by geofrancis
Old Apr 16, 2013, 10:17 PM
C-ME-FLY is offline
C-ME-FLY's Avatar
Wilmington NC
Joined Aug 2010
Hahaha. I did the same. Haven't done much except I burnt the vxl motor and put a miss GEICO motor in her and have ran it once since then.
Old Apr 16, 2013, 10:25 PM
Joined Feb 2010
i got mine off of ebay for 35 with a graupner brushed speed 700 race motor installed. i ran it on 8.4v then 9.6v then 18.v and it was fast but the batteries only lasted a couple of minutes so I installed the GX-12 nitro engine from a wrecked rc car but that was underpowered at only 1.2cc. the motor I am using was for my friends boat but it and the batteries were too heavy so i gave him the nitro engine and he gave me the brushless motor now i just need it to run stable.
Sold Cen modded Aquajet RTR yucafrita Boats (FS/W) 7 Sep 28, 2011 08:30 PM
For Sale Cen modded Aquajet RTR over 30 MPH! yucafrita Boats (FS/W) 4 Jun 04, 2011 02:23 PM
Discussion CEN AquaJet 550 Review magnat Dock Talk 10 Jan 21, 2008 04:11 PM
Discussion Buying a CEN Aquajet magnat Racing Boats - Electric 0 Dec 14, 2006 12:40 PM
Wanted Looking for a CEN Aquajet Flyingfool Boats (FS/W) 0 Feb 11, 2006 04:15 PM
