Old Mar 05, 2013, 06:36 PM
USA, OR, Salem
Joined Dec 2010
Mixing digital and analog servos
Is there any problem mixing analog and digital servos in a sailplane? I'm building a woodie and plan to use digital servos for the rudder and elevator and analog for the spoilers. I can't think of any problems but electronic is not my strong suit.
Gary
gmugs284sm is offline Find More Posts by gmugs284sm
Old Mar 05, 2013, 06:42 PM
Wazmo's Avatar
No. VA
Joined Nov 2004
Not a problem, unless you have one of the new high-speed spread-spectrum receivers. In that case, your analog servos make not work with the higher frame rate.
Wazmo is offline Find More Posts by Wazmo
Old Mar 06, 2013, 01:12 PM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
I've done this in a couple of different airplanes (using old 72mHz receivers) with no issues.
rdeis is offline Find More Posts by rdeis
Old Mar 07, 2013, 10:08 AM
Play loud, Fly high
Gil Gauger's Avatar
Vincennes,IN USA
Joined Apr 2007
Mixing servos
I am currently doing just as you describe using Airtronics FHSS-3 receivers. Took a bit of tweaking centers/end points with the spoilers closed to avoid buzzing. Works great.
Gil Gauger is offline Find More Posts by Gil Gauger
Old Mar 09, 2013, 10:44 PM
Ready to string launch!
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
I have a mix of digital and analog in my AR7000 powered Psyko.
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Mar 10, 2013, 04:49 PM
LI, New York, USA
Joined Mar 2003
As stated by everyone else, I have done this with no problem.
Some new receivers and some new servos can take higher voltages than the older models. But if you are running 6V or less, this should not be a problem.
Certain radio/receiver combinations provide the option for high speed/low latency signaling. It is my understanding that this requires digital servos, but I would check with your radio manual. but if you are running at "normal" rates there is no problem mixing regular/and digital servos.
aeajr is offline Find More Posts by aeajr
Question Decently priced/quality 9g servos??? Digital or analog finguz Electric Heli Talk 10 Feb 23, 2013 02:18 AM
Discussion Digital" VS "Analog" servos 60 size fun fly plane eng30 Radios 2 Jan 27, 2013 03:30 PM
Discussion Digital vs Analog Servos? GarryOgilvie Radios 2 Jan 12, 2013 02:59 PM
Question Mixing digital and analog servos benjaminn7 Mini Helis 5 Jul 23, 2008 07:16 PM
digital analog servo mix rand24 Hand Launch 0 May 17, 2005 09:24 PM
