Old Mar 08, 2013, 06:00 AM
Jeremy Kamutzki is offline
Find More Posts by Jeremy Kamutzki
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
Originally Posted by whiskykid View Post
once you have the ribs spread out and pined in place on the plans, making shure that they are strait up and down, take and put a couple drops of thin CA on the spars at each rib!
probably confusing as they can't be glued till all ribs are in place! don't get the ribs and sub ribs mixed up! make shure that the riblets and ribs that have the joining slots are at the center!
and that the riblits aren't unidirectional! there is a top and bottom!
Ok, I will probably use ca to tack them in place while the wood glue dries. Also, I'll remember that the riblets have a top and a bottom, thanks
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Old Mar 08, 2013, 09:37 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Originally Posted by Jeremy Kamutzki View Post
Ok, great. Thanks for clarifying that for me. I've noticed you drilled holes in the front edge of your ribs. Was that to remove weight?
You got me thinking there! I looked up my magazine article - it was written around August 2007, which means I built the model in early 2007 at best.
Holes in ribs. When covering a model in heatshrink film - this one was Monokote'd - it is possible to have the film stick down to so many ribs that when the film is finally heat-shrunk by hot air gun, the air inside expands and expands the film. I've also done less than ideally stiff wings by sticking the film down to every rib, which stiffens up the wing but the iron heat can puff the film in rib bays.
Those holes allow any hot air to expand through the wing, not just in a rib bay. They aren't very big, so don't affect strength or weight worth noticing.
Drilling holes in ribs to reduce weight is pretty much last ditch. If a rib was that heavy - as you well know, balsa has a great range of density - I'd rather replace it than mess around perforating it. Ribs can stand a few holes - most of my models have a paper tube from servo bay to centre for the servo lead, for one example - but you don't want to go too far with perforations to save a few gm overall.
Save you wondering. Years ago, I 'acquired' an old telescopic car radio aerial. Stripped it down, cut the sections down in length to 'convenient', sharpened up one end, taped up the other. Make great tools for fitting holes into balsa wood up to around 1/8".
D
Dereck is offline Find More Posts by Dereck
Old Mar 08, 2013, 09:45 AM
Dereck is offline
Joined Dec 1996
Oops - nearly forgot. Made these rib positioning jigs up years ago, real handy for holding ribs vertical while the glue sets.
Bought a length of alloy 'L' section stock from local big box hardware store - most seem to carry it, though you have to look in dark corners as its not that trendy. Cut into short lengths - 1/2" and 1" for mine, though its not critical. Drilled holes in both arms for pins - see photo.
Clamps - mine came from somewhere like 'Micro Mark' - MO modelling tools company. Most need to be light, so as not to cause balancing issues.
Hopefully the photo says more than I can drone on about. Best couple of hours messing with alloy I've had in a long while
D
Old Mar 08, 2013, 10:59 AM
Joined Jul 2011
D
Ok, that makes sense. I'll do that then on my cub. I didn't realize that the covering was that airtight! When installing the covering (ultracote) do I want to stick it to every rib?
Old Mar 08, 2013, 11:17 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
keep the questions coming, sorry can't help with pic's, as I am actually helping my son-inlaw build his, it is his first full on build also! so the planes at his house!
and as far as electrics go I am no help either! wet fuel kinda guy here!
whiskykid is offline Find More Posts by whiskykid
Old Mar 08, 2013, 01:20 PM
MikeCr is offline
Find More Posts by MikeCr
United States, WI, Slinger
Joined Mar 2006
That's OK. There are plenty of us here that can help you make the transition back from the dark side!
MikeCr is offline Find More Posts by MikeCr
Old Mar 08, 2013, 03:38 PM
Dereck is offline
Joined Dec 1996
I occasionally miss going flying with the little amount of support gear needed to run a glow lump - finger stall, plug heater from two D cells and some wire to a connector and fuel. I know I should have spent a lot more on 'stuff' than that, but my engines kept on starting just fine.
But remembering what my then-new wife's face looked like when I came home smelling all funny from burnt engine fuel soon makes all the stuff needed for an electric model worthwhile...
D
Old Mar 08, 2013, 04:57 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
I got nothing genst electricity! the only successful flight I seen today after I planted my 20cc failed experiment, and my son-inlaw broke his senioreta in 1/2, and el presidente flopped his extra on the runway, I was able to get a flight in with my UMX SBACH, in 10 ta 15 mph X winds!
but hey we all had fun doing it
Old Mar 08, 2013, 05:41 PM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
One thing you might consider for sure when the time comes is to make the stab/ elevator in two halves that are able to plug into each other. The reason is that the covering at the fuselage to fin area will look 'tonnes' better! Just make little aluminum tubes and glue them into the fuselage to receive the stab halves. It's really easy to do- just looks difficult.
ARUP is offline Find More Posts by ARUP
Old Mar 08, 2013, 08:20 PM
Joined Jul 2011
Electronics arrived tonight with my dad when he returned from a business trip in chicago. Now I will be able to plan it all out better.
Old Mar 08, 2013, 08:21 PM
Joined Jul 2011
How would I keep the two halves together and on the fuselage? Would I use a screw that went through the stab half and the aluminum tube?
Old Mar 08, 2013, 11:36 PM
ARUP is offline
Joined Mar 2010
Just 5' epoxy glue stab in place after covering everything and use support wires like the real Cub did. I have pics of this if interested. Any repairs are easily remedied by cutting old stab off and using soldering iron to melt away the epoxy.
Old Mar 08, 2013, 11:42 PM
Joined Jul 2011
Ok, I thought you meant it was removable and that confused me. Pics would be great, just to clarify.
Old Mar 09, 2013, 07:36 PM
ARUP is offline
Joined Mar 2010
PM sent. Just don't want to clog your thread w my pics.
Old Mar 10, 2013, 12:58 PM
Dereck is offline
Joined Dec 1996
The idea of not having to cover around the tailplane/fus joints is good. I did it the kit way and the covering part was too much fun.
Adding the tailfeather bracing wires sounds good too. They are pretty obvious on the full sized Cub, so worth the effort whether they are structural or decorative.
D
Sold Sig 1/4 scale clipped wing cub j3dave Aircraft - Fuel - Airplanes (FS/W) 5 Apr 22, 2013 11:32 AM
Found Sig 1/4 Cub NIB non clipped wing version Ice Aircraft - Fuel - Airplanes (FS/W) 4 Feb 14, 2013 11:44 PM
Sold 1/6 Scale Hazel Sig Clipped Wing Cub woodro9744 Aircraft - Electric - Airplanes (FS/W) 0 Oct 10, 2012 03:39 PM
Discussion Sig clipped wing cub 1/6 scale or not sig?Can anyone ID the kit? ejam Scale Fuel Planes 15 Nov 15, 2010 10:33 PM
Question Help 1/6 scale 56" Sig clipped wing cub creapyd Glow to Electric Conversions 2 Jan 04, 2010 11:30 AM
