Old Mar 05, 2013, 03:12 PM
warthox is offline
Find More Posts by warthox
Joined Aug 2009
what happens if you change rotation direction of the props midflight? [fp 3D quad]
this!
mwc quad // ultraesc 3d (2 min 53 sec)
my first cautious attempts to fly a 3d capable quad
experimental ultraesc fw.
modded mwc fw [oneshot + 3d] for nanowii board.
modded 8x4.5" cf reinforced props.
ultraesc setup:
- input pwm 125-250Ás oneshot
- motor pwm 32khz
- active freewheeling enabled [synchronous rectification]
more info http://www.rcgroups.com/forums/showthread.php?t=1799000
warthox is offline Find More Posts by warthox
Old Mar 05, 2013, 03:14 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Alright, that is cool.
I want ALL the info needed to make this work!
WiseDuck is offline Find More Posts by WiseDuck
Old Mar 05, 2013, 03:16 PM
Oso Grande is offline
Find More Posts by Oso Grande
Need more props..........
Oso Grande's Avatar
United States, TX, Houston
Joined Jan 2013
Wow
Oso Grande is offline Find More Posts by Oso Grande
Old Mar 05, 2013, 03:21 PM
vadimus is offline
Find More Posts by vadimus
Don't panic!
Canada, ON, Mississauga
Joined Feb 2013
Just a thought - as it is being widely considered, quad it doomed once 1 motor is out.
With reversing motors, could the quad land more safely with opposite motor able to reverse to compensate failed side going down?
Considering the fact that even 2 motors combined have enough power to at least decrease negative vertical speed?
By the way, are there any copters with variable pitch rotors?
vadimus is offline Find More Posts by vadimus
Old Mar 05, 2013, 03:35 PM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Bravo! Beautiful innovation.
2400RDR is offline Find More Posts by 2400RDR
Old Mar 05, 2013, 03:36 PM
RuralFPV is offline
Find More Posts by RuralFPV
Head full of foam
United States, NE, Omaha
Joined Jan 2013
OK, stupid operational question:
Does the FC do that automatically? As in, you get it upside down, the FC senses it's new attitude and it turns the props backwards to hover upside down. Or is this something you have to do on the remote, like flip a switch?
RuralFPV is offline Find More Posts by RuralFPV
Old Mar 05, 2013, 03:37 PM
vadimus is offline
Don't panic!
Joined Feb 2013
Or you throttle stick has zero in the center, not at the bottom?
Old Mar 05, 2013, 03:42 PM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
I guess the throttle stick is simply set with zero at THR 50%, same as you would control the ESC for a buggy....
With maybe a little bit of dual-rate for the "reverse", since the props won't be as efficient.
Olivier_C is online now Find More Posts by Olivier_C
Old Mar 05, 2013, 03:50 PM
warthox is offline
Joined Aug 2009
v
exactly.
throttle stick above center = normal rotation.
throttle stick below center = reversed rotation.
throttle stick at center = very slow normal rotation.
theres no position of the stick were the motors are stopped.
there is nothing else. its like controlling a normal cp heli.
Old Mar 05, 2013, 04:13 PM
Wrice4 is offline
Find More Posts by Wrice4
Blacked out 350z - Texas
Wrice4's Avatar
Joined Nov 2012
Originally Posted by warthox View Post
v
exactly.
You sir.......ROCK.
Wrice4 is offline Find More Posts by Wrice4
Old Mar 05, 2013, 04:41 PM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
I see a new breed of props in our future.
Granted is online now Find More Posts by Granted
Old Mar 05, 2013, 05:18 PM
jasper7821 is online now
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Totally awesome ! ! !
jasper7821 is online now Find More Posts by jasper7821
Old Mar 05, 2013, 05:21 PM
serrated is offline
Find More Posts by serrated
United States, KS, Overland Park
Joined Feb 2013
brilliant!
serrated is offline Find More Posts by serrated
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Wow, this is a game changer,awesome work.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Mar 05, 2013, 05:43 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Hello!
I tried to do this early last year, since I added support for this in my tree since Nov 3, 2011, but found that most slow flyer props really suck at reverse thrust (pun not intended). I ordered some non-scooped props from Fancy Foam Models, as I recall, but never ended up getting them, and then forgot to try again. If flat is not available, higher pitch props probably work better. The ones warthox is using there seem to work but don't sound very happy.
For doing this with my code, you just need to set RC_PULS_REVERSE to 1 (which enables RC Car type mode) and perhaps adjust the endpoints, or calibrate them like with an RC car ESC. It will work on any board including without complementary PWM, though complementary PWM does actually help a bit with back-EMF detection and could probably flip directions a bit faster. This eventually led to the start-up improvements and ZC filtering in 2011/2012 that made higher inductance and pancake motors work better and not get stuck spinning the wrong way. I tested with a 2213N with no prop and could flip from full throttle one way to the other in <100ms with COMP_PWM=0.
simonk is offline Find More Posts by simonk
