Old Mar 05, 2013, 10:21 AM
ncp546 is offline
Find More Posts by ncp546
Joined Mar 2012
Help!
Will this motor work with my miss elam?
So im looking to get a faster motor then my stock one that came with my miss elam. I started a thread a few days ago on here and you guys said that this is the best motor for my boat
http://www3.towerhobbies.com/cgi-bin...&I=LXVSV3&P=ML
However, i dont see a water cooler on the engine. My old one did. What do i do, my current set up is
AquaCraft 60 amp brushless esc lipo ready
Spectrum 2.4 GHz DSM SR200 sport surface receiver
Waterproof traxxas survo
& my controller DX2E DSM radio system.
The boat runs off two 2s lipo batteries. Hobby town did my new electronic swap just to let you know.
Does everything seem okay for this motor? I dont want to buy the wrong thing. Also what do i do about the cooling system? Thanks.
ncp546 is offline Find More Posts by ncp546
Old Mar 05, 2013, 11:10 AM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Good motor, you do need to add a cooling jacket to the motor. Pretty much any cooling jacket of 36mm should be fine.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAXEU&P=M
cyberhoops is offline Find More Posts by cyberhoops
Old Mar 05, 2013, 01:16 PM
zozer is offline
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
That is a good motor, but I would use this one instead:
http://www3.towerhobbies.com/cgi-bin...&I=LXZGW6&P=ML
It has more torque that the 2030 motor and will be easier on the ESC. We run the 2030 motor in lighter hydros and often pull 80-90 amps average. The 1800 motor will spin larger props a bit slower, a better solution for the ME. Another advantage is that the 1800 is less likely to burn up if you prop too big or run for too long. Both motors are capable of similar speeds, just with different props.
zozer is offline Find More Posts by zozer
Old Mar 05, 2013, 01:49 PM
ncp546 is offline
Joined Mar 2012
Hey i have a RED/BLUE?YELLOW hook up in my boat. That plugs into the motor. That motor has a black one instead of blue. What do i do?
Old Mar 05, 2013, 02:58 PM
dobydog6507 is offline
Find More Posts by dobydog6507
Joined Oct 2011
Connect any of the 3 wires on the controller to the motor connectors...it doesn't matter which ones...if the motor runs backwards, change any two.
The 2030 AQ motor is the motor to use in that hull.
dobydog6507 is offline Find More Posts by dobydog6507
Old Mar 07, 2013, 07:25 AM
zozer is offline
Steps? What steps?
zozer's Avatar
Joined Jan 2010
Really? Have you even tried the 1800 Kv motor in that hull? Just curious.
Old Mar 07, 2013, 08:43 AM
Joined Oct 2011
Yup, higher rpm's and smaller props are the way to go in hydros...less prop walk.
Old Mar 07, 2013, 05:31 PM
zozer is offline
Steps? What steps?
zozer's Avatar
Joined Jan 2010
Lots of winning racers will disagree with your over-generalized statement, but if it works for you that's great. However, a relatively new non-racer will have less trouble with the lower Kv motor - and his speeds will be within a couple mph of the 2030 motor. The higher the Kv the easier it is for inexperienced boaters to burn up their motor/ESC. A tip for you - what's good for you just might not be the best for someone else. That's a life lesson for you.
Old Mar 07, 2013, 06:09 PM
Joined Oct 2011
Originally Posted by zozer;24354638 A tip for you - what's good for you just might not be the best for someone else. That's a life lesson for you.
[COLOR="White"
.[/COLOR]
Take your own advice then....
Old Mar 11, 2013, 10:03 AM
ncp546 is offline
Joined Mar 2012
Ahhhhhhh! What one should i get im still bunked on this now
Old Mar 11, 2013, 11:10 AM
Joined Oct 2011
Either...time for you to decide what to do.
Old Mar 11, 2013, 11:45 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The 2030kv motor will be a great option, and not too high of a kv.
wparsons is offline Find More Posts by wparsons
Old Mar 11, 2013, 01:45 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You need to be cautious with the 2030kv and only a 60 amp ESC, start with a small prop.
scorpion1 is offline Find More Posts by scorpion1
Old Mar 11, 2013, 03:57 PM
Joined Oct 2011
Remember, this is the standard set up on the AQ UL-1 and been running for several years now..with a good lifter prop its becomes a 50 Mph boat.
Nothing wrong with the 1800 kv motor either though. The original Miss Elam came with a 1500 kv motor.
Old Mar 11, 2013, 07:05 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I'd strongly consider the 1800kv...............the 2030kv is gonna tend to cavitate with the smaller prop you would be using compared to n 1800kv prop.
My suggestion would be an x637 for the 2030kv and an x640 for the 1800.
Help! Will this motor work with Techone yak 54? d12bn 3D Foamies 6 Mar 02, 2013 07:06 PM
Question Miss Elam Upgrade Motor QUESTION ncp546 Racing Boats - Electric 9 Feb 28, 2013 09:40 AM
Discussion Will this crystal set work with my RC? byteninja2 Car Talk 4 Feb 19, 2013 04:29 AM
Discussion how will my plane fly with this motor and watts?? scottc39 Power Systems 10 Feb 17, 2013 05:18 AM
Discussion Can THIS motor work with THIS plane? If not-can you show me an ARF that will work? zdsweet Electric Plane Talk 2 Jul 24, 2009 09:44 PM
