Old Mar 07, 2013, 12:52 AM
Sukhoikid is offline
Find More Posts by Sukhoikid
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Originally Posted by LoneWolfRC View Post
well you are going quicker than I do my builds.
speaking of which I am glad I didn't buy this...I have no room right now.
but it is very tempting.
when you do your video, can you show:
1. upright harrier to show harrier stability
2. KE spin
3. blender
4. pop top
4. wall
5. parachute into elevator
6. snake if you can
7. 90 degree half roll turn from inverted if you can
8. KE loop
but a plain old upright harrier, as boring as it is, would be appreciated to show upright harrier stability. The wall will demonstrate pitch authority.
I will do it all plus the KE Wall, 45 degree snake, 1 roll in loop, 1 roll in circle, and a few other precision maneuvers.
I do know the prototype did sick pop tops and blenders.
Sukhoikid is offline Find More Posts by Sukhoikid
Old Mar 07, 2013, 04:52 PM
jrdrake9 is offline
Find More Posts by jrdrake9
Joined Jul 2012
If you are following this build tread, one error so far. Make sure that you install the tail wheel and make the 90 degree bend in the metal shaft to plug into the rudder. After you have done the tail wheel assembly, then install the rudder.
jrdrake9 is offline Find More Posts by jrdrake9
Site Sponsor
Old Mar 07, 2013, 07:43 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
John is right. I plan on not running a steerable tail wheel at this point. If you do want to run one though make sure you install the tail wheel assembly first then the rudder.
Old Mar 07, 2013, 08:03 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
Do you fly for OMP?
3Daddict is offline Find More Posts by 3Daddict
Old Mar 07, 2013, 09:00 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Originally Posted by 3Daddict View Post
Do you fly for OMP?
Yes I do.
Old Mar 07, 2013, 10:45 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Well today I didnt do much due to I had some other things to do tonight with work and had to clean up the house a little!
Got the landing gear mounted. It is a good idea to use locktite of course. For the tail wheel I decided to run no steerable tail wheel so I cut off the part that would have bent back into the rudder.
You will need to drill the holes for the two screws that attach the tail wheel assembly to the airplane. Make sure you put some CA down the holes before screwing down the tail wheel.
I also lined up the motor that I am using to the airframe and the holes do not match with this motor setup. I will need to drill out new holes for this motor. It looks like I need a 1/2 inch to 3/4 inch standoff to space the motor enough to clear the cowl.
More to come tomorrow I hope!
Old Mar 07, 2013, 10:54 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
what you got in the crate?
3drcparts is offline Find More Posts by 3drcparts
Old Mar 07, 2013, 11:11 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
I recently moved and it was the way I transported my gas planes. Had to build four crates. Now I am using two of them as work benches lol.
Old Mar 07, 2013, 11:41 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Subed, looking forward to video. Looks nice so far.
JimTMich is offline Find More Posts by JimTMich
Old Mar 07, 2013, 11:55 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
why? I speculate, but maybe it is easier on rudder servo?
Anyway I bet a lot of people are looking forward to the video, and if it flies as well as we hope, I bet you sell out.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Mar 08, 2013, 12:18 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
nice, would love to see you fly
Old Mar 08, 2013, 12:25 AM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
The rod is long enough for it to fit in between the rudder and vertical stab and then bend 90 degrees to be inserted into the rudder to be able to use it as a steerable tail wheel. I had a brain fart and just didnt think about doing this when I glued the rudder in I usually dont run steerable tail wheels on my gas planes. ha ha
Old Mar 08, 2013, 12:26 AM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Ill be in CA for a few IMAC contest in the future.
Old Mar 08, 2013, 12:29 AM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Ordered two batteries today from hobby king. Didnt find exactly what I wanted but it will do for now. 4000 mah Zippy packs at 35c 5s. Also ordered a 16x10 electric prop. Servos should be in next week. If my weekend is not too busy I am going to try to finish everything except for installing servos.
Gotta hurry up and get this one done not only to get video but another plane is on its way! Except this one is a little bigger....
Old Mar 08, 2013, 10:14 AM
3Daddict is offline
3Daddict's Avatar
Joined Oct 2010
Do not forget to cut a hole in the bottom of the plane for cooling.
Discussion NEW OMP 60" Electric S-Bach Sukhoikid 3D Flying 7 Nov 28, 2013 10:18 AM
Discussion am i the only one here with the sbach 342 60"? out of stock Glow to Electric Conversions 20 Apr 19, 2013 08:07 PM
For Sale omp extra da 60 rappid rich Aircraft - Fuel - Airplanes (FS/W) 5 Feb 16, 2012 03:57 PM
Discussion SBACH 342 60 airline XavierM 3D Flying 2 Jan 13, 2012 10:00 AM
Sold Pilot 25% Sbach 342 assembled with servos JimVanLoo Aircraft - Fuel - Airplanes (FS/W) 5 Feb 03, 2011 11:16 PM
