Old Mar 06, 2013, 08:12 PM
Sukhoikid is offline
Find More Posts by Sukhoikid
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
We suggest to install the control horn on the rudder before installing the rudder to the vertical stab.
I check and there are two spots back at the rear of the fuse for servos. I plan on running a Pull Pull Setup for now so I will be using the double horn. The kit is supplied with a extra single horn just in case you want to run your rudder servo in the back or run two elevator servos instead of one.
Sukhoikid is offline Find More Posts by Sukhoikid
Old Mar 06, 2013, 08:19 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Its a good idea to take some sand paper or a dremel tool and scuff up the horn so the glue can stick to it better.
Next you need to cut the covering in the rudder so the control horn can go through. I prefer using a soldering tip to do this.
Old Mar 06, 2013, 08:36 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Use epoxy to glue the control horn. I have used thick CA in the past on this size of plane and it also works well. For this plane I am using 5 minute epoxy. Make sure both sides are equal.
Old Mar 06, 2013, 09:49 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Use the supplied CA hinges to hinge the rudder. Be sure to wipe away any excess CA.
Old Mar 06, 2013, 09:51 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Its a good idea to go through the fuse and put a few drops of CA where wood joints meet. The aircraft does not really need it, but its always a good idea to do this so the plane will last even longer. I also put a few drops going down the battery tray. I plan on pushing the limits with this plane!
Old Mar 06, 2013, 09:54 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Next step for me is to attach the landing gear. I plan on doing this tomorrow considering I am worn out right now. I had to finish a few other projects that I have going on in my garage. Hope to get a little more done tomorrow!
If anyone has any questions please let me know!
Old Mar 06, 2013, 09:56 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Originally Posted by 3Daddict View Post
Are you going to run the 7245MH?
Plan on running the 5245MG from Hitec
Old Mar 06, 2013, 10:06 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Originally Posted by Ohio AV8TOR View Post
Can you please post some dimensions of the control surfaces?
Hope this helps.
Old Mar 06, 2013, 10:08 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Originally Posted by runnin9s View Post
Got mine today and I really like the carbon fiber reinforced fuse. my power hd digital servos look a little big but a little work there and they will fit. I could use some input on what servos will fit perfect if anyone has some info
Here is a ruler laying beside one of the servo holes. Hope this helps to decide what servos you can use.
Old Mar 06, 2013, 10:16 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Is there a rod to connect the two elevator halves then?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Mar 06, 2013, 10:33 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
There is a plywood piece that connects the two together.
Old Mar 06, 2013, 10:34 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
Speaking of the elevators I forgot to get that measurement! Ill get it tomorrow.
Old Mar 06, 2013, 10:41 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
speaking of carbon, is the carbon running the length of the fuse, tubes or a thin layer on top of balsa, battery tray is it solid carbon or thin on top of ply/balsa
3drcparts is offline Find More Posts by 3drcparts
Old Mar 06, 2013, 10:44 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
well you are going quicker than I do my builds.
speaking of which I am glad I didn't buy this...I have no room right now.
but it is very tempting.
when you do your video, can you show:
1. upright harrier to show harrier stability
2. KE spin
3. blender
4. pop top
4. wall
5. parachute into elevator
6. snake if you can
7. 90 degree half roll turn from inverted if you can
8. KE loop
but a plain old upright harrier, as boring as it is, would be appreciated to show upright harrier stability. The wall will demonstrate pitch authority.
Old Mar 06, 2013, 11:50 PM
UAV R&D Pilot/MC/PO
Sukhoikid's Avatar
Joined Jun 2006
There are four carbon tubes running down the fuse from front to back. As for the battery tray it is ply with a thin piece of carbon on top.
Discussion NEW OMP 60" Electric S-Bach Sukhoikid 3D Flying 7 Nov 28, 2013 09:18 AM
Discussion am i the only one here with the sbach 342 60"? out of stock Glow to Electric Conversions 20 Apr 19, 2013 07:07 PM
For Sale omp extra da 60 rappid rich Aircraft - Fuel - Airplanes (FS/W) 5 Feb 16, 2012 02:57 PM
Discussion SBACH 342 60 airline XavierM 3D Flying 2 Jan 13, 2012 09:00 AM
Sold Pilot 25% Sbach 342 assembled with servos JimVanLoo Aircraft - Fuel - Airplanes (FS/W) 5 Feb 03, 2011 10:16 PM
