Old Mar 04, 2013, 09:20 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
Question
Brushless RPM sensor false readings
Hi. I bought am almost complete suite of EagleTree electronics recently. I finally got everything installed today and was doing the first OSD testing. Everything appears to be working fine except the RPM sensor, which is periodically showing a non-zero figure (~3-4k) while the motor is off but armed. Now, I read the FAQ and it suggests either the arming tones or brake pulses, but this is well past arming and I have all brakes off (plus its not that regular). One weird thing is I can force it to "blip" by engaging AUX2. Whenever I use the AUX2 switch, the blip happens. But I don't need to do that... just sit and wait and it will do it (non consistently) every say 4 to 20 seconds. Thoughts?
s_mack is offline Find More Posts by s_mack
Old Mar 05, 2013, 10:00 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
I am also getting spurious RPM readings with the brushless rpm Sensor plugged in but not hooked up to a motor and only a battery has been attached to eLogger V4 and no ESC. Just found it doing a battery "test" recording. Appeared on all battery tests with both 13+ volts and 21+ volts input.
Ken Myers is offline Find More Posts by Ken Myers
Old Mar 05, 2013, 01:25 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, are these pulses happening outside, or indoors? If they are happening indoors, and especially when connected to a PC, they are most likely AC line noise (either 50Hz or 60Hz) that the sensor is picking up. There is some line noise filtering in the eLogger firmware, but it is not able to filter it all.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Mar 05, 2013, 10:11 PM
s_mack is offline
Registered Loser
Joined Jun 2010
In my case it was a field test... not hooked up to a PC.
Old Mar 06, 2013, 07:33 AM
Ken Myers's Avatar
Joined Aug 2001
Mine was not connected to a PC, just setting on my kitchen counter.
Old Mar 06, 2013, 01:31 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
s_mack, do the pulses occur if the ESC is unarmed? If not, most likely the ESC is generating some noise pulses when armed that the sensor is picking up. One additioanl thing to try would be to use both sensor wires (one per motor pole) if you are not already, or try disconnecting "wire 2" if both are connected.
Ken, what are the values of spurious readings you are seeing? If they continue outside your house, and the readings are greater than the normal readings your motor produces, you can click "Advanced, Set Min/Max Values" and cap the RPM value to the max that you would normally see. This will hide the spurious pulses.
Site Sponsor
Old Mar 06, 2013, 10:43 PM
keninvic is offline
Find More Posts by keninvic
Joined Jan 2012
I am having the same problem with my brushless RPM sensor - when ESC is connected it intermittantly jumps in values, the RPM does increase with throttle, so it seems to work properly. It is only at idle that I notice these spurious pulses. It stays at 0 when I disconnect the Elogger V4 from the ESC, but of course the ESC no longer has power then.
keninvic is offline Find More Posts by keninvic
Old Mar 06, 2013, 11:16 PM
s_mack is offline
Registered Loser
Joined Jun 2010
The pulses are there when unarmed, but that's expected because my ESC emits a periodic "tone" (yes, I know its no the ESC that's singing to me) to warn that its not armed (I guess). It expectedly goes haywire during the arming tones. But its after arming that I don't expect it to do that and it does. Ie. its "jumping" when there's no tones at all.
I'm not going to worry about it though. I tried a different ESC and it still jumps during any tones but is steady when armed but zero rpm... as expected. So it is something to do with that ESC. Even though I have brakes set to off, there's obviously some sort of pulse that's going through.
Just to address your other comment: It is currently connected with both wires. I suppose I can give it a try with just wire #1.
Thanks for your help. I'm satisfied that its my ESC causing the behavior. It appears accurate during use otherwise.
- Steven
Old Mar 07, 2013, 06:49 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Thanks for the update. Yes, it sounds like the one ESC is just noisy. I'm guessing removing a wire won't affect it, but it won't hurt to try.
Site Sponsor
For Sale eagletree brushless rpm sensor steveiewonder Aircraft - General - Miscellaneous (FS/W) 1 Jan 20, 2013 06:28 AM
Discussion Brushless RPM Sensor Readings rjbsilva Eagle Tree Systems 7 Oct 16, 2009 11:08 PM
Discussion Brushless RPM sensor reads half value on LCD jackosmeister Eagle Tree Systems 4 Aug 11, 2009 02:39 PM
Discussion elogger V3 brushless RPM sensor readings are erratic grumpy42 Eagle Tree Systems 13 Jul 24, 2009 07:01 AM
Discussion Different reading on RPM brushless sensor with and without prop stemasoft Eagle Tree Systems 6 Jun 24, 2009 07:34 PM
