How would yo reflect an LED
I want to put strobe lights on the wing-tips. Of course the LED does not have a very wide viewing angle. What would you use to reflect/refract the light so it could be seen from more than just straight on?
I was thinking of something like this to attach to the front of the LED: http://www.ebay.com/itm/8mm-Alexandr...90858835518%26 I also thought of a small reflector made similar to a small flashlight reflector, without a hole in the center, and put the LED out front of it, pointing back at it. I don't know where I would get such a thing. A tiny version of this would be nice: http://www.ebay.ca/itm/LOT-GENERAL-E...item43adb74b58 |
I wonder what they do with these. Wire in series so they will take 12v or parallel with a resistor?
http://www.ebay.ca/itm/10x-194-168-T...item4164bfb142 |
Maybe this may be what I am looking for: http://www.ebay.ca/itm/100pcs-5mm-Wh...item2c6010d079 Or maybe this: http://www.ebay.ca/itm/New-50pcs-5mm...item5aeeb5f3bf They say 14,000 but the ones I got are 55,000 I saw some others that have the top with a cone shaped depression which I could reproduce with a drill bit but wouldn't it need to be polished? What if I just did that and painted it white? |
Aaahhhhh.....pi$$ on it, I just ordered a couple of these:
http://www.hobbyking.com/hobbyking/s...dproduct=11744 Will use the LED's for tail nav lights maybe. |
Letchworth, Great Britain (UK)
Joined Jul 2004
For brightness and viewing angle I think nothing beats these http://www.cree.com/led-components-a...onal/xlamp-xpe . They're very small, surface-mounted, and need a heatsink if they're going to be on continuously. But for strobe-like flashes I've been using them for several months now without a heatsink, without any apparent problem. They're visible in daylight at normal flying height, and with them angled at 45 degrees sideways in the wingtips, I can easily see both of them when the plane is coming towards me.
what cree chip did you get I wanted to mention the R2 its a tiny package and offeres the most light output for the package size. Most of the flashlights I build are made for throw meaning they cast a laser like beam of light rather then flood an area this is largly dependant on the reflector type but you need LED power as well (Lumens). I have run R2's using a good driver from 1.5 - 7.4V the higher the voltage the more that LED will shine. If you look for proper mounting plates (Star) for these they are aluminum and sink heat well for your needs that would be all you need for long life as your not running continous for extended periods.http://m.dealextreme.com/p/cree-xr-e...ium-star-15943. Stars can be bought in different sizes so look for the smallest to save weight
I got some of these:
http://www.ebay.ca/itm/221192861752?...e=STRK:null:IT That star looks nice as the cut-out areas will make extra surface area for heat transfer. Are the ones toward the bottom the R2?: http://ca.mouser.com/search/refine.a...aign=119142901 |
| Thread Tools | |
| Help! Problem with MultiWii SE -- yo-yo effect during flight | Garret H | Multirotor Electronics | 12 | Jan 13, 2013 06:52 PM |
| Discussion How would you fix this? | jaizon | Multi Task F3X | 20 | Jan 12, 2013 11:10 PM |
| Discussion Trex 250SE Electronics, how much would they sell for? | kpilot786457 | Micro Helis | 0 | Jan 07, 2013 08:02 PM |
| Poll How would you rather power your LEDs? **Setups for sale now!** | edge5foamy | Night Flying | 2 | Jan 16, 2008 10:26 PM |
| Discussion would this be yo-yo-ing | X3n0 | Micro Helis | 1 | Aug 18, 2006 12:16 AM |
