Old Mar 04, 2013, 01:12 PM
Latinnus is offline
Find More Posts by Latinnus
Joined Dec 2012
Asp 108a
Good Evening,
I am trying to build a twin rotor model plane for a Uni project.
At this point we have been looking into the ASP 108A engines as they seem to provide a good output with a good power to weight and power to price relationship.
However, would you consider this set of engines reliable? Would the combination of both actually be able to provide a power output of 6HP?
Is there any sort of set of engines that you would recommend that would be able to provide a similar performance at low prices?
Looking forward for your opinions.
Best Wishes,
Latinnus
Latinnus is offline Find More Posts by Latinnus
Old Mar 04, 2013, 03:23 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The problem with the low cost engines, is that they tend to be hit and miss in their quality and reliability. You may get a good engine, but the odds get worse for getting two good engines. But you might get lucky though, as they have been improving over the years. Usually the engine itself is fine, it is whether the carburetor works OK or not.
If you aren't experienced with using and running model glow engines, I would suggest a OS 1.20 AX engine as you are likely to have a much more successful experience. The ASp engines amy work OK, but there is risk in buying them and discovering you have problems and how to deal with the problems.
earlwb is offline Find More Posts by earlwb
Old Mar 06, 2013, 04:04 AM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Im with Earl on this one , sometimes individual engines will run fine and then when put together the probs. start . I havent got any of these engines but have a few asps- magnums that run fine but have heard that the 108 can be a problem child so I would go with the ax120 even though it cost more as it may end up saving u alot of grief .Cheers the pope
the pope is offline Find More Posts by the pope
Old Mar 06, 2013, 06:24 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I did acquire a ASP 1.08 a couple three years ago, but I haven't done anything with it or used it for anything yet.
But a few years ago I acquired a couple of ASP .61 four stroke engines and they both had problems. I had to stabilize the needle valve with a short piece of fuel tubing, as the engines were running erratically and having needle valve adjustment problems with false needle settings. Then I had to use 15% nitromethane glow fuel in the engines to get them to run OK. I normally use 5% nitro glow fuel in everything and these engines needed more nitromethane in the glow fuel. But even though they were now running OK, and adjusted well, they both acted like they were loading up at idle as the engines would unload a lot of smoke when you advanced the throttle, after idling for a while. It might improve over time, but I was concerned and thus I didn't use them in a twin engine plane project I had planned for them. I didn't want a engine to quit on me in the air. I just didn't feel comfortable using them in a twin engine plane. I went ahead and used a couple of Saito four stroke engines instead.
More recently I bought three ASP .61 two stroke engines and two of them ran pretty good, but the third had carburetor issues. But I am seriously considering just using the new Fox carburetors on the engines instead, or just the one engine. I have a triple engine project I am thinking about using them on. I have a Fox carb to ASP .61 adapter made and it looks like real good way to do it.
But such mods aren't for newbies to RC planes or RC engines though.
Last edited by earlwb; Mar 06, 2013 at 06:26 AM. Reason: typo correction and add more information
Old Mar 06, 2013, 12:48 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I have a ASP 1.08. As engines go, its only ok. Like has been said earlier, their QC is 50/50. Mine would run good one time, then be finicky the next two times. When running good its fairly strong but the inconsistency is aggravating. I surely wouldnt recommend it for a twin project. Maybe if you replaced the carbs on them, but seems like a better idea to spend more so you wont have to worry about an engine out and loss of the plane.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Mar 06, 2013, 08:50 PM
Rcflyyer1 is offline
Find More Posts by Rcflyyer1
Rcflyyer1's Avatar
United States, FL, Sarasota
Joined Dec 2010
Two airplanes at my flying field use ASP 108 2 Strokes. They seem to idle good and have a TON of power. Both of the engines were acquired new and were broken in correctly. I would go for the O.S. 120AX as Earl suggested. I have heard they are very reliable and easy to tune. The only setback is the price.
Rcflyyer1 is offline Find More Posts by Rcflyyer1
Sold SOLD.....New in Box ASP 108AS with Bisson Muffler Dane McGee Aircraft - Fuel - Engines and Accessories (FS/W) 1 Dec 22, 2012 02:13 PM
For Sale REDUCED...NIB ASP 108AS and Bisson Muffler Dane McGee Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 15, 2012 05:42 PM
Sold NIB ASP 108a $80 shipped Broken Wings Aircraft - Fuel - Engines and Accessories (FS/W) 4 Sep 29, 2010 07:36 PM
Question ABC 108a SC Factory Settings promoto Fuel Plane Talk 1 Aug 19, 2009 07:35 PM
For Sale Asp 108a williame3590 Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jul 25, 2008 10:13 AM
