Old Mar 03, 2013, 06:03 AM
Disarray is offline
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
Fun cub built tips
First off, I am aware of the big fun cub thread, but after picking through the first 500 posts, I can say that posts that are usefull are very well hidden. Once i got to people complaining about where the kit is manufactured, i gave up. I do not feel like wading through that mire any longer.
So, any quick and dirty tips you can give me? I am going to update my post with my observations upon completion.
Disarray is offline Find More Posts by Disarray
Old Mar 04, 2013, 12:24 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
This won't seem like much...
but we did just finish one, and I agree with you about people cluttering up a perfectly good thread with jerky BS.
The windows are on a translucent film, so if you are going to paint your model,
do it before you put the windows on.
The plastic wingspar brace needs to have a drill of the same diameter as the spar tube run into it all the way to the middle, so the tubes will go all the way in.
(Owing to a small mis-alignment in the mold, you may get a part that blocks the spar tube. This is not a reason to whine to customer- service. Just fix it!
Good luck with your model!
Lancer31 is offline Find More Posts by Lancer31
Old Mar 14, 2013, 07:57 AM
Disarray is offline
Disarray's Avatar
Joined Apr 2007
As promised, here are the tips I have picked up and incorporated so far:
1. Center section of fuse has given some trouble, so I reinforced it like this:
2. I also went with an aluminum motor mount to avoid the vibration problem some have had.
3.i have done a bungee mod to the landing gear. I did this because I used a huge motor, will be swinging a 13" prop and would like to avoid prop strikes.
4. I made a photo copy of the written part of the directions, so I did not have to flip back a d forth in the book. And I could x out each section as I completed it.
Old Mar 15, 2013, 05:05 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
I added a carbon fiber rod that goes inside the plastic wing spar from tip to tip. Makes the wing a lot stiffer for those crazy flights.
robbthepilot is offline Find More Posts by robbthepilot
Old Apr 02, 2013, 05:45 PM
raamedicva is offline
Find More Posts by raamedicva
Hanover, VA
United States, VA, Mechanicsville
Joined Oct 2007
Funcub mods
I too have been trying to read through the main thread but find it frustrating. I would like to run a turnigy 35-42 800ish kv motor and will most likely get the aluminum motor mount. I want to be able to hover and STOL. Slow flight is fine for me. Any other suggestions on the build? I'm thinking of going all metal gear servos but not sure if that is over kill. What C rating are people using. I plan on using 2200 mAh 25-35 C batteries. I'm expecting to have to add weight to the tail to get it to balance.
raamedicva is offline Find More Posts by raamedicva
Old Apr 02, 2013, 08:02 PM
cbinfl is offline
Find More Posts by cbinfl
United States, FL, Clearwater
Joined Jun 2009
I just received my 'Fun Cub" kit and I guess it's a pretty fresh kit as heads up was out of stock for awhile. Anyway there is a Hitec metal motor mount plate in the parts bag and it's mentioned in the instruction book. This is not the one with slotted mount holes, it's the one with the mounting holes drilled in a circle. Maybe this is common knowledge, but I didn't know it. I bought the more expensive one for more motor options, but you can save some money if you pick the right motor .
cbinfl is offline Find More Posts by cbinfl
Old Apr 03, 2013, 12:20 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I built mine as is from the box. I can't recall having any gripes.
JDMJim is offline Find More Posts by JDMJim
Wanted Multiplex Fun Cub Jstov Aircraft - Electric - Airplanes (FS/W) 6 Feb 24, 2013 10:36 AM
Video GoPro on Fun Cub chased by extra 300 Watts cooking Electric Plane Talk 5 Jan 22, 2013 06:18 PM
For Sale Multiplex Aluminum motor mount Fun Cub mjdee14 Aircraft - General - Miscellaneous (FS/W) 0 Jan 09, 2013 07:46 PM
Sold Fun Cub khallman Aircraft - Electric - Airplanes (FS/W) 3 Jan 09, 2013 10:19 AM
Wanted Multiplex fun cub addictedtoplanes Aircraft - Electric - Airplanes (FS/W) 1 Jan 03, 2013 03:19 PM
