This thread is privately moderated by MassiveOverkill, who may elect to delete unwanted replies.
Old Mar 02, 2013, 06:15 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Those Pesky Micro Losi \ Walkera Battery Connectors part deux
I figure I'd go into more detail on getting those Micro Losi \ Walkera battery connectors to work better as many still have problems with them.
The first thing to address is the pin angles on charger\RX connector. Typically the pins are pointing the wrong way as pictured below. The pins are pointing downwards which will make it hard to insert the connectors as well as cause bad electrical contact if they're that way on your charger:
You want to get a small flat head screwdriver and slightly pry them upwards. You'll notice the connectors will go in easier and make better contact. The first time you insert the battery, it may go in rough, but the the angle of the pins will self-adjust and subsequent insertions will go much more smoothly:
We've been offering a service on our Lipos to remove the little nubs on the batteries in order to make it easier to take the connectors apart. You can see the nub in the picture below:
Instead of modifying each battery, a much better solution is to remove the locking tabs on the the RX connector using a pair of nail clippers:
Tabs removed vs stock. This picture also shows the pins tweaked vs stock:
So there you have it. Happy quading!!
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
ultra micro 3.7 losi charger with batteries MIKEYOUR Non R/C Items (FS/W) 5 Feb 02, 2013 04:03 PM
Sold rc parts, Battery connectors, low voltage buzzers servo tester more ronzer Cars - Trucks and Parts (FS/W) 5 Jan 18, 2013 10:49 PM
Sold CX2 CX3 micro heli parts lamaIV eflite walkera swash battery frames 2.4g metal parts blueindian Non R/C Items (FS/W) 1 Nov 27, 2010 06:05 PM
