Old Mar 02, 2013, 12:39 PM
boomboom124 is offline
Find More Posts by boomboom124
Boomboom124
Joined Feb 2013
New Sail winch
This is the first (of the 3rd prototype) winch made.
Very happy with the result.
Comparable with the RMG exept in cost.
A GRP mounting plate (not shown) will be fixed under the drum with 2 holes for fixing.
Dimensions - Length 54mm
- Width 36mm
- Height 76mm
Comments welcomed
Description:
boomboom124 is offline Find More Posts by boomboom124
Old Mar 02, 2013, 02:21 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
The physical dimensions do not reveal a lot about why it is or is not comparable with another brand. I don't think many will "bite" on just that information.
martin richards is online now Find More Posts by martin richards
Old Mar 02, 2013, 04:18 PM
Boomboom124
Joined Feb 2013
I use comparison as follows.
Size - smaller overall mass
Speed- 0.2 seconds slower (3turns)
Torque - significantly greater
Waterproofing- significantly better
Power usage- lower
Resolution- finer
Installation -easier and closer to COG
Cost- less (approx 130 GBP)
Weight - 25g heavier
Warranty - 1 year
Old Mar 02, 2013, 05:46 PM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Is it progammable? that one of the big features with the RMG and other similair designs.
8387mike is offline Find More Posts by 8387mike
Old Mar 03, 2013, 02:27 AM
coolmobility is offline
Find More Posts by coolmobility
coolmobility's Avatar
Australia, VIC, Paynesville
Joined Sep 2009
Also what voltage range can it handle and does it work as a BEC like the RMG saving extra wires - battery to winch - power for Rx from winch connection at 5V.
I like that the RMG gears can be seen and cleaned, but having a sealed unit may be an improvement.
Need more data please.
coolmobility is offline Find More Posts by coolmobility
Old Mar 03, 2013, 05:26 AM
gp. is offline
gp.
Find More Posts by gp.
gp.
gp
gp.'s Avatar
South Aust.
Joined Aug 2006
How easy it to service if needed.
Have a great day
gp. is offline Find More Posts by gp.
Old Mar 03, 2013, 05:32 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Looks like a yes as it has battery and servo lead coming out of it. But if its not programmable it just becomes an expensive Eurgle.
More info please
Old Mar 03, 2013, 03:22 PM
Boomboom124
Joined Feb 2013
As requested, some info on the Titan Revolution Sailwinch.
These specifications are liable to change as development proceeds towards
the final production units.
We have several of these winches being vigourously trialed at the moment.
Digital Positive PWM Control with Clock Frequency 20 MHz
Voltage Range:- 5.5v - 8.5v (2-cell 7.4v LiPo)
Absolute Max Voltage:- 9v
Dedicated Red/Black 22g Silicone Power Leads
Voltage Regulated Auxilliary Output at 5.0v 1.2A for Rx and Rudder Servo
Turns:- 4 turns exactly - preset at factory.
Speed:- 1.35secs/4 turns
Stall Torque @ 7.5 volts with 26mm Drum:- 19kg/cm
No-Load Current:- 35mA
Normal Running Current:- 370mA
Stall Current @ 7.5v with 26mm Drum:- 3.3 amps
Dead-Band:- 4uS - preset at factory
Mid-Point Neutral:- 1500uS
Double Ball-raced 6.35mm Hexagonal Output Shaft with V-Ring seal.
Weight: - 190g
Waterproof design comparable to IP67 rating
Dimensions:- 55mm x 36mm x 68mm (not including drum or mounting bracket)
Separate lightweight mounting bracket supplied for easy installation.
The Titan 'REVOLUTION' SailWinch has been designed from the very outset
for model yacht competition racing, covering all classes from IOM to A Class.
It will be designed and manufactured in the UK and all servicing and repairs
will be promptly done under 1 year warranty in the UK.
When a Titan 'REVOLUTION' SailWinch is returned to us for servicing and/or repair,
a renewed 1 year warranty will commence upon return to the customer.
The Titan 'REVOLUTION' SailWinch is a digital programmable servo that
will have it's important motor control/feedback parameters such as dead-band, pulse-width step-size, gain, max PWM duty cycle, mid-point/endpoint positions and signal recognition configured and preset at the factory. The user will not have access to these programming functions.
The amount of turns can be user adjustable from 1 turn to 5.5 turns by adjusting the 'Travel-Adjust' function available in any modern digital transmitter. Same goes for the 'End-Point' adjustment.
If a customer requires more than 5.5 turns for their particular boat, then we can modify the TRS for them upon request, at no extra cost when ordering.
Old Mar 03, 2013, 05:17 PM
gp. is offline
gp.
gp.
gp
gp.'s Avatar
South Aust.
Joined Aug 2006
Thanks Boomboom124 for the specs.
Have a great day
Old Mar 03, 2013, 06:50 PM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
At AUD$190 per winch I dont think many will be heading this way as an RMG is only $60 more and comes with more features.
Not knocking what you are trying to do but you are up against the other winchs from Italy and they are progammable for the same price.
I think you will need to be a little more competitive on the pricing if you want to make a dent on the winch market.
Good Luck
Old Mar 03, 2013, 07:29 PM
bigpat is offline
Find More Posts by bigpat
Love RC Yachts!!!
Australia, VIC, Melbourne
Joined Aug 2012
Yes you are up against competition, but good luck to you. At the end of the day, we sailors have more options!
bigpat is offline Find More Posts by bigpat
Old Mar 04, 2013, 09:15 AM
Boomboom124
Joined Feb 2013
This is being sold as a high performance winch
made from far superior quality parts than anything
currently on the market.
It will have everything needed for both the serious
racer and the club sailor.
Alas, it won't play tunes.
Speed, torque, failsafe, resolution, turn and end point
adjustment and above all, reliability are the
critical factors.
A large Eurgle it most certainly is not!
Alas, it won't play music.
Obviously, in the current economic climate
It has to be priced accordingly so plenty to think about.
Old Mar 05, 2013, 12:09 PM
VeloceHydro is offline
Find More Posts by VeloceHydro
Joined May 2011
Just thought I'd put my tuppence-worth in here.
What is the big deal about these 'must have" programmable sail winches..??
I really think this micro-processor technology is great and all...but on the right device,
where it can contribute something useful and necessary to it's operation and performance.
Not long ago, I owned an RMG ES-380 'Smart Winch', and I put it in to my Pikanto one meter
expecting great things from it, but in the end, I spent more time at the pond-side trying to
persuade it to function than I actually spent on the water and sailing my boat!
It took 19 separate joystick movements (I counted 'em!) and countless on and off switchings of my Tx in the vague and unreliable process of trying to 'program' it. Not to mention the many confusing 'beeps' blurts' and 'blats' that issued forth from it's internals as I tried in vain to communicate with it.
Once I finally did get it 'programmed' as per the instructions, it would suddenly, for no particular reason, lose this hard-earned 'programming', and leave me drifting with no sheet response from the Tx whatsoever. Careful manipulation of the rudder in the prevailing wind got me in again some time later.
After another replacement by RMG for a 'faulty' winch...It happened again. Same thing.
I gave up in the end, and sold it to a club mate, who likes to 'program' things.
Sail winches in the past didn't need to be 'programmable before they worked properly, and they don't need to be so 'smart' now either. All that is required from a sail servo is that it has enough torque, speed and simple waterproofed reliability to make yer sails go in and out when told to do so. I want a simple, robust and reliable servo that is 'fit and forget', and turns 'on' ready to go, when I connect the battery...so if someone is bringing out a new sail winch that can do all these normal things, and do it cheaper than so-called 'intelligently-smart' expensive offerings that everybody seems to think is the best thing ever since sliced bread, - and that includes all the Italian 'clones' too - then I'm interested in having a look at it.
What's next I wonder...a 'programmable' tyre for your car? "Just because you can...doesn't mean you should" - Jeff Goldblum, quote from the film Jurassic Park .
VeloceHydro is offline Find More Posts by VeloceHydro
Old Mar 05, 2013, 12:37 PM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
+ 1
Dick L. is online now Find More Posts by Dick L.
Old Mar 06, 2013, 09:47 PM
bigpat is offline
Love RC Yachts!!!
Joined Aug 2012
Funny, but I believe the RMG winches are very basic to program. The latest F series can be done in under 20 seconds. It takes exactly 4 stick movements to do it. There can be all sorts of reasons why it wouldn't program. Rob checks each winch before it leaves his workshop...
I've seen dodgy receivers, crook servo leads, half flat batteries in the Tx, and in the boat, all contribute to the winch not programming. I've only ever sent 2 winches back for repair, both times after they got a lot of water in the boat.
I know some earlier models wouldn't talk to some 2.4 Ghz systems and Multiplex radios, but there were comprehensive instructions on the website for that too....
Anyhow, each to their own!!!!
Discussion IOM sail winch Barbera_Banker Sailboats 19 Feb 25, 2013 09:18 PM
Discussion Sail Winch Motor s_e_h10 GWS (Grand Wing Servo) 1 Feb 13, 2013 09:38 PM
Sold As NEW Probar W-2F Sail Winch (SOLD) luger007 Boats (FS/W) 1 Aug 18, 2009 05:49 PM
GWS sail winch servo robster94gt GWS (Grand Wing Servo) 0 Oct 29, 2003 06:12 AM
Question Double arm sail winch? DaveyDave Sailboats 2 Oct 07, 2003 01:09 PM
