Old Mar 02, 2013, 09:47 AM
JohnR. is offline
Find More Posts by JohnR.
Joined Mar 2013
Trimming Syma X1 quadcopter
Hello;
Just got a new Syma X1 quad-copter. I'm new to quad-copters in general. I believe I understand the trimming, but I'm wondering if I'm just not doing something right, or if I have a bad X1.
For those familiar with the X1, I have the TX in "mode 2", which I've read is equivalent to "mode 4" in the quad-copter world.
After allowing the gyro to self-calibrate and binding the TX, I apply throttle and the X1 immediately drifts directly to the left. This is indoors with no air currents. I use the "sideward fly fine-tuning" trim switch, and I can get it to the point where the X1 will either drift Very Slowly to the left or, if I adjust the trim switch the other way, Very Slowly to the right. In other words, I can't get it to stay put.
What does this mean? Bad copter, or is there some more complex trimming that I need to do?
Thanks in advance.
JohnR. is offline Find More Posts by JohnR.
Old Mar 02, 2013, 09:53 AM
JohnR. is offline
Joined Mar 2013
One other thing that I noticed just now. If, while turned off, I manually turn each blade with my finger one at a time, they all spin very freely except one, which definitely shows more resistance than the others.
Old Mar 02, 2013, 10:54 AM
Arr0wHead is offline
Find More Posts by Arr0wHead
United States, MA, Plymouth
Joined Jan 2013
When you bind, make sure you plug in the battery and then set it down on a LEVEL SURFACE. If you're at a slant, or holding it, the gyro will calibrate to something screwy and keep trying to return itself to that position.
In addition, what you noticed about the props could also be the issue. Check for any hair or anything binding.
Arr0wHead is offline Find More Posts by Arr0wHead
Old Mar 02, 2013, 11:50 AM
JohnR. is offline
Joined Mar 2013
Thanks for your reply. I was careful to have the copter level after plugging in the battery.
Nothing binding that I can see. I guess my next step would be to take apart and reassemble that prop's assembly, if that's possible. I'll look into that.
Old Mar 02, 2013, 12:05 PM
Joined Jan 2013
Maybe just try loosening the screw a quarter turn.
Old Mar 02, 2013, 01:10 PM
JohnR. is offline
Joined Mar 2013
Which screw are you referring to ... the one that holds the prop to the prop shaft? Isn't that just for holding the prop on, and you unscrew it to remove the prop?
From playing around with it, I'm getting the impression that the resistance is either within the motor, or between the motor gear and the prop shaft gear. Do you know if these things needs lubrication?
Thanks.
Old Mar 02, 2013, 01:19 PM
Joined Jan 2013
Sorry, I was figuring an over tightened prop could bind against the motor housing, but I just tried and it's not possible.
Old Mar 11, 2013, 06:33 AM
IanPellant is offline
Find More Posts by IanPellant
Australia, QLD, Townsville
Joined Feb 2013
Thanks.
You're probably on the right track. Tight motor or gears.
My Symas are all coax copters, but I did find that some of them when new were overly tight between motor pinion gear and main gear.
The X1 manual shows a pinion on the motor driving a gear on the bottom of the prop shaft. Many of the micro quads are direct drive - the props are on the motor shaft. The X1 is not. There is a chance that either the gears on the hard to hand turn motor are tight or the bearings on the prop shaft are tight.
My micro copter collection numbers 9 this week. (Another V911 is in the post). All of them have become smoother and quieter with use. And oil. I use sewing machine oil - it's very thin, penetrates, does not go gummy and is safe on plastics. As with any small machinery, these little copters do benefit by being "run in" a bit. Blasting off with a new copter on full power may burn out a tight motor or, perhaps, as in your quad, cause imbalances.
An aside: I bought an old model Syma S006 (non-Gyro). When new, it was prone to a lot of spinning until the gears on one motor bedded in and the beast balanced both motors and rotor speed... I found a few web forums where users were finding it "impossible" to stop the spin on an S006... they should have run the motors and gears in a bit before attempting full bore flying. (IMO)
Maybe, just maybe, if you use some oil on your tight motor and bench run it (at half speed) for a battery charge or two, that may bring that prop up to speed and the gyro will do a better job of balancing all four rotor speeds.
I'm considering buying an X1... but the Syma 2013 catalog (off their web site) shows an X3 quad which looks very interesting.
IanPellant is offline Find More Posts by IanPellant
Old Mar 11, 2013, 07:39 AM
JohnR. is offline
Joined Mar 2013
Thanks for your reply. I actually did run the X1 thru at least 2 battery charges at low speed, as I was testing it inside and blasting off at full power would have been bad for both my X1 and the ceiling. ;-) I'll try sewing machine oil and patience.
Old Mar 15, 2013, 10:28 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Mode 2 is mode two/ and mode 4 is different. Quad world most use mode 2.
X-1 I used stock TX no issues/ then bound to T9X and again no issues. Both needed nothing to fly righjt. Check your board to see if its mounted correct.
dankar04 is offline Find More Posts by dankar04
Old Mar 15, 2013, 11:56 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
A micro-quad is never going to just sit still in the air. There are always air currents that influence it, since it has little weight or mass. It's using very low cost electronics, too. The motor that doesn't move freely is definitely a concern. That's a sign that the brushes may be going bad. I would check to see that the gear turns easily in the housing, by pushing the gear down, so it disengages from the motor pinion.
Balr14 is offline Find More Posts by Balr14
Old Apr 24, 2013, 10:13 AM
lew308 is offline
Find More Posts by lew308
Joined Sep 2012
After having 4 new X1's I would just go ahead and change the motor.Take your time and figure everything out before you destroy anything .There are ways to do all you have to do.
lew308 is offline Find More Posts by lew308
Old Mar 24, 2014, 09:38 AM
DAVEHU is offline
Find More Posts by DAVEHU
Joined Mar 2014
syma x1 drift
JohnR. I got my x1 a few days ago and have the same problem: that is no matter what I do to the trim and no matter how careful I am connecting the battery while keeping the unit level, it still drifts to the left. I try some of the things mentioned here and if I come up with something, I'll be sure and post it.
DAVEHU is offline Find More Posts by DAVEHU
Old Feb 22, 2015, 07:58 AM
Tlc is offline
Tlc
Find More Posts by Tlc
Tlc
Joined Feb 2015
I have trouble understanding trimming on my syma11 hornet.i am new 74old and determined
Tom
Tlc is offline Find More Posts by Tlc
Old Feb 22, 2015, 02:21 PM
dankar04 is offline
Tucson, Az
Joined Feb 2007
X-1 just bind level and should fly fine. i never trimed mine. It smooth and fairly slow to a new flyer. Mine board died after 25 flights. Sits in its box as back up.
I was going to get a V929 board but not needed.
New Product xheli.com Syma X1 Mini Quadcopters Nitro_Nancy Mini Multirotors 11 Feb 15, 2013 11:09 PM
New Product xheli.com Syma X1 Mini Quadcopters Nitro_Nancy Mini Helis 2 Jan 17, 2013 03:08 PM
Discussion xheli.com Syma X1 Mini Quadcopters Nitro_Nancy XHeli 0 Jan 14, 2013 04:55 PM
