Old Mar 02, 2013, 08:58 AM
Tipgrind is offline
Find More Posts by Tipgrind
Tipgrind's Avatar
Joined Feb 2013
nano cpx
I have a nano cpx and durring hover the heli starts to have a slow wobble and continues to get worse with no input. i can stop it by conroling the sticks but when i go back to stationary hover it starts to oscilate again. It didnt do this when it was brand new. can someone tell me what causes this?
Tipgrind is offline Find More Posts by Tipgrind
Old Mar 02, 2013, 08:53 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
bent spindle?
helipilot23 is offline Find More Posts by helipilot23
Old Mar 03, 2013, 09:00 AM
Tipgrind is offline
Tipgrind's Avatar
Joined Feb 2013
I just replaced the feathering shaft and its still doing it. The main shaft is carbon fiber or plastic so i cant see that being bent.
Old Mar 03, 2013, 09:18 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Was it like that before? Have you checked the blade tracking?
Hajile is online now Find More Posts by Hajile
Old Mar 04, 2013, 08:28 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Could be split ?
dankar04 is online now Find More Posts by dankar04
Old Mar 04, 2013, 09:01 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Mine does that if the main shaft gear is too tight against the frame. Try backing it off a little, but not too much or it won't lift off.
matiac is offline Find More Posts by matiac
Old Mar 05, 2013, 01:58 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Have you changed your throttle curve recently? I put mine a little low on my mcpx and I was getting tail wag and crazy vibrations. Going into idle up the problems would go away.
Otherwise so far I hate my nano because I got bad tail wag out of the box. Horizon's working with me on it though. I think it's my main motor at this point.
When you replaced and tightened the spindle did you make sure to leave the grips free to move? Are the blades loose in the grips? Is your 3in1 screwed in all the way to the frame? Good battery?
There's a nano thread, http://www.rcgroups.com/forums/showthread.php?t=1719536 , you might want to try searching there for an answer too.
finguz is offline Find More Posts by finguz
Old Mar 07, 2013, 06:01 PM
Tipgrind is offline
Tipgrind's Avatar
Joined Feb 2013
thanks guys.. i think my feathering shaft was to tight. i loosened it up and it seems to be fine now.
Wanted mcp x for nano cpx cale10 Aircraft - Electric - Helis (FS/W) 2 Feb 05, 2013 09:34 PM
Sold For sale - Blade Nano CPX - Leaving the hobby!!! michael76 Aircraft - Electric - Helis (FS/W) 5 Jan 06, 2013 10:02 PM
Help! Nano CPx servo chatter therealroger Micro Helis 3 Jan 05, 2013 09:12 AM
Sold Blade Nano CPX jabull Aircraft - Electric - Helis (FS/W) 1 Jan 04, 2013 09:15 PM
