Old Mar 09, 2013, 07:43 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
And here is a weight report of the structures.
Rudder - 1.1 g
Fin - 0.7 g
H Stab - 2.1 g
Elevator - 2.9 g
Wing & Hatch - 24.5 g
Fuselage - 39.0 g
This totals to... 70.3 g (or 2 and a half-ish ounces).
The flying weight of my E-Flite Carbon Cub is 90 g. I still might be able to use a Park 180 size motor.
davidterrell80 is offline Find More Posts by davidterrell80
Old Mar 12, 2013, 11:28 PM
Joined Apr 2012
Tonight, I installed the receiver, 2 x servos (5g because I had them), a 10A ESC, a Park 180 2200Kv motor, and a 6030 prop. The front of the plane is quite large and masks some of the prop. I may have to make a streamlined nose piece, while I was hoping to make it look like a flat radiator, like the SE-5a.
The fuselage weight increased to 91.5 g... total now at 123.8 g.
A 2S 300 mAh battery runs about 15g... 140g
The carbon cub weighs in at 90g, so I probably need to up the motor and, perhaps, the ESC.
Old Mar 13, 2013, 12:45 AM
KnifeEdge51 is online now
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
My, that is a good bit of weight for that motor to haul around, based on the numbers I've seen for it. Perhaps a Park250 would better serve your purposes? Just a thought... But it looks very good, I must say!
KnifeEdge51 is online now Find More Posts by KnifeEdge51
Old Mar 13, 2013, 05:46 PM
Joined Apr 2012
Thanks for the kind words... I wasn't thinking. When I thought about my Carbon Cub's 90 g, I knew better. I've ordered a Power Up 250 plus from HeadsUp RC that should do nicely. I had larger motors but no one in the 250-300 range.
My spreadsheet tells me that for:
-- 40 mph Vmax
-- 2S system
-- 200 g weight
-- 90 W/lb (so 40 Watt system)
-- 1400 Kv at 75% efficiency
-- 7 A Cmotor
--10 A ESC
That I can swing a 7x4 prop with 6 A on the motor. So I will put an 8040 on it and bench test it in case the efficiency is better. At 80% efficiency the 8040 prop should give 20% more power at 7 A. At lower efficiency the current goes up.
Old Mar 15, 2013, 11:21 PM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
Looking great David!
conrad907 is offline Find More Posts by conrad907
Old Mar 19, 2013, 07:19 PM
Joined Apr 2012
Thanks, Conrad.
I finally got the motor I was waiting on. But, I don't have a prop adapter for a 2 mm shaft; and, the prop keeper I have won't hold the thrust I'm generating... fratzen ratzen, stinken winken...
Old Mar 19, 2013, 09:27 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
I remember pushrods like that!
Well, nearly like that...
She's looking good.
D
Dereck is offline Find More Posts by Dereck
Old Mar 21, 2013, 02:08 PM
Joined Apr 2012
I just got the motor rigged up with an EP 8040 and the 2S system draws 5 A and produces 35.5 Watts at WOT. Let me see if I have a 9040!
Edit: I put a 9047 on the motor and it puts out 44 Watts at 6.5 A... I need to adjust the math in my spreadsheet. Now to do some more covering...
Old Mar 21, 2013, 06:28 PM
Joined Apr 2012
Finished the basic covering...
To do list:
-- Wing struts and attachment fittings
-- Wing-fuselage attachment fittings
-- Cockpit
-- Pilot, which is also the after wing-fuselage attachment latch
-- Nose block
-- Vent in the electronics bay for cooling air exhaust
-- Landing gear
-- Control horns
-- Windshield
-- Exhaust pipe
-- Guns
-- Markings
Old Mar 21, 2013, 09:34 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
Looking great David...
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Mar 22, 2013, 05:25 AM
Joined Apr 2012
Thanks!
You may remember from my Blackburn Skua, that my finishing skills are still underdeveloped.
I'm working to do better, this time.
David
Old Mar 22, 2013, 09:04 PM
Joined Apr 2012
I built the wing-fuselage attach mechanism.
Weight so far is 180.4 grams.
Remaining weight will consist of:
-- landing gear
-- wheels
-- pilot
-- headrest
-- wing struts
-- nose block
-- control horns
Old Mar 22, 2013, 09:07 PM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
Originally Posted by davidterrell80 View Post
Thanks!
David
The Knight is a good plane to improve on with its simple design. Practice makes almost good enough, as I always say....
Old Mar 22, 2013, 09:52 PM
conrad907's Avatar
Joined Feb 2012
The covering looks good David! You are getting close to your maiden, very fast build! This plane looks like it should be a gentle flyer.
Conrad
Old Mar 23, 2013, 01:40 PM
dmbaerry is offline
Find More Posts by dmbaerry
dmbaerry's Avatar
United States, NC, Burlington
Joined May 2012
Looking Great David... will be following.. oh your covering is great.
dmbaerry is offline Find More Posts by dmbaerry
Build Log Blackburn Skua, FF to RC conversion of Earl Stahl design davidterrell80 Balsa Builders 128 Aug 09, 2014 02:06 PM
Sold 2 JR DS 188 Digital High Speed Servos MOC $40 gva1956 Aircraft - General - Radio Equipment (FS/W) 2 Feb 10, 2013 11:00 PM
Rave White Knight / Space Ship One foamflyer Foamies (Kits) 10 Aug 03, 2005 07:59 AM
Rave Scaled Composites White Knight / Space Ship One foamflyer Scale Kit/Scratch Built 4 Jun 04, 2004 12:44 AM
