Old Mar 01, 2013, 07:52 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Tired of paying $7 for a tiny can of Lexan spray paint? Try SEM!
We all know that Lexan requires special paint. This is because not much sticks to it, and when the body flexes, regular paint will crack and flake off. The problem is that Pactra and Tamiya PS Lexan paints are $7 for a tiny 3oz can of spray paint. I've found an alternative, it' SEM's Color Coat. It's made specifically for plastic, vinyls, and cloth. It's available in spray cans at your local auto body supply store for around $13 for a full 16oz can. It comes in lots of colors, nothing too fancy, but all the basics are covered. It also works great for backing other Lexan paints if you're using Tamiya or Pactra metallics. Most shops can also custom mix colors if you're got a spray gun or airbrush.
So, how well does it work? Well, I've been using it for recoloring car interiors for years, and I've used it on every RC body I've painted. It's incredibly durable, and it doesn't require scuffing the pastic or any other special prep of the Lexan. Just spray it on and go
Example 1, my Slash 4x4 Pro-line Baja Beetle
The spoiler on this body is particularly vulnerable. You can see in the pic that the spoiler is cracked and torn to bits, but the paint is still holding up great. The body it's self is painted with Pactra and backed with SEM black. You can see that the body is bashed, banged, cracked, torn, and has been repaired many times. The paint however is largely intact.
Example 2, my Backslash.
The black and yellow on this body are painted on the outside, SEM silver on the inside. This body is also bashed to heck, yet the SEM inside the body is still all there and in great shape.
Example 3, my Turnigy Monster Beetle.
Both yellow and black are SEM colors. This car is bouncy and tumbly, and spends as much time upside down as right side up. With one tiny exception, the paint is completely intact. Here's an example of the kind tumbling the body regularly goes through:
Bashing with a Turnigy Monster Beetle (5 min 39 sec)
In short, next time you need to paint a body, give SEM a try
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Mar 03, 2013, 08:52 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I prefer using faskolor with an airbrush, you can get a lot more usage from $5 in paint but you need an airbrush then.
wparsons is offline Find More Posts by wparsons
Old Mar 05, 2013, 05:26 PM
mummi is offline
Find More Posts by mummi
Iceland, Capital Region, Reykjavik
Joined May 2012
So... basically any paint mad for plastic could work?
mummi is offline Find More Posts by mummi
Old Mar 06, 2013, 10:56 AM
Evansville, WI
Joined Dec 2006
Not necessarily. Krylon Fusion for example is made specifically for plastics but will chip and flake off unless you sand/scuff the plastic first. Standard Testors and Tamiya TS model paint are made for plastics too, and it will flake off in no time. SEM can be sprayed on directly with no additional prep. Anything advertised as a vinyl paint should work, though SEM is the only one I've used.
Old Mar 06, 2013, 11:48 PM
SporadicIdiocy is offline
Find More Posts by SporadicIdiocy
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
Cool, Lordco sells them in B.C. Canada, I'll have to check them out when I get the chance.
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Old Aug 29, 2013, 02:18 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
More people using vinyl paints for their lexan bodies? If it's a durable as it seems, I think it's a better option than the regular lexan paints, which tend to seperate from the lexan over time.
SoloProFan is online now Find More Posts by SoloProFan
Old Oct 04, 2013, 07:28 AM
metoo is offline
Find More Posts by metoo
Joined May 2008
So rather than paying $28 for small paint cans to do a 4 dollar body and have the unused paint sitting in the cans for a couple of years, you can spend $52 and store much bigger cans for longer. I get what your saying tho, but you'd have to pretty busy with painting bodies to make !6oz cans worth while. I could see getting a can of black and a can of white as those are used the most, even if just to back another color.
My advice, get and airbrush (even a cheap Harbor Freight one) and use Faskolor. One tiny bottle goes a very long way, is water based, makes for a lighter weight body (because of the airbrush), and last a very very long time without getting all clumpy and inconsistent like spray paint. I have a couple bottles that are 10 years old...still good to go. I painted this Slash with my old paint (the white is Pactra)
metoo is offline Find More Posts by metoo
Old Nov 27, 2015, 01:40 AM
letsstart78 is online now
Find More Posts by letsstart78
Canada, BC, Vancouver
Joined Jul 2012
I think it's time to do some follow up : ) how's been holding up ?
letsstart78 is online now Find More Posts by letsstart78
Old Nov 27, 2015, 07:02 PM
Evansville, WI
Joined Dec 2006
Phenomenally well. The bodies are all beat and cracked to heck, the paint is still stuck just fine. If you haven't tried SEM Color Coat yet, I recommend you do. Basic colors are available in spray cans through Amazon, specialty colors and metallics can be mixed by any auto body supply store.
As a side note, I tried Duplicolor's Vinyl and Fabric spray paint, thinking it might be an easier to get SEM substitute. Wrong. While a bit more flexible than regular spray paint, it didn't stick worth a darn and was basically worthless.
Old Nov 27, 2015, 09:09 PM
Joined Jul 2012
Thanks a lot for your response. I will defiantly buy only 30 min away from me.
Discussion Painting problems using Tremclad spray paint ? riggerman Scale Boats 2 Jan 27, 2013 07:42 AM
Discussion Tiny video switcher on FPV vehicle so camera can change from front to bottom view jasper7821 FPV Talk 0 Jan 07, 2013 01:37 PM
Discussion Conductive Coating Spray Paint Altimat Multirotor Electronics 0 Jan 06, 2013 08:48 PM
Discussion K&H Spray Can Paints For Colour Matching Moldie Repairs AvB Australia 2 Feb 21, 2009 03:58 PM
Question Manually pressurized spray can for painting? iceburg47 Foamies (Scratchbuilt) 24 Apr 30, 2008 08:40 PM
