Old Mar 01, 2013, 05:06 PM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
Bell Cranks
I began 35 sized planes with metal bell cranks. Control feel was like dragging a chain across a rocky road, the lead outs sawed through the bell crank and when I followed Bark Klapinski's great advice and soldered brass bushings into the crank eyelets, it proved fatal to my modifed Magician when the acid that wasn't removed adequately, ate through the lead outs causing the Magician's disintegration. I lost control as the first lead out broke, at the top of the 5th or 6th loop, then the Magician went into a steep dive when the second lead out broke. Nice bird. Then I took Bart's advice again and started using Sig 3 inch nylon bellcranks. I bush the eyelets with brass thimbles. They feel like a Hurst Competetion Plus linkage on a primo Borg Warner T-10 transmission. They require 1 brief modification, don't rust, don't wear out, are virtually indestructable and are the single best improvement I ever made in building model airplanes. I realize that technology is 40 years old, but is there a better way? And remember, simplicity = genius
tigreflyer is offline Find More Posts by tigreflyer
Old Mar 02, 2013, 02:52 AM
greggles47 is offline
Find More Posts by greggles47
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Tigre,
Regardless of what the bell crank is made of, it's important that its fulcrum is bushed and that the leadouts where they attach to the bc are solid.
If you want flexible leadouts they need to be soldered to the solid. As you have found it's really important that anything you use as a solder flux is rinsed off the LO.
Greg
greggles47 is offline Find More Posts by greggles47
Old Mar 02, 2013, 07:31 AM
The Kiwi is offline
Find More Posts by The Kiwi
Old Timer
The Kiwi's Avatar
USA, TX, San Antonio
Joined Jun 2010
The copper "end loop" bushing has long been popular with phenolic and metal bellcranks. Two lengths of small diameter tubing -- about 1/16" size, are used at the ends of heavy C-D flexible cable leadouts. Pass the cable through the tubing, drill out the bellcrank holes, Put a small radius bend in the middle of each tube (use a quarter inch dowel as a mandrel), feed it into the B/C and wrap, then solder, the free end of the cable to the main part of the leadout.
I seldom used silver solder / Acid Flux on any joints I couldn't see easily, using resin core solder for internal connectors.
The Kiwi is offline Find More Posts by The Kiwi
Old Mar 02, 2013, 12:33 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
I use nylon covered cable fishing leader material for lead outs. With a plastic bellcrank, I cover the leader with the teflon tubing for thick CA. I have a set ,heavily flown for seven years, which shows absolutely no wear on the bellcrank or the CA tubing.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Mar 02, 2013, 07:29 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
I used solid 1/32nd piano wire folded over, sleeved through a brass tube and soldered.
I hope it lasts more than fifty flights.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Mar 02, 2013, 07:43 PM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Looks good John, the only addition I make to that is to run a 1/4" support from the spar to the TE to fully support the BC mount. A 1/16" rib doesn't provide enough support in a high stress situation.
Greg
Old Mar 02, 2013, 08:35 PM
JohnAV8R is offline
Joined Oct 2005
Thanks Greg. I'll add the brace.
John
Discussion pull-pull crossed: how calculate bell crank? sroge The Builders Workshop 11 Feb 05, 2013 08:01 PM
For Sale HD Tiller Bars, Bell Cranks and Differential Bell cranks-Price to sell unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Jul 09, 2011 07:46 PM
EBAY: Hirobo Shuttle Metal Aliron(Bell Crank)Lever mroy0404 Aircraft - Fuel - Helis (FS/W) 1 Oct 13, 2004 09:59 AM
warning elivator bell crank failure on nyx f3f charlieuk Slope 20 Sep 30, 2004 04:46 PM
Hornet Tail Gearbox Bell Crank Shaft (E025) Maarksc Electric Heli Talk 1 Jun 01, 2001 03:14 PM
