Well after some digging around I think the best option for me is to use one of the cloud based nesting providers. I’m going to try out a few and will post how I get on
. A bit more background - all I’m looking to do is nest the profiles on my standard Depron sheet size. As I don’t have access to a CNC laser or router, I will print the nested sheet on a wide format printer and then overlay on the Depron and cut by hand. 1st up is MyNesting - http://www.mynesting.com/ There is no upfront cost for the software. You install it on your PC, create your nest and only if you want to export the nest do you make a payment. You do this by buying credits online. Very easy to use but had problems with the dxf’s that I exported out from SW with bend lines. Once the bend lines were removed everything worked fine. I’m sure if I edited the dxf and put the bend lines on a different layer it would work file. I don’t particularly want to do this as, being lazy, it’s another process in the workflow… I would rather spend the time designing, building or flying. ![]() They give you one free credit when you first install the software which I used for this test project (pics). Another positive is that you could use the software to generate the nest on screen to give you an idea of the best utilisation of the material and then create the nest manually based on it. Even this would save a lot of time. |
| Thread Tools | |
| Discussion CAM software help(part nesting/duplication) | ssquillace | CAD/CAM | 2 | Feb 10, 2013 07:58 AM |
| Hornets nest - uHeli carrier | pwkpete | Micro Helis | 0 | Mar 09, 2004 10:19 PM |
| The nest big thing! D99+++ | sneu | High Performance | 17 | Jul 23, 2003 12:57 AM |
| Eagle in nest webcam | uncled | Aerial Photography | 0 | May 26, 2003 08:51 AM |
| Hornet's nest! | gbruce | Electric Ducted Fan Jet Talk | 46 | Dec 10, 2002 11:55 PM |
