Old Mar 01, 2013, 02:36 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
More CG Questions...
Anyone have the correct CG for the Goldberg Shoestring?
Or the Junior Nobler?
Thank you all in advance?
Ah Clem is offline Find More Posts by Ah Clem
Old Mar 01, 2013, 03:03 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
I have a Shoestring on the table right now with the original Goldberg plans. Here ya go, 2-3/8" to 2-3/4":
Description: CG
RknRusty is offline Find More Posts by RknRusty
Old Mar 01, 2013, 03:09 PM
BLACK HAWK MOD is offline
Find More Posts by BLACK HAWK MOD
Joined Aug 2009
On all control line models the cg is located in the first 1/3 of the wing. The closer to that point the more maneuverable the model becomes and the harder to fly. Crossing that point makes the plane to hard to control.
101
BLACK HAWK MOD is offline Find More Posts by BLACK HAWK MOD
Old Mar 01, 2013, 04:17 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
For older airplanes with relatively short tail moments, and small tail feathers, a good starting point is no more than 15% MAC back from the leading edge. On 1/2A airplanes, a little more forward is a good idea.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Mar 01, 2013, 06:02 PM
Ah Clem is offline
Ah Clem's Avatar
Joined Mar 2005
WOW!
Thank you all very much!
I don't know if this one is nose heavy, but I am willing to bet it is. Now I have the correct information to check the CG!
Old Mar 01, 2013, 08:05 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
I'm pushing max weight on my Shoestring, but I think I'm going to get it in just under the wire at about 29oz. All that's left is paint on the front end and mounting the LG and engine.
Description:
Old Mar 01, 2013, 10:09 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Not sure how close the Shoestring is to the Buster, but my Buster had 2.25 inches from the leading edge as the GC and she was tail heavy. Could not get it to groove. Was always searching up and down. Set it at about an inch and it flew very well.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Mar 02, 2013, 07:44 PM
Jim Kraft is offline
Find More Posts by Jim Kraft
Jim Kraft's Avatar
The middle of Kansas
Joined Jan 2005
1" back from the leading edge is a good starting point on most of these old designs without flaps. You can move it back a little at a time from that point until it starts to float on landing, and then move it back forward to suit you. Generally 10 to 15% of mean air cord like Jim T said is pretty close. Control line planes need to balance quite a bit forward from what R/C planes do.
Jim Kraft is offline Find More Posts by Jim Kraft
Old Mar 05, 2013, 02:39 PM
Traian is offline
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
The CG Dissertation.
The CG set should be set in relationship to your particular flying style and expertise level.
A forward CG will have the plane track very nice and it is very docile. This is a good CG for beginners who want to fly level, inverted, and do loops and of course it is excellent if you want to flip the plane over when you land.
Once you are bored of loops it is time to switch to a more rearward CG. At his new CG placement the model will want to turn faster and will start to corner a little better but you will sure feel the difference at the handle because now the plane is feistier. This is where an adjustable handle is very practical. Because the model becomes much more sensitive you need to tighten the spacing in the handle to cool off the plane and maintain the responsiveness of the control to match your feel (I am assuming you already set your handle for the safe forward CG). Perhaps you may want to add a little more sensitivity from the handle to be able to corner the plane. The plane should behave the way you want it to behave, not the other way around. This is where you my stay for a while till you get good feel for the plane and build up your cornering and maneuvering around the pattern skills etc. A light plane is very well served by this CG position.
Some of us go a bit farther than that and push the CG even farther back. Where is the max back position? Well if the model begins to hunt, (unstable in level flight, which means you constantly have to impute to have the model to fly level flight) then you went too far back and you need to back off of it and return the CG little more forward. This is where I like to have my plane set and it is my personal preference. The model will have the smallest corner in this position and because there is the least amount of deflection of controls and you maintain the maximum momentum (it does not slow down too much in the corner) which allows for a safe run speed to the next corner. But expect lighter line tension. In this position the model has maximum response and minimum deflection on controls. A heavy plane is best set this way.
There was one day when I flew my friendís plane and it was not cornering if my life depended on it so we added some tail weight to the model and towards the end of the session the model was behaving quite nicely. We had to close the handle spacing in conjunction with the CG back but it was behaving very well. We both left smiling and it was an eye opening experience for my friend. We only put a few flights (5-6) half fuel tank each to check for the feel and the model was transformed from a lazy dog to a snappy cricket.
As a side note as the CG moves also the lead outs need to follow suit. I cannot emphasize how important is to be able to tune your model.
Have fun experimenting with your CG
Traian is offline Find More Posts by Traian
Discussion Building a GLH II, CG question Dave Craig 1/2A Planes 13 Feb 25, 2013 05:27 PM
Discussion The question of CG in futura haimedrei Fuel Jet Talk 0 Jan 27, 2013 01:25 PM
Discussion The question of CG in futura haimedrei Electric Ducted Fan Jet Talk 0 Jan 27, 2013 01:08 PM
