Old Mar 05, 2013, 05:56 AM
v22chap is offline
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
Just goes to show .. a brick could hover if you can program a controller ,, matter of fact hover charlie looks a little like a brick
Good job Aaron I finally have my Wii board out trying to make a head tracking unit out of it for my A&P bird ... This old man has a lot of respect for what you guys do on these boards ,,, I am so lost ... as there is a ton of material to go thru just to get ready to setup the board
v22chap is offline Find More Posts by v22chap
Old Mar 05, 2013, 07:12 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Ain't nothing like the real thing.
MiniMollie Training Day - Part II (3 min 35 sec)
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 05, 2013, 07:13 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Here is another (very cool) bicopter that flies great with out fan cant.
I might throw together a test rig to isolate cant/precession to see what happens with fan cant only, no tilt....kind of like the vinyl record experiment.
Falcon UH-144 HALO RC model bicopter (2 min 24 sec)
leadfeather is offline Find More Posts by leadfeather
Old Mar 05, 2013, 07:18 AM
Joined Aug 2009
And the props can spin in the same direction, but it is of a different design and works under a different principle.
Twincpter [ Dualcopter ] Handicraft & KK2.0 V1.2 Vol.39 Test flight (6 min 52 sec)
Winging it >
Joined May 2006
http://youtu.be/GHoeGdqhdtU
Sweet! Very smooth flying; nice!!
Old Mar 05, 2013, 07:27 AM
Winging it >
Joined May 2006
Rimshot, how would you compare the flying qualities of your tilt only copter vs your tilt/cant design?
Old Mar 05, 2013, 07:35 AM
Joined Aug 2009
IMO, the bottom line is, if all that is desired is to fly, as stated, one can fly a brick or build paper airplanes. It just a matter of personal likes and dislikes. Subjectivity.
Old Mar 05, 2013, 08:00 AM
Joined Aug 2009
Why would someone build something like what is shown in the attached picture if all they wants to do is Fly?
Old Mar 05, 2013, 12:49 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Found a great link. Talks about some interesting stuff, all of which are relevant to the OAT bicopter.
A FEASIBILITY STUDY ON THE CONTROL OF A GENERIC AIR VEHICLE USING CONTROL MOMENT GYROS
ilektron is offline Find More Posts by ilektron
Old Mar 07, 2013, 09:27 PM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, FL, Milton
Joined Mar 2011
http://m.youtube.com/watch?v=V-DZXIj4RPk
this is great!
kicekilla is offline Find More Posts by kicekilla
Old Mar 08, 2013, 12:17 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by ilektron View Post
Found a great link. Talks about some interesting stuff, all of which are relevant to the OAT bicopter...
Very interesting read. Probably a good thing I don't understand a word of it or I most likely wouldn't even attempt the things I build
If you find something good in it and don't mind breaking it down, way down, into layman terms then I'm all ears.
As long as that brick is made of foam you are good to go. He's getting a nose cone and looks a little more like a torpedo to me now. We'll see what happens.
As for the Arduino learning curve. It's not too bad once you get past that first build. My suggestion is do the "load the blink sketch" tutorial first. That will tell you all about arduino and how to load up code. Then build a + config quadcopter since I think it's the easiest to keep orientation of. You can easily glue a vertical foam fin on it and such to help with orientation even more. Not as easy to do with an x config quad.
RCvertt is offline Find More Posts by RCvertt
Old Mar 08, 2013, 12:34 AM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Haha,
They took a simulated model of an F16, trimmed it so that it is neutrally stable in flight, and threw four CMGs (Control Moment Gyros or large spinning masses) in it. Then, they tried to control the aircraft using those gyros. When I have some time I'll dig through it more in depth.
Old Mar 08, 2013, 07:24 AM
Winging it >
Joined May 2006
Speaking of flying bricks.
Flight Assembled Architecture (1 min 48 sec)
Old Mar 09, 2013, 10:12 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
The beginning of quadcopter slave labor Not going to be fun when SkyNet takes over.
Charlie had some good tests in lots of wind today.
FoamyCharlie-InWind1 (0 min 59 sec)
Old Mar 10, 2013, 08:35 AM
Winging it >
Joined May 2006
Nice RCv!
Looks like the elevator has gyro input?
Discussion Bicopter pitch stability leadfeather Multirotor Talk 3 Aug 16, 2015 10:05 PM
Discussion Mounting position of flight controller versus stability... serrated Multirotor Electronics 1 Feb 18, 2013 03:01 AM
Discussion measurement arms bicopter ghiro11 Scratchbuilt Multirotors 1 Jan 14, 2013 08:30 PM
Sold FY30A new Aircraft stabilizer & cam stabilizer Tom.in.Maryland Aircraft - General - Radio Equipment (FS/W) 5 Jan 11, 2013 06:03 PM
WTT/FS....various speed400 stuff,fma RX,Speed controls for Brushless Controller kindjordan Aircraft - Electric - Airplanes (FS/W) 9 Jan 16, 2004 04:42 PM
