Old Mar 02, 2013, 09:34 AM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Originally Posted by Peter Seddon View Post
You presumably know of the work of Gary Gress? His website is but a shadow of its former self but I have the attached paper.
Peter
Really good stuff Peter. I had not seen this before. He confirms the gyroscopic control effect in his writing.
leadfeather is offline Find More Posts by leadfeather
Old Mar 02, 2013, 01:24 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Originally Posted by leadfeather View Post
http://m.youtube.com/watch?v=W3FS3D1rCos
(old video of man on personal heli thing)
That thing looks like a blast. Segway of the skies!
4) Conservation of angular momentum. Discussed in the first few posts.
Originally Posted by rimshotcopter View Post
I am ONLY Stating my opinion based upon my observations and personal experiences. With the Props that I've used on my builds, the gyroscopic effect is minimum and do not overcome the other flight dynamics. In a total or near vacuum, then gyroscopic effect is supreme. The mass and the speed of spinning object is very important but to add enough mass or RPMs is a very hard challenges. I have a number of videos to support my claims but I digress.
I agree with rimshotcopter, too. Just watch the video of the tilt rotor with the vinyl records on the motors again. Pitch and roll are not held. They wobble back and forth, but can't hold an angle because the string holding the craft + gravity creates a constant torque on pitched/rolled airframe, which the gyroscopic forces can't fully overcome.
ilektron is offline Find More Posts by ilektron
Old Mar 02, 2013, 02:08 PM
Winging it >
Joined May 2006
Do you have a link to this video please?
Old Mar 02, 2013, 02:16 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
3-axis Control in Space with Propellers? (/LPs?) (2 min 28 sec)
Old Mar 02, 2013, 02:30 PM
Winging it >
Joined May 2006
Thanks for the video.
I think we are saying the same thing. The conservation of angular momentum will be conserved and rotation continues unless the system is acted upon by an outside force...such as gravity/pendulum effect, flying surfaces etc.
In the vinyl record experiment, had the pivot point of the string been at the cg instead of above the cg (no outside force this way), I think the the copter would continue rotating when the flywheels are canted..
Old Mar 02, 2013, 02:36 PM
ilektron is offline
Will fly for food
ilektron's Avatar
Joined May 2011
Indeed
Old Mar 02, 2013, 05:51 PM
rc foam is offline
Find More Posts by rc foam
Joined Aug 2011
Great stuff. Thanks for discussing my issue of today - today. Just hovered my first bicopter but pitch seem really odd..-sometimes :/.
rc foam is offline Find More Posts by rc foam
Old Mar 02, 2013, 07:43 PM
Winging it >
Joined May 2006
Any photos of your copter? What did you observe that seemed odd?
For a bicopter VTOL I was thinking a nice control set up might be fans angled like Rimshotcopter's Mini-Mollie so that you get tilt and cant at the saem time, but then as the tilt continues for forward flight, the fans end up straight ahead. I'd like to figure a simpel way to do this so that only two sevos are used, one on each side to tilt the fan.
Old Mar 03, 2013, 03:17 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i'm not sure if it will help your pursuit, but i think you guys will like these videos:
Eric Laithwaite's lecture part 1 (14 min 45 sec)
Eric Laithwaite's lecture part 2 (14 min 41 sec)
Eric Laithwaite's lecture part 3 (14 min 38 sec)
Eric Laithwaites lecture part 4 (14 min 36 sec)
Eric Laithwaite's lecture part 5 (1 min 14 sec)
some really neat experiments
derk is offline Find More Posts by derk
Old Mar 03, 2013, 11:41 AM
Peter Seddon is offline
Find More Posts by Peter Seddon
Solihull, England
Joined Jun 2004
Search for OAT or scorpid 500 or scorpid 450 on www.DIYDrones.com. Gary Gress sometimes posts there as well.
Peter
Peter Seddon is offline Find More Posts by Peter Seddon
Old Mar 03, 2013, 12:53 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
This thread may be of some interest: http://www.rcgroups.com/forums/showthread.php?t=1238357
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 03, 2013, 05:09 PM
Lotus21 is offline
Find More Posts by Lotus21
Joined Apr 2009
Hey
Like Rim said, a key factor in this would be the mass of the propellers.
IMHO this in a flying machine would limit this phenomenon to only help with very small control adjustments?
Hence make this path, a very narrow oneto foollow
Lotus21 is offline Find More Posts by Lotus21
Old Mar 03, 2013, 11:11 PM
rc foam is offline
Joined Aug 2011
Yes i need to upload a little video to youtube today. My pitch was weird until i put fixed vertical vanes under the pivot points.. -Now its only difficult -im way behind you guys..
Old Mar 04, 2013, 07:47 AM
Joined Aug 2009
Gyroscopic Precession (3 min 49 sec)
Old Mar 05, 2013, 01:04 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
What? No Mini-Mollie?
This thread should be closed for such a blasphemous omission
Here are some picts of Osprino-V2, call sign Foamy-Charlie. The "canting" of the motors in Osprino-V1 was done by accident due to not compensating for dihedral in the wing and the wing bending under the load of the aircraft. Foamy-Charlie has a stiff wood front spar that doesn't bend when the aircraft leaves the ground. It's just a tricopter T frame without a rear motor.
The motors point straight up and straight forward. Nothing fancy here. Foamy-Charlie should hover regardless of prop rotation direction. Should work with two of the same direction props also.
You just have to play with the PIDs and stable mode a little. That's all. Osprino V1 and V2 don't work if "Stable" mode isn't on. That is the key my friends.
With the CG back, it hovers nose up. Stable mode keeps knocking the nose down though.
FoamyCharlie-FirstHover (0 min 52 sec)
RCvertt is offline Find More Posts by RCvertt
Discussion Bicopter pitch stability leadfeather Multirotor Talk 3 Aug 16, 2015 10:05 PM
Discussion Mounting position of flight controller versus stability... serrated Multirotor Electronics 1 Feb 18, 2013 03:01 AM
Discussion measurement arms bicopter ghiro11 Scratchbuilt Multirotors 1 Jan 14, 2013 08:30 PM
Sold FY30A new Aircraft stabilizer & cam stabilizer Tom.in.Maryland Aircraft - General - Radio Equipment (FS/W) 5 Jan 11, 2013 06:03 PM
WTT/FS....various speed400 stuff,fma RX,Speed controls for Brushless Controller kindjordan Aircraft - Electric - Airplanes (FS/W) 9 Jan 16, 2004 04:42 PM
