Mar 02, 2013, 07:45 PM
Bellingen NSW Australia
Joined Aug 2008
2 Balloons?
How do you use 2 balloons? One inside the other?
When I experimented (unsuccessfully) with balloons as an inflation bladder, I tied the end to a short length of vinyl tube with a rubber band twisted between multiple turns. Then, the short length was plugged into the next size up vinyl tubing which went to the air supply. I was only using aroun 15 psi of pressure.
I could not get then to last the duration without bursting, so went back to welded plastic inflation bladders, tied the same way as above - without leaks.
Reason: spelling
