Old Feb 28, 2013, 08:22 PM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Can I set up a speed controller for manual control?
My buddy has a full-size electric boat that is not working. The power set-up is very similar to our models, in that it has a speed control that takes 24VDC input, and converts it to a three-phase output to a 2200W brushless motor. The speed command to the ESC comes from a manual potentiometer. For testing purposes, would it be possible to modify one of our ESCs to operate from a potentiometer rather than from the throttle output of a receiver? I can then substitute the new ESC for the existing one in order to determine if the motor will run.
Chatenever is offline Find More Posts by Chatenever
Old Feb 28, 2013, 09:47 PM
Joined Nov 2007
Very easy, just get one of these:
http://www.ebay.com/itm/Mini-Servo-T...item1c2f0f6094
Any hobby store should have one.
Or you can make one:
http://www.sentex.ca/~mec1995/gadgets/servo3.htm
mjsas is offline Find More Posts by mjsas
Old Mar 01, 2013, 08:10 AM
Chatenever's Avatar
USA, CA, Oxnard
Joined Mar 2006
Thanks! That's a GREAT and simple idea!
Discussion best/cheap TX for control of an fpv set up Disp0sablehero Video Piloting (FPV/RPV) 18 Feb 04, 2013 12:26 AM
Discussion How do I set up a speed controller? RCWarbirds Power Systems 9 Jun 28, 2006 03:51 PM
Multiplex speed control - how to set up? Bandicoot Power Systems 2 Jan 07, 2005 02:57 PM
speed control set up twinsticks Micro Helis 2 Jul 18, 2004 10:40 AM
? Setting up my TMM 40e-3ph Speed Control neonbutterfly Power Systems 2 Feb 16, 2003 02:09 PM
