Old Mar 01, 2013, 05:43 PM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Guys,thanxs for all the help.I will keep you all updated on what I build.I apprciate all the imput
stefanP
KOMET 44 is offline Find More Posts by KOMET 44
Old Mar 01, 2013, 10:35 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Well, you guys got me started and today I ran across some high efficiency smaller particle furnace fans in the hardware store. It looks like I'm going to give up a 4 foot section of counter top and drawer cabinets below to incorporate a sanding station in my new model shop area.
More details to follow when I get to that stage. I'm just putting in a dust collection system so I can begin fabricating the kitchen cabinets that will be used in the model, wood and metal working areas.
BMatthews is offline Find More Posts by BMatthews
Old Mar 01, 2013, 10:57 PM
Riserflier is offline
Find More Posts by Riserflier
Joined Jun 2004
The speed controller is a good idea if using a furnace blower. Sometimes mine moves so much air (full speed) that it can be kind of a nuisance for small jobs (and the wind chill makes my fingers hurt).
FWIW: got my blower/motor from my commercial HVAC technician. Seems that there are only a few recycling places that take furnaces and all the contactors take their stuff to them. Basically, they back their trucks in the yard and kick the old furnaces off the back. Most of the time, the problem requiring their replacement is not the blower, but in the exchanger. However, many of them are 220v. My contractor replaced a smaller, 110v unit and saved the blower for me. Needless to say, his service contract was renewed at the end of its term.
Riserflier is offline Find More Posts by Riserflier
Old Mar 01, 2013, 10:58 PM
Joker 53150 is offline
Find More Posts by Joker 53150
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
Originally Posted by eflightray View Post
Does this thread give any ideas -
Cheap DIY water pre-filter for workshop dust
I just noticed this thread and you beat me to it - the water bucket method works well for my drywall sanding dust. When I get to the point where I'm creating enough balsa dust (when I give up my foam addiction) I'll probably build a collection system from 5-gallon buckets and a shop vac.
Joker 53150 is offline Find More Posts by Joker 53150
Old Mar 02, 2013, 12:07 AM
tdholm is offline
Find More Posts by tdholm
United States, OR, Aurora
Joined Jul 2008
sanding box
I have built the sanding box from a set of directions posted by MinnFlyer over on RCU forums. Great size at about 4 by 2.5 feet as I recall. My small 2.5 horsepower does not however provide enough suction to really get a good down draft flow. I can tell however that the dust in the air directly above the box is controlled and does not leave the immediate area nearly as much to float about the shop space. At some point I hope to get a larger vacuum to attach. The idea of a blower mechanism is intriguing as well.
What about the dust cyclone systems such as:
<http://www.oneida-air.com/category.asp?Id={CC6B6F2A-E3D7-4F18-A53C-B5C357DFE131}>
This seems like a reasonable way to reduce filter clogging with the fine dust we are generating.
Keep the ideas coming gentleman. We are on to something good here...
tdholm is offline Find More Posts by tdholm
Old Mar 02, 2013, 09:37 AM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Luckily, I'm a hoarder,and I have a furnace 'squirrel cage' blower sitting around. I use it for cooling the dog in the summer,when she's outside in the sun.
Any way, I plugged it in,and dropped a hand full of saw dust in it's intake.Holy Cow !
It pulls so much,and blows it so far.
Are we thinking of putting a furnace air filter in the box, or just blowing the sanding dust outside through the fan?
I bolted it tight against the wall,and it sets up a 'harmonics', like a poorly adjusted microphone.....it's obvious why they're iso-mounted in a furnace.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Mar 02, 2013, 10:15 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
You set them up to draw the dust through a furnace filter or 2
invertmast is offline Find More Posts by invertmast
Old Mar 02, 2013, 12:07 PM
Joined Jun 2004
If the filters are placed so that the motor is on the "clean side" of the air flow, then the motor should last longer, don't you think? If there are no filters and the motor is in the flow of dirty air, then it's only a matter of time before the dust takes its toll and the motor or bearings/bushings go bad.
I maximized the surface area of the filters because they get really clogged up very fast. Smaller filter surface area means lower air flow and more cleaning. My table is 30" x 72". Originally, I used four, 14" x 20" x 1" pleated furnace filters. Later, I added two layers of open foam filter media (Graingers item # 6U592) that are 1/4" x 30" x 72", and I removed two of the furnace filters. The foam stuff is convenient because it traps the big chunks of wood and a lot of the smaller stuff and prolongs the clean up interval. And when it is time for clean up, I lay the foam on the driveway and hose it down.
Old Mar 02, 2013, 01:57 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
tdholm, the cyclone style cone filters are used to separate the chunks from the dust. The fine dust stays in the air and exits the cyclone outlet. The fine stuff either has to be filtered out with a dry or possibly wet filter or sent outside. To properly filter out fine balsa or possibly dust from sanding primer coats you want to be using a filter which is able to filter out down to 1 micro dust.
A cyclone separator is a good thing for classic wood working tools but we modelers simply don't make the sort of chips or shavings that a wood working shop produces. So a cyclone separator isn't of any worth to us.
The issue with venting the dust to the outside is that in the winter you're dumping a LOT of heating dollars into the Great Outdoors. So a filter system which keeps the warm air we paid for inside seems like a better option even if it means we need to buy new ones regularly.
Really though I expect that with knocking out the excess a few times that our $10 filter set should be fine for a good solid year unless you hook up a power sander to the system.
And obviously we want to set the fan up so it's moving the filtered air to avoid clogging it up with dust. Although with a direct to the outdoors fan this isn't a big deal.
Old Mar 02, 2013, 02:38 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
What Bruce said!
Originally Posted by AndyKunz View Post
I have a Craftsman dust collector. Simply sanding in front of the end bell is sufficient for reducing the free dust to almost nothing.
This is the unit I have (the discontinued one in the picture).
http://www.sears.com/search=Craftsma..._prod=40022428
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Mar 03, 2013, 01:38 PM
mhodgson is offline
Find More Posts by mhodgson
mhodgson's Avatar
UK, Coventry
Joined Aug 2005
Here is an article from rc-universe. A little smaller than you're thinking perhaps but should give you a start.
mhodgson is offline Find More Posts by mhodgson
Old Mar 03, 2013, 08:06 PM
spacefanmick is offline
Find More Posts by spacefanmick
Spacefanmick
United States, OK, Broken Arrow
Joined Mar 2013
A few years back I took a 3M hand sanding block(the kind with they two halves and hollow inside) I modified a small flexible attachment to the top that i hooked a vacuum hose too.Then drilled small holes down each side near the bottom to suck the dust up. It worked good. Sometimes is a bit awkward. Due to the hose being attached to it. But it worked good for early rough sanding. I sent it off to my mom, who knew a guy who was looking at a patent for me. But never got it back. But it did work well.
spacefanmick is offline Find More Posts by spacefanmick
Old Mar 04, 2013, 12:32 PM
MyronW is offline
Find More Posts by MyronW
Stumpy6Guns
United States, CA, Valley Center
Joined Feb 2013
Bill Pentz is the internet dust control expert. His cyclone design removes an incredible percentage of super-fine dust.
http://clearvuecyclones.com has licensed his design and sells a mini cyclone that goes in front of your shop vac. They also sell large systems.
I have both, and my shop does not have a film of dust on everything, even though I do a lot of woodworking.
MyronW is offline Find More Posts by MyronW
Old Mar 04, 2013, 05:33 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Myron, the woodworking side of me started drooling at the sight of your setup. It got worse when I looked up the web site....
That's one slick system. And the control of dust down to .5micron is nothing short of amazing. They truly have done their homework to optimize the cyclone separator design to let it work as well as you found.
But you have to admit that the price, not to mention the size, will put off all but the most ardent model builders. That and the obvious requirement for a 220v dryer rated power plug to handle the 5hp motor.
Question best glue for depron when I need to sand it down? jet-ster The Builders Workshop 2 Jan 16, 2007 03:32 PM
Discussion Pusher jet that you sand down? thor4944 Pusher Prop Jet Models 8 Oct 12, 2006 08:28 AM
turbulence or big down draft? Arbo Slope 18 Sep 15, 2004 05:03 PM
Question Plane eating down draft Stocker Hand Launch 18 May 03, 2004 09:36 PM
