Old Feb 28, 2013, 04:37 PM
superinstaller is offline
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
How can I lower voltage from 4cell to 3cell
I'm building a quad copter and will be running it on 4cell lipo (because I already have them). And plan to add 12vdc led strips on all four arms. Is there an easy way to build a micro step down xformer thats small and light. I'm sure the draw will be very low like 500 mah. I could test them w my multimeter I guess
superinstaller is offline Find More Posts by superinstaller
Old Feb 28, 2013, 04:58 PM
viperidae is offline
Find More Posts by viperidae
New Zealand, Wellington, Porirua
Joined Jan 2013
http://www.fairchildsemi.com/pf/LM/LM7812.html
viperidae is offline Find More Posts by viperidae
Old Feb 28, 2013, 05:19 PM
Joined May 2006
Will this work? These guys have good prices! How do I wire these ??
http://www.westfloridacomponents.com/T278PD/view.html
Old Feb 28, 2013, 05:28 PM
Joined Jan 2013
Page 22 of the datasheet has the typical schematic.
http://www.fairchildsemi.com/ds/LM/LM7812.pdf
Old Feb 28, 2013, 06:09 PM
Smash McCrash is offline
Find More Posts by Smash McCrash
89" Kool Aid drinker.
Smash McCrash's Avatar
United States, CA, Ventura
Joined Dec 2001
I think you are overlooking the easiest way... Power it off of the balance leads at the third cell connection...
Smash McCrash is offline Find More Posts by Smash McCrash
Old Feb 28, 2013, 06:41 PM
Joined May 2006
I thought of that I want less work and more flying/crashing
Old Mar 01, 2013, 06:54 AM
spog is offline
Find More Posts by spog
Joined Mar 2006
Be aware that this will cause an imbalance in the pack cells.
spog is offline Find More Posts by spog
Old Mar 01, 2013, 09:25 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
http://dx.com/p/m1201-dc-3-40v-to-1-...or-blue-177634
Cheap, better in many ways. Still reg you linked too and few other parts would get job done would be about same money (well maybe not)
SadSack is offline Find More Posts by SadSack
Joined Dec 2001
Agreed, but the imbalance would be minor. I have a plane with a lot of LEDs on it and it still only draws about 1 amp. Small in comparison to the power needed to fly a plane, let alone a quad. Balance charging will correct the imbalance easily.
Old Mar 03, 2013, 07:59 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
You cannot determine whether the imbalance would be minor or not as the imbalance would depend on the current draw of the LEDs and the time they were on.
Ohmic is offline Find More Posts by Ohmic
Old Mar 03, 2013, 02:08 PM
Joined Jan 2013
If you want to power anything off only a few cells, you'll want a lipo alarm that monitors every cell. If your lipo alarm (or esc capability) only monitors the total voltage of the pack, you'll risk destroying some of the cells in your battery.
Old Mar 04, 2013, 05:13 PM
Joined May 2006
My goal is to make a regulator (or buy) that is permanent and needs no extra pluging and unplugging, I'm always up for a new trick and cheap is that much better!
Old Mar 04, 2013, 05:36 PM
SadSack is offline
Joined Aug 2008
http://dx.com/p/dc-4-75-24v-to-dc-0-...le-blue-151065 cheap simple small...
http://dx.com/s/Step%2bDown.html?sort=Price
Old Mar 04, 2013, 05:45 PM
Joined May 2006
Nice find, I will try find one in country. Tks for the help.
Old Mar 04, 2013, 06:18 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
For reducing the current for an LED when the source voltage is higher than the operating voltage of the LED, just use a resistor.
According to the calculator http://led.linear1.org/1led.wiz
You would want 8.2ohm at just over 2W. Radio Shack has a 3W 10ohm resistor (a $1.89) part# 55050389. Should work fine, actual resistance is not all that critical, I would tend to err on the high side.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Discussion how well do small 4 strokes pull fuel from a lower tank? jeff262 Engines 13 Jan 28, 2013 06:39 PM
Question 3cell vs 4cell battery twinastir05 Beginner Training Area (Aircraft-Electric) 10 Jan 28, 2009 10:23 AM
For Sale TP 1320 4cell and 2 PQ600 3cell jymz Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 05, 2008 08:55 PM
Discussion Can I make a 4cell lipo from two -2 cell packs? brian.c Batteries and Chargers 12 Aug 03, 2008 12:52 AM
Discussion Thunderbird 18 detects 3cell as 4cell jwegman Castle Creations 18 Feb 09, 2008 01:23 PM
