Old Feb 28, 2013, 12:47 PM
P31 is offline
P31
Find More Posts by P31
P31
United States, WA, Spanaway
Joined Dec 2011
Colin Archer
HI evrybody. I'm kit bashing a Colin Archer, and I'm thinking of changing to a single mast with jib I guess called a marconi rig. Has anyone done this that might give me some pointers. the picture is the way I'm thinking of going,Thanks
Gary
P31 is offline Find More Posts by P31
Old Feb 28, 2013, 08:31 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
You should do a google search on William Atkin- his design "Eric" is a single masted Colin Archer type- though not a "marconi" sloop (it is a gaff rigged cutter) it may give you some ideas to look at- other "Colin Archer" types to look at might be the Westsail 32 and various Perry designs like the "Baba"...
Aerominded is offline Find More Posts by Aerominded
Old Feb 28, 2013, 09:14 PM
P31 is offline
P31
P31
Joined Dec 2011
Thanks my friend I will look at that.
Gary
Old Feb 28, 2013, 09:45 PM
Joined Feb 2004
You're welcome! you'll have a neat boat when done!
Old Feb 28, 2013, 10:09 PM
herrmill is offline
Find More Posts by herrmill
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
Yes, that will be a pretty boat. Gaff-rigged cutter would be the way to go.
If you aren't already familiar with Ivor Bittle's website, take look under his Thames barge link for some ideas & inspiration on how best to do your rig.
http://www.ivorbittle.co.uk
herrmill is offline Find More Posts by herrmill
Old Feb 28, 2013, 11:55 PM
P31 is offline
P31
P31
Joined Dec 2011
Thats a neat site, i'll be reading that one.
Old Feb 28, 2013, 11:59 PM
P31 is offline
P31
P31
Joined Dec 2011
I think I will stick with the Gaff-Rig without the Spanker, just the main and jib's or fore sails. I'll post some Pic's tonight as where I am now.
Gary
Old Mar 01, 2013, 02:53 AM
P31 is offline
P31
P31
Joined Dec 2011
Here are some pic's of where I am right now. I will start the planking tomarrow.
Gary
Old Mar 01, 2013, 11:57 AM
Joined Feb 2004
Looking great!
Old Mar 01, 2013, 12:00 PM
Joined Feb 2004
Quick question, do you have a combing around the deck opening that the cabin top fits on to?
Old Mar 01, 2013, 12:24 PM
P31 is offline
P31
P31
Joined Dec 2011
Yes it will, thats just the ruff cut , and thanks for your input, if anyone see's I,m doing something that maybe I should go a differant way, shout it out, sail is new to me. I am a scale boat builder and have several on the shelf.
Gary
Old Mar 01, 2013, 12:34 PM
Joined Feb 2004
Good to hear! I figured you were going to add it but just wanted to check!
want to keep the inside dry in "big seas" and/or when the rail goes down!
Old Mar 05, 2013, 02:18 PM
P31 is offline
P31
P31
Joined Dec 2011
I am trying to figure out how to manage the two front stay sails on the one servo. Can't seem to find any instructions on how to rig controls for sail boats. here is a drawing of what I'm talking about. Is there any site showing methode's of doing this.
Gary
Old Mar 05, 2013, 04:29 PM
lucc is offline
Find More Posts by lucc
belgium,limburg
Joined Sep 2009
Ive see ,you got the same problem as me.
I'm also seeking a solution for this problem.
lucc is offline Find More Posts by lucc
Old Mar 05, 2013, 04:33 PM
lucc is offline
belgium,limburg
Joined Sep 2009
this is how somebody else dit it.
The loop is on the deck not in the hull
Originally Posted by wim1951 View Post
Hallo Luc, hier wat plaatjes
Roerservo en motor
Winch fok en kluiver met spaninrichting tbv omloop
Vaartregelaar met zekeringen
Accu bak met beugel om accu te zeevasten(onder de accu uitneembare loodballast).
Extra spant achter de mast gemaakt, voor de mast zit ook een spant.
Omloop met fokkeschoot en kluiverschoot (SB)
Omloop tbv fokke en kluiverschoot komt aan dek(plastic kapjes om bolders tbv vrijloop grootschoot tijdens zeilen
Nagelbank met verlengde voorpoten tbv vrijloop fokke schoot
Grootschoot komt in de stuurkuip naar buiten.
Dubbelschijfs blok tbv omloop fok en kluiver.
Zijwanten bij bovenste jufferblokken met haakjes tbv transport
Grootschoot doorvoorpijpje naar dek
Grootschoot lier.(de schoot zit in de e-buis zodat hij niet door de boot kan slingeren)
Detail fokke en kluiver schoot met meeneemblokje aan omloopdraad.
Nagelbank vast aan mast met messing pootjes in mast.
Dit is makkelijk want de zeilen blijven gehesen aan de mast tijdens transport.
Voorpoten van nagelbank verlengd tbv fokkeschoot geleiding
Bediening roer met bowdenkabel (alleen aan stuurboord)
Omloop fok en kluiver schoot over dek (dunne draadje tussen mastgat en koekoek voordek)
Ook is hier te zien dat de railingscepters tbv transport uitgenomen kunnen worden.
Schema grootzeil bediening
De werkgebieden van de lieren zijn instelbaar op de zender
Alles wat in de boot zit is dusdanig gemaakt dat alles door het grote luik uit te nemen is.
Voorlopig heb je wat om uit te zoeken ,veel succes.
Groet Wim.
For Sale Colin Archer fpvbasher Boats (FS/W) 6 Mar 04, 2013 08:35 PM
Found Colin Archer P31 Boats (FS/W) 1 Feb 01, 2013 09:44 AM
Off Site COLIN ARCHER on ebay vett Boats (FS/W) 3 Jan 10, 2007 03:57 PM
Wanted sails for colin archer vett Boats (FS/W) 0 Jan 01, 2007 08:04 AM
Yippee! for sale Colin Archer chioce pick one of two vett Boats (FS/W) 0 Dec 06, 2004 01:05 PM
