Old Feb 28, 2013, 11:27 AM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
The E-Pulsar Owners Thread
At a suggestion in the 3.2 Pulsar thread, here's the place to put all things E-Pulsar.
Any model,any size,anything related to this soaring machine including builds,flying,radio setups, tricks or tips, etc.
I'll kick it off with a couple pics
Leadchucker is offline Find More Posts by Leadchucker
Old Feb 28, 2013, 11:58 AM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Great idea! Subscribed.
Question: Esprit sell a Control Horn Brass Surface set. I bought some for my 3.6. Now...when I was learning to build (when we used to do that) I was always told to keep the pivot point over the hinge line. However, with these, the pivot point is about 1/4" behind the hinge. I do not fully understand the mechanics of why this would be a bad thing, but would love some input before I go ahead and use them. Here is a link to them so you can see what I mean.
http://www.espritmodel.com/control-h...ets-m3-10.aspx
This link also shows one attached on a Pulsar wing.
Your thoughts are most welcome.
Thanks.
Preston
jaizon is offline Find More Posts by jaizon
Old Feb 28, 2013, 01:59 PM
AMA7224 LSF1832
Joined Sep 2008
I should have mentioned but figured it goes without saying, prospective pilot/owners are of course welcome too. Any and all Pulsar vendors could add input and it too would be very welcome. Speaking of vendors, here's how some of the parts are made by Vladimir's Models from Esprit's site, I don't thing ZB and Miss Lucuy will mind.
http://www.espritmodel.com/explanati...echnology.aspx
Old Feb 28, 2013, 06:24 PM
P Farley is offline
Find More Posts by P Farley
P Farley's Avatar
United States, WA, Spokane
Joined Aug 2006
Subscribed! Looking forward to various Pulsar flight reports this Summer.
P Farley is offline Find More Posts by P Farley
Old Mar 01, 2013, 01:07 PM
P Farley is offline
P Farley's Avatar
Joined Aug 2006
Arming
I'm thinking of installing a clean small arming plug on my 3.2. It would be nice to arm/disable it quickly at the field without having to remove the nose each time in between flights.
Anybody have one on any size Pulsar?
Old Mar 01, 2013, 02:06 PM
bonefisher is offline
Find More Posts by bonefisher
United States, UT, Park City
Joined Sep 2007
Wow... how timely... just posted to the other Pulsar 2E Build thread the below.... and then saw this... Sorry for a double... truly appreciate any help!
____
Hello all....
After following this thread for some time I have taken the leap and ordered a Pulsar 2E....
One of my first questions is I noticed the flap linkage is ON TOP of the wing... has anyone tried to put it underneath by cutting out the brace and epoxying it allowing servo to reside underneath?
Thanks for all the information on this site!
bonefisher is offline Find More Posts by bonefisher
Old Mar 01, 2013, 08:52 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
____
Hello all....
My 3.6 Pro comes with the openings on the bottom. I guess they feel that will work.
Also, my Jeti DC-16 comes with a throttle lock on the main screen and they are coming out with a locking switch as well, but I do like the CC idea.
Old Mar 01, 2013, 09:37 PM
leaktech is offline
Find More Posts by leaktech
Balsa + glue + bluesky= fun
leaktech's Avatar
Phoenix AZ USA
Joined Jan 2009
New E 3.6 REF
Just got a 3.6 two days ago. I'm working on fitting a MVVS 5.6 960 into the pod.
Wish I had spent the extra for the recommended Neu$$$ inrunner. Anyway it's a tight fit. Added 3/16" ply behind the firewall after sanding the band of epoxy behind the firewall with a flap sanding tool on the dremmel. Saw this idea somewhere on the forums, drop the sander tool in the fuse with the shaft hanging out and hook it up the the dremmel and sand the epoxy off. The sanding tool is pretty aggressive so be careful if you try it and remove often to check progress. Would be a shame to sand through. Holding a torch at the firewall while looking in the canopy hole helps to see progress.
The 38mm spinner is a good fit on the pod. Had a small problem getting one of the CF joiners out of it's tip panel. Turns out it had a little dab of glue on it. I used a #1 Jorgensen clamp to grab it tight and wiggled for a half hour before the glue finally cracked and it slipped out. You can see the leftover glue in the image. I needed to work the joiners a little so they would slip in and out without straining. Just like every one else, very impressed with the quality.
James
leaktech is offline Find More Posts by leaktech
Old Mar 02, 2013, 10:10 AM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
James
Nice work on the motor mounting. Looks good.
Did you weigh your airframe, empty? Mine came in at 34.5 oz.
Preston
Old Mar 02, 2013, 04:19 PM
Petem is offline
Find More Posts by Petem
If it flies - I want one!
Petem's Avatar
Australia, VIC, Werribee
Joined Jul 2008
Motor, weight, joiners
My 3.2 Pro came out at 1560gm ready to go - not sure what that works out to in vintage units.
Motor is MVVS 4.6/840 Sport and I had the same difficulties getting it fully up the nose - sanding flap wheel worked well to remove the splooge to the point where a 3mm spacer could keep the motor in place. Fitted three spaced balsa wedges to locate and firm the rear of the motor as well.
I love the fixed outside case and rear connectors on the MVVS - no wires to sneak around a rotating barrel. One downside of the heavier motor is that the battery has to go right back under the fuselage 'roof' aft of the cockpit opening - tricky to mount and get in and out for battery change.
It never occurred to me that the wingtip joiners should come out - I have simply left them where they were when I received the kit.
Test flew mine last weekend on an undersized prop (12x6.5, only draws around 26A) and it still climbed beautifully - estimate well over 200m in 30 sec. The glide is a floating dream! Played with some small thermals, but basically just worked on getting the trim right. Two flights totalling 45 minutes used around half of the 2200mAh battery (around 8 climbs, from memory). I have no competition ambitions, just enjoy chasing thermals.
I need more practice and some trimming to get the descent under brakes nice and smooth, but overall a lovely aircraft and big grin!
Cheers,
PeteM
I need practice
Petem is offline Find More Posts by Petem
Old Mar 02, 2013, 06:14 PM
AMA7224 LSF1832
Joined Sep 2008
Originally Posted by Petem View Post
My 3.2 Pro came out at 1560gm ready to go - not sure what that works out to in vintage units...........
55oz. Here's an easy to use calculator for weight conversions:
http://www.worldwidemetric.com/measurements.html
This is the second bird with fit troubles using the sport motor I've read. I just fitted mine up the other day it was spot on with no splooge interferance using the regular 4.6/840 sailplane motor. I too like the MVVS idea wit the plugs built into to the motor case. This is the 4th MVVS I have and they all run great.
My 3.6 RES should be done this week with test flights at the will and whim of the weather gods.
Old Mar 02, 2013, 06:43 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
That's great. Still waiting on my Neu motor.
Let us know how it goes! Video if you can.
And work on getting to the Polecat. You really don't want to miss that.
Old Mar 02, 2013, 08:38 PM
Petem is offline
Petem's Avatar
Joined Jul 2008
Thank you!
Great conversion page, Leadchucker! I'll be able to convert my climb and descent rates into Furlongs per Fortnight!
Cheers,
Pete
Old Mar 03, 2013, 01:08 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I need practice
Hmmm, this came as a bit of surprise for me, I expected much lighter...
Don't take it wrong, I don't intend to complain, but to clarify myself what could bring different a Pulsar for me, compared with my BoT, at close weight and size. A large hole in the wallet for sure, but I must justify it to my wife, other than great look.
Will the airfoil alone change the way how she flies so dramatical?
renatoa is online now Find More Posts by renatoa
Old Mar 03, 2013, 05:19 AM
Petem is offline
Petem's Avatar
Joined Jul 2008
Light or heavy?
Renatoa,
Your point of view is interesting - I was surprised the other way, as the Pulsar is replacing my seven-year old Optima 100 (2.5m, 1660gm) so the weight of the larger sailplane is actually less. Wing loading around 7.4 oz/sq ft (there I go with units again!) or 22 gm/sq dm for Pulsar, vs 11 or so oz/sq ft or 33 gm/sq dm for the smaller Optima.
Our area is fairly windy, so the lighter wing loading may actually be a disadvantage much of the time.
The full house controls with crow braking and camber, vs rudder/elevator and simple spoilers were attractions for me, but mostly just the lure of modern technology and elegance. On performance grounds (I fly for fun only) you could not justify moving from the lovely Bird of Time, which has similar span and a nice, thin low camber section. I suspect camber is a minor advantage at best, and controllability with good dihedral and rudder is certainly good enough.
I guess an aircraft either grabs you or does not?
Fly and enjoy!
PeteM
Discussion Official FMS 1700MM Warbird Owners Thread Aros.MotionRC Electric Warbirds 271 Oct 03, 2015 12:35 AM
Discussion The Gun Owners Thread -- No politics!! bdshort Life, The Universe, and Politics 86 Mar 11, 2013 11:17 AM
Wanted Bingo or Pulsar 2.5 E Chuchuf Aircraft - Sailplanes (FS/W) 0 Feb 07, 2013 05:09 AM
Sold Pulsar 3.2 R.E.S. bafbob Aircraft - Sailplanes (FS/W) 0 Jan 30, 2013 03:52 PM
Discussion Hyperion Sniper X II Owners Thread wolfewinde 3D Foamies 2 Jan 17, 2013 04:47 PM
