120mm, 11 Blade Alloy EDF 700kv
Introducing the Dr. Mad Thrust high performance EDF series. The Dr. has been hard at work to bring you MAD power EDF systems with excellent quality, high performance and at a price that will leave some cash in your pocket.
Dr. Mad Thrust 120mm 11 Blade Alloy EDF 700kv - 7000watt (12s)
The Dr. Mad Thrust EDF series are pre-assembled and dynamically balanced making them simple and easy to fit, no unit assembly is required. In addition to high power, these fans have excellent cooling and run so smoothly, the sound is amazing, there is also no housing distortion unlike plastic fans. This top quality EDF unit is the ideal way to transform your jet into a speeding missile!
Dr. Mad Thrust EDF series - just the right prescription for your model!
Features:
  • Pre-assembled
  • Factory dynamically balanced
  • High power with superior cooling
  • High quality construction
  • Fully serviceable
  • Fast to fit
  • No housing distortion
Specs:
  • EDF Inner Diameter: 120mm
  • Outer Diameter: 125mm
  • Construction: Alloy
  • Weight: 1008g (complete unit with 4mm connectors)
  • Max RPM: 35,000
  • Motor Type: 4035 4 Pole 700kv brushless outrunner
  • Max Power: 7000w
  • Continuous Power: 6500w
  • Max Voltage: 44.4v (12S)
  • Max Amps: 140A
  • Max Thrust: 7.5kg
HobbyKing Daily - Dr Mad Thrust EDF Unit (1 min 8 sec)
LEARN MORE HERE
JOIN THE CONVERSATION
Old Feb 28, 2013, 11:35 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
There already is a thread started on this.
http://www.rcgroups.com/forums/showthread.php?t=1840163
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
???? Just for advertising sake? this ought to be in the "vendor" or product announcement forums
A couple of days late to the party ; there is already a discussion here:
Mike Warren is offline Find More Posts by Mike Warren
Last edited by Mike Warren; Feb 28, 2013 at 11:37 AM. Reason: Advertising....sheesh!
Old Feb 28, 2013, 11:42 AM
jefffassbinder is online now
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Post a Video
I'd like to see this fan spin on 45-60C 12s packs for a couple of minutes to be sure of the precision of this fine fan. They should make a video and share it so we can see and hear the sound.
Looks great. Jim put that sucker on a profile with some ducting and huck that sucker.
jefffassbinder is online now Find More Posts by jefffassbinder
Old Feb 28, 2013, 11:45 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
lol that is an image of the 50mm 10blade
D_FAST is offline Find More Posts by D_FAST
Old Feb 28, 2013, 11:51 AM
Joined Jan 2011
Motor
Yes I just saw that and then I realized the motor shaft is sticking out about a 1/4" which is great for chaffing your wires. Someone needs to get a dremel and some tape. One of the best tools ever created Dremel.
Old Feb 28, 2013, 11:52 AM
BOHICA!
Joined Dec 2010
That's funny, you're right.....3300kV ought to do the job on a 120mm
Old Feb 28, 2013, 12:21 PM
Jim T. Graham is online now
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
I have updated the image, added a link to the original thread and closed this thread.
Jim T. Graham is online now Find More Posts by Jim T. Graham
Administrator
Discussion Review - HK Alloy DPS 64mm 10 blade EDF w/ 3000kv JGuilty13 Foamy EDFs 24 Dec 12, 2015 10:03 AM
Discussion HobbyKing 64mm 10 Blade 3300Kv Alloy EDF Unit vactrol Electric Ducted Fan Jet Talk 27 Sep 02, 2014 03:05 PM
Sold New in package12 Blade Alloy DPS 90mm EDF unit - 6s 1620kv 2250watt jimmy34256 Aircraft - Electric - Power Systems (FS/W) 5 Feb 23, 2013 05:05 AM
Sold Alloy DPS Series 70mm 10-Blade EDF unit with 2200kv Motor - 1900watt (6s) jimmy34256 Aircraft - Electric - Power Systems (FS/W) 2 Feb 19, 2013 04:55 AM
