Old Feb 27, 2013, 06:10 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
How to hold mylars for painting
I'm painting some mylars for bagging and was wondering what's the best way
to hold them up for painting...
BillO is offline Find More Posts by BillO
Old Feb 27, 2013, 08:32 PM
Paul Harvey is offline
Find More Posts by Paul Harvey
Canada
Joined Jun 2009
The simplest way I have done it is to hot melt glue a couple small wood blocks to a piece of card board leaning back on a chair kept from sliding off the chair with a piece of tape. Just rest the mylars on the cardboard with the blocks holding them up and spray away.
Paul
Paul Harvey is offline Find More Posts by Paul Harvey
killercando is offline
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Just lay them flat. Then you can lay posterboard masks on them, don't have to worry about runs etc. Start with misting coats also.
killercando is offline Find More Posts by killercando
Old Feb 27, 2013, 09:16 PM
Certifiable User
Joined Mar 2011
Beautimus Dave
Old Feb 27, 2013, 09:36 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Very nice Dave.
How come you get a nice straight line without using masking tape as an edge? I would have thought the paint would have bleed under the paper?
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Feb 27, 2013, 09:43 PM
Certifiable User
Joined Mar 2011
Try and spray away from the seam of the mask and don't get the paint too wet so surface tension won't draw it under the mask.
Old Feb 27, 2013, 10:45 PM
BillO is offline
Firecracker!
BillO's Avatar
Dave, I never thought about laying them flat. I am using an HVLP spray gun with gravity feed, so I can't tip it very far. Thanks for the idea though!
At the moment, I'm doing something like Paul, a piece of masonite leaned up against a support, with wood block "standoffs" that I attach the mylars to with a loop of tape. It seems complicated though.
Old Feb 27, 2013, 11:00 PM
Canada
Joined Jun 2009
Bill O,
I got my version after seeing Phill Barnes paint his mylars. If the mylars have not gone through a cycle or two and are still curly it may put up a bit of a fight.
Painting on the flat has it's own set of needs and challenges.
Good Luck,
Paul
Old Feb 28, 2013, 12:01 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I just stick them to sheets of cardboard with masking tape doubled over on the back.
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 28, 2013, 06:15 AM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
I spray a mist of 3m on the back side. Very light then stick it to the paint booth wall
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Feb 28, 2013, 06:31 PM
BillO is offline
Firecracker!
BillO's Avatar
Thanks guys -- sounds like I'm in the ballpark then...
Question Removing paint from mylars? kcaldwel Composites Fabrication 5 Jan 30, 2013 02:35 AM
Discussion Type of Paint for 'Airbrushing' Mylars? Jeff Winder Hand Launch 1 Jan 24, 2008 08:49 PM
Discussion Painting mylars - how long between coats? Before bagging? infopimp Composites Fabrication 37 Nov 08, 2007 03:46 PM
Discussion Mylar prep for paint TomFlyer Composites Fabrication 5 Dec 29, 2006 02:01 PM
paint for molds and wing mylars in uk thermaled Composites Fabrication 8 May 17, 2005 03:37 PM
