Old Feb 27, 2013, 03:09 PM
deepwater is offline
Find More Posts by deepwater
United States, PA, Lansdale
Joined Feb 2013
voltage reducers
hey guys; what is a good voltage reducer,and where can i get them.i need to go from 12v to 3v and 12v to 9v. thank you very much
deepwater is offline Find More Posts by deepwater
Old Feb 27, 2013, 03:13 PM
Dutchraptor is offline
Find More Posts by Dutchraptor
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
How many Ah's? If it is for logic circuit you can use 78XX ic's. Or else you can always buy these kind of units:
http://www.ebay.com/itm/LM2596-DC-DC...item564ee165a1
Danny
Dutchraptor is offline Find More Posts by Dutchraptor
Old Feb 27, 2013, 03:20 PM
Joined Feb 2013
danny;one is forrunning navigation lights,the other is for a radar bar. as for the Ah's i am not sure
Old Feb 27, 2013, 04:25 PM
Skystream is offline
Find More Posts by Skystream
Joined Dec 2012
There are different ways to tackle this. Voltage regulators will keep the voltage at a target voltage (but require a higher input voltage). If your input voltage doesn't vary much and is at a known value and you're not going to be pulling a lot of amps, you could just use some resistors (make a voltage divider), although this isn't necessarily efficient. I'm not really an electronics guy, though.
Skystream is offline Find More Posts by Skystream
Old Feb 27, 2013, 06:28 PM
Massey is offline
Find More Posts by Massey
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
Here check this video out. The guy here talks alot about voltage dividers and regulators and how one is or is not better than another. It also shows you schematics that will allow you to build your own pretty easily.
Tutorial 03 for Arduino: Electrical Engineering Basics (16 min 12 sec)
Massey
Massey is offline Find More Posts by Massey
ESC output voltage reducer? The Don DIY Electronics 4 Sep 14, 2004 09:56 PM
Does Tx power reduce as battery voltage drops? Andy W Radios 12 Aug 07, 2004 02:20 PM
Reducing the voltage of a 3 cell Li-poly pack? KenP Batteries and Chargers 3 Sep 05, 2003 04:34 PM
Rave reducing voltage Rxb Batteries and Chargers 4 Jun 14, 2003 03:02 PM
Voltage reducing diode?? Vinnya42 Power Systems 13 Feb 19, 2002 06:29 PM
