Feb 27, 2013, 11:42 AM
United States, TX, Sugar Land
Joined Feb 2013
another work related project... help?
Hey All,
I could use your input with this project. I work at an oilfield services company, we have some horizontal sections of pipe, which avg i guess about 40' long, and are connected together with collars (unions), to lengths of up to 250'. We occasionally get debris in the pipe that we would like to clear, and also we are generally curious as to the condition of the I.D. of the pipe, the geometry of the collars, etc. So, i suggested an RC solution, with FPV, possibly a robotic arm or other debris retrieval system, and my suggestion got approved =D however, since the company wants to pay for it, they also want it to be a somewhat integrated solution, i.e. not a bunch of junk wired together with a zillion moving parts, multple controllers, etc.. Something anyone could use, with a little documentation for training/operation.
We tossed around the idea of an Arduino based tracked robot vehicle, with XBee telemetry; and while we do have the skills to implement, it would take a lot of development time, lots of coding. An RC solution might be quicker to implement.
Here are some of our requirements:
Our 4 different pipes range from 10" diameter to 4.5" diameter, so size is a concern. I've seen a few RC trucks out there around 4" wide, so i would like to start there. The collars where the pipes join together might have a step about 1/2", so the vehicle must be able to traverse them. (soft, knobby tires should be fine).
since we will need to implement FPV and an arm, i need controls for them. This is probably where you guys can help me the most right now. I dont see much in the way of off-the-shelf vehicles with extra/auxilliary channels. So i guess that means we need to modify something. My idea is to get a suitible chassis, and switch over to using a flight TX/RX, 5 channels minimum. The left stick could control Throttle (up/down) and Direction (left/right). The right stick could control a Pan/Tilt for the camera. and the 5th channel could be a single function to operate the arm- either a pinch mechanism or just drop a garden hoe-shaped tool behind the debris... then i should mention, we do not need a reverse function, as we will never send the vehicle into the pipe without a tether. so if we can just get a scoop or something behind the debris, we can pull it out by the tether.
so! does this sound halfway feasible? any suggestions on a platform, where to start? i have next to no RC experience on the grand scale of things, i've owned a few RTF planes, never built my own system tho. We are electronics technicians with plenty of general electronics experience, good solderers, just no RC experience.
Thank you for your time!
