Old Apr 02, 2013, 12:30 PM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
Homemade gimbal, 46FW:
Eerste testvlucht Brushless Gimabl (3 min 21 sec)
Aaalie is offline Find More Posts by Aaalie
Old Apr 02, 2013, 01:09 PM
Jcflippen is online now
Find More Posts by Jcflippen
United Kingdom, Cardiff
Joined Feb 2013
Very good pictures - what camera and lens - NEX5?
Jcflippen is online now Find More Posts by Jcflippen
Old Apr 02, 2013, 01:32 PM
Aaalie is offline
Aaalie's Avatar
Netherlands
Joined May 2006
Most of them are EOS-M, 22mm pancake Canon. Some could be NEX and 16mm Sony pancake. Compilation of first three flights, during the flights did some adjustments and mounted a few other cams/lenses.
Old Apr 09, 2013, 04:13 AM
multirotorLuc is offline
Find More Posts by multirotorLuc
Joined Mar 2013
I am having some issues and hopefully someone could help.
I was able to connect and load the controller with v46 firmware before I got my gimbal. I got my gimbal yesterday and was trying to access and configure the controller I was not able to access.
Got the message when I try to upload the firmware again : avrdude: stk500_getsync(): not in sync: resp=0x00. From what I have gathered, this message will appear when the software is not able to communicates with the hardware.
The GUI is reading the contoller forever.
There was no error upon connecting the controller (blue light on). Mine is allocated Com5. Everything was in default (baud in 9600 etc). I'm using Arduino 1.04. The error appears after compile completes with the Upload done message. When I try to connect using the GUI, the status is TC: Reading Values.... and nothing happens.
I had tried reinstalling the ftdi drivers. Switch to another laptop, still getting the same message.
Is there a way to RESET the controller?
Any help is appreciated.
multirotorLuc is offline Find More Posts by multirotorLuc
Old Apr 10, 2013, 04:23 AM
hdworld is offline
Find More Posts by hdworld
hdworld's Avatar
Joined Feb 2012
Hi It seems when you are were going to upload again your power connection was interupted shortly and your bootloader crashed , for this , need USBASP programming machine, and use arduino software
and choose the right programming unit under TOOL, and begin to burn.
hdworld is offline Find More Posts by hdworld
Old Apr 11, 2013, 02:02 AM
Joined Mar 2013
I managed to use another system (macbook pro) to flash the firmware again without problem. Using v46 GUI in win7 was then able to connect to the board and simulate the IMU.
Issue now is the motor is twitching. Going to check the settings again.
Old Apr 26, 2013, 02:57 AM
Luis Benati is offline
Find More Posts by Luis Benati
Joined Feb 2013
As for flight controller, hobby-wing has them for sale now.
Luis Benati is offline Find More Posts by Luis Benati
Old Apr 26, 2013, 11:50 AM
7subaru4 is offline
Find More Posts by 7subaru4
Joined Dec 2012
hi,
I have exactly the same problem, like many others people since 1 week ( that weird ! )
Mine just crashed without any reason and make smoke my IMU board.
The Martinez board is working but I can't upload f0.48 again on it still the 3 flashs red led with "not in sync" error.
What did you do to make it work again ?
How do you reflash the board with the bootloader ?
plz help me
7subaru4 is offline Find More Posts by 7subaru4
Old Apr 26, 2013, 12:11 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
i had to burn the bootloader to fix that sync issue with arduino. Burn Bootloader in under Tools in arduino. Since i had a socket tool for flashing escs and a usbasp, i was able to burn a new bootloader and reflash 048 firmware.
check this out
TheFernMan is offline Find More Posts by TheFernMan
Old Apr 26, 2013, 02:18 PM
louiealadph is offline
Find More Posts by louiealadph
Joined Apr 2011
Just Sharing Our German V3 Board. with alexmos Fimware. Just Having Fun,still private use only
Imu test
Alexmos Firmware on German Brushless Gimbal board. (0 min 27 sec)
Video Test
Alexmos firmware on german Board Ground video test. :) (0 min 46 sec)
louiealadph is offline Find More Posts by louiealadph
Old Apr 27, 2013, 06:06 AM
7subaru4 is offline
Joined Dec 2012
check this out
i try your solution with this USBasp AVR from hobbyking.
Its not working driver are installed but when i upload bootloader on the board with Arduino i have multiple errors !
Which USB asp avr did you use ?
Old Apr 27, 2013, 06:37 AM
simiban is offline
Find More Posts by simiban
simiban's Avatar
France, Alsace, Erstein
Joined Jul 2012
We had the same problem 2 days ago.
With a second USBasp we where able to flash the firmaware of the first one to avo´d this message.
But even with this message the ESC Blue series was flashed properly
Hope you have 2 USBasp by u
simiban is offline Find More Posts by simiban
Old Apr 27, 2013, 07:02 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I'm just curious just how trash does a design have to be to keep having all these programming problems? I mean ....
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Apr 27, 2013, 07:09 AM
TheFernMan's Avatar
Joined Jul 2012
I wonder too why it happens. My issue was when loading different firmware. Some people it seem to happen out of nowhere.
Old May 08, 2013, 01:22 AM
Kaen is offline
Find More Posts by Kaen
Joined Feb 2013
Cool stuff... mind sharing how you loaded the alexmos firmware onto the martinez v3 board?
Kaen is offline Find More Posts by Kaen
For Sale Very nice (DIY) 2 Axis project gimbal BIGTACO Aircraft - Electric - Multirotor (FS/W) 5 Feb 28, 2013 07:55 AM
Off Site honeybee cp extras very cheap $95 "buy it now" siryan Aircraft - Electric - Helis (FS/W) 0 Oct 11, 2006 10:28 PM
