Old Mar 07, 2013, 02:58 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
Originally Posted by Lbuff1 View Post
Gliders or sailplanes?
Here's how I store the large sailplanes.
holy crap!!!
i want a man cave like that one!
mine are tucked away in cupboards or behind mirrors in custom bags. but you can see a plane in most rooms of my house.
socommk23 is offline Find More Posts by socommk23
Old Mar 07, 2013, 05:41 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
tip
Hey,
I bet everyone knows this but it is very important that whatever you use be truely FLAT. The best way I know to get a wing warp is storing on non parallel surfaces such as hand drilled dowel rods in 2x4s.....OK I'm busted I did do that ...once many years ago
ozmo01 is offline Find More Posts by ozmo01
Old Mar 07, 2013, 06:47 AM
socommk23's Avatar
Joined Aug 2010
my wingsa are stored on their ends! no warps. all good. lol
Old Mar 07, 2013, 11:27 AM
simmler is offline
Find More Posts by simmler
United States, CA, Santa Margarita
Joined Dec 2007
Works for me
Depending on weight and construction strengths....................the smaller/lighter ones have done well for me hanging by their stabilizers on dowels wrapped with pipe insulation. The larger ones do better standing on their nose, usually in a hole lined with pipe insulation. Wings I either keep on the fuselage as they stand/hang, or vertically on their roots. Very interesting seeing the other storage methods, and also the flying creations in/on them. Some good ideas for sure.
simmler is offline Find More Posts by simmler
Old Mar 08, 2013, 04:59 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by CoolCanuck View Post
I hang most fuselages and wings on straps using hooks and some cheap fabric straps.
Wings are hung L.E. down.
The heavy scale fuselages are kept in cradles. Most stuff in bubble wrap "bags".
Some are kept in storage "bags" attached to a broom-stick handle for easier transport to the field.
Everything neatly stores on shelves in my "storage room".
yea, I've got too many, but then again...
I LOVE it when the shelves are custom built to fit the exact dimentions of the models. (-:
rdeis is offline Find More Posts by rdeis
Old Mar 10, 2013, 03:13 PM
Graham 65 is offline
Find More Posts by Graham 65
Graham 65's Avatar
Chipping Norton, UK
Joined Jul 2006
Having asked this question in the first place, its time to show whats been done.
Some fantastic set ups have been shown and if my planes could have there own hanger then they look like an ideal sulution, however my fleet has to share the garage with all the clutter that goes in a family garage. Mind you the cars never get a look in!
So out with anything that has not flown in ages, all banished to the loft. Several new shelves for storage above and below. Bags still need to be made to keep the dust off some of them.
Pictures show the original state of things and where its at now.
Graham 65 is offline Find More Posts by Graham 65
Old Mar 10, 2013, 04:30 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
The bigger they are the bigger the room needed.
davidjensen is offline Find More Posts by davidjensen
Old Mar 08, 2014, 12:54 PM
LSF226 is offline
Find More Posts by LSF226
United States, WA, Shoreline
Joined May 2004
My Sailplane Storage
This solution is similar or identical to a previous post. The tracks and supports are intended for shelves and were bought at the Home Depot. They come in single and double versions. For my models, the single version was more than adequate. The tracks come in white or galvanized, the galvanized are a little cheaper. The shelf supports come in a range of lengths: 8”, 10”, 12” and 16”. The 8”length proved more than suitable for my models so that’s what I used. I was a little concerned about having wings and fuselages resting on a single vertical piece of metal. The solution to cushion the shelf support was a few aisles away and it’s called Polyethelyne Foam Pipe Insulation. This is a soft foam tube, slit on the bottom and it cuts easily with a blade or a bread knife. Simply cut to length and slide over the shelf support.
LSF226 is offline Find More Posts by LSF226
Discussion What do you store your lipo's in?? two-stroke Batteries and Chargers 83 Jun 21, 2015 02:46 PM
Discussion How do you store/display your copters ? mskeyspirate Electric Heli Talk 23 Mar 03, 2013 04:15 PM
Discussion how do you store your foamies? swampflyer 3D Foamies 16 Feb 09, 2013 12:24 PM
Discussion do you store your lipos ? fastfwd Electric Plane Talk 27 Jan 19, 2013 06:09 PM
How do you store your sailplanes? gasbag floater Thermal 24 May 27, 2005 05:57 PM
